Question about Home
How do I repair a bathtub faucet?
I am trying to replace the stem of my bathtub faucet and looking for any assistance on how to repair it.
Posted by Jerry Bell on
Jenny Molin
It's not any difficult job to fix your bathtub faucet if it became leaky. You can fix it using some basic tools. Watch this video to watch how to do it step by step ( 11 Easy Steps to Fix a Leaky Bathtub Faucet ). Replace your Bathtub faucet it is old enough. Thanks!
Posted on Mar 19, 2020
heppnerguy
    New Friend:
  • 13 Answers
If you really want to know, go to YouTube.com and type on " how to repair a bathroom faucet. "
Posted on Aug 08, 2014
2 Related Answers
Anonymous
  • 10 Answers
SOURCE: bathtub faucet only runs hot water. think it is
there should be alternate little faucet knobs somewhere close one hot one cold, maybe you just have the hot knob turned to the maximum
Posted on Aug 29, 2010
jyackle5
Jyackle5
  • 8197 Answers
SOURCE: faucet leak
May I get the make and model # to help you more
Posted on Apr 05, 2010
We have no hot water coming out of our bathtub faucet. We took it all apart and water is only coming our of the cold side of the pipe
there is probably a shutoff on the rough-in valve in the wall. Sometimes the seal in that comes apart and blocks the water. Get new stem for valve. Unscrew the nut, replace stem, tighten nut. Clean inside valve before u put new one in.
Oct 10, 2015 | Delta & Single Handle Shower Faucet
We have a 2 handle Delta faucet in our bathtub and one leaks. House is 25 years old all the information I can find on Delta is for the single handle type and information would be appreciated
nathanolsen1.gif It probably looks something like this basically front of handle has a cap pops up usually phillip screw after unscrewing that the handle will pull off if its real difficult you may need a handle puller or cut off the handle with saw and replace the stems may just need a gasket but if its that old i recommend buying a whole repair kit that includes handles, stems, seats and will include everything except the seat wrench.
Aug 27, 2011 | Home
Bathtub faucet knobs for cold hot and shower knobs
If you are looking for replacements, Home depot and Lowes both carry Danco replacement
knobs and stems for many models in the plumbing department as well as remodel kits
for Delta. Hope this helps.
Feb 26, 2011 | Plumbing
How do I tighten the faucet handle. The handle is floppy and unless you put downward pressure on the handle when you turn it, it will continue to move from left to right
From what you have described it sounds like the stem in which the handle rests on is stripped and allowing to move from side to side.
Remove handle it has a set screw in the side of it and turn water off. Check the stem may be in need of replacing or the retaining nut that holds the stem down to counter top may be in need of tighting.
Feb 12, 2011 | Kohler Brushed Nickel Roman Bathtub Tub...
Yesterday I was washinh some dishes in the sink when the hot water just turned off while running. I pushed the handle to off and then back on and the cold water works fine but no hot water! I cchecked the...
Depending on what brand of faucet you have you may need to replace the cartridge,moen and clones, or stem/cartridge on delta and similar. I would not replace the faucet until I was sure that you had hot water to the kitchen faucet and the faucet was going to cost more to repair then replace.
If you have supply valves for kitchen faucet I would shut them off and try to take faucet apart to determine where the hot water is stopping. Do not try to force things to much or you may make the faucet totally useless.
If you know what name brand your faucet is you can find several sites on u-tube that show good repair procedures.
I hope this helps you. Thank you.
Jan 12, 2011 | Home
Looking for the stem unit diagram from delta for their single handle shower unit that uses the stem rp1991. in the info leaflet that comes with the replacement they refer to a spring. I want a diagram to...
You can go to the link below to get a parts breakdown of your style of Delta. The seats and springs are recessed into the valve body behind the RP1991 stem. The flat part of the stem rotates back and forth across surface of the rubber seat, so in time the rubber surface wears flat and the spring can no longer push it firmly against the stem.and then the faucet drips.
http://www.plumbingpartsdepot.com/delta1600.pdf
Aug 04, 2010 | Home
I have an Elger slantback faucet which has develope a leak from inside the pop-up stem hole. I have a spare and both the one in use and the spare leak. It is as if there is a hole/crack inside the stem...
It should not be a crack but a loose stem underneath the chrome cover. Take off the knobs, and get a wrench on the the bolt looking part that is sticking up. It should do it. If that isn't the problem, the it is leaking out the cartridge and you will need to replace them, simple job. Take out the old with the water off, and match it up at the hardware store. With the handles off you should be able to see the leak. Hope this helps.
May 20, 2010 | Home
The roman tub faucet keeps dripping. I push down on the stems and it stops?
the retaining nut,located under handle may not be screwed down all the way.this happened to me on similar / same faucet's.so try this and see,nice and easy
Dec 30, 2009 | Delta Faucet Delta T2710-LHP Classic Roman...
The cold water won't turn off on our Bathtub
Sounds like you have a faucet that has a stop that is on the handle and it has broke. Remove the handle and turn the stem on its own. If you end up having to replace the stem, you will need to turn the water off to the faucet and if it is in the tub, you will need to turn the water off to the house. Hopefully this helps you.
Apr 09, 2009 | Whirlpool 6060 DL Corner Pro-Fit Acrylic ...
Home Logo
206 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
