Question about Bose Audio Players & Recorders
Bose av18 60 cycle hum in bass module
Posted by bill martin on
JavaAddict
    New Friend:
    Problem Solver:
  • 8 Answers
Hum is tough. It is often caused by quite a variety of things. First, address the basics:
1. Make sure that none of your signal cables run near to power cabels.
2. If possible, feed all power from the same receptacle.
3. If your plugs are not polarized, try reversing one at a time.
If none of those basic checks uncovers your demon, verify the path of the noise by disconnecting the signal from the preamp at the input to the sub. If is still hums, then look closely at the power feed to the sub, More likely, the hum will stop (along with the music.) In this case, try breaking the shield ground at the sub input (e.g. with a ground isolation adapter.)
You should also confirm that the hum is limited to the sub. Subs tend to exaggerate hum because playing signals in the 60Hz is their forte. So with the sub turned off and bypassed, listen for the hum in your main speakers. If it is there, too, then start checking your sources. Remember, even a source device other than the one selected for play could be the source ... completely disconnect each source at the preamp to track it down.
Posted on Aug 08, 2014
2 Related Answers
dunnbiker
David Dunn
  • 8546 Answers
SOURCE: front bose speakers and bass module stopped puttimg put sound
If you're saying you hooked the Bose speakers directly to the Yamaha's amp instead of the prescribed way through their own bass module - they're cooked.
Posted on Dec 28, 2009
mark24354
Mark T
  • 776 Answers
SOURCE: Doesn's play anymore unless I reset, and plays
Call Bose again. Since they sent you something, you must be the original owner or first to register the serial number with Bose. They have an excellent customer service and lifetime support to the original owner. It is best not to try to open the unit or it will invalidate your support plan with Bose.
The Hum is probably a dry capacitor on the power supply. The power supply is also probably getting warm and the unit is going into protection (safe) mode and shutting down.
Again, give Bose a call this afternoon or Monday.
Good luck.
Posted on Sep 10, 2011
How to hook up bose b1 module into yamaha emx 5000
The Bose B1 bass module is designed to handle up to 125 watts into 8 ohms 40-200 Hz.
The Yamaha EMX 5000 is full 500 watts, and full range. This is not a particularly good match.
EMX5000 Powered Mixers Mixers Live Sound Products Yamaha United States B1 Bass Module Bose L1 Encyclopedia FAQ Wiki
Apr 29, 2014 | Bose Audio Players & Recorders
How to put together a double cube bose speaker
The Bose speakers with the cubes and bass module are all interconnected with a proprietary cable available from Bose, if lost you get a replacement by called 1-800-444-BOSE.
When you connect the speakers all wires run from the receiver to the base module first, then out to each of the speakers. All terminals on the bass module are labeled.
The Bose cubes are all identical and can be used in the front or back positions.
Try to keep them at ear level or aimed at the listening position for best sound.
May 17, 2011 | Bose Acoustimass 15 System
Bose lifestyle 28 will not come on?
The Bose Lifestyle System has two power connection. One is the adaptor for the media center/DVD and the other one is the bass module/ subwoofer. Both has physical indicators showing that power is present. If your pwoer adaptor is ok, then the media center display should show "BOSE LIFESTYLE SYSTEMS" on startup. The bass module power module should be OK when you see a green blinking or steady linght underneath.
If only the media center/DVD has no display then there is something wrong with your pwer adaptor and should be sent for repair.
Hope I have helped you
Apr 05, 2009 | Bose Lifestyle 18 System
Sound cuts out from time to time
Hi, your system has some problem on the bass module which overheats the thermal sensors built in the bass module/subwoofer. I recommend that you bring the bass module to the Bose service center near your location.
That is the only solution...
Mar 18, 2009 | Bose Lifestyle 18 System
Front bose speakers and bass module stopped puttimg put sound
Dec 23, 2008 | Bose Lifestyle 12 System
Changing out my monitor speakers to bose cube speakers
You probably can do it as long as the speakers there now are 8 ohm speakers and you must use the bose bass module with the cubes because the crossover is built into the bass module for the cubes to work. If you just wire up the cubes you will mess the cubes up and they want sound right at all. The cubes are no good without their bass module in other words. Hope this helps.
I’m happy to help further over the phone at https://www.6ya.com/expert/brandon_60dfebff379d64bd
Nov 09, 2008 | Bose Lifestyle 12 System
Acoustimass Subwoofer has a low "hummm" sound when turned on.
Sounds like an inadequate ground wire in the signal cable. You may have to replace the cable between the reciever and bass module. It also, however, may be IN the bass or reciever module.
Aug 04, 2008 | Bose Acoustimass 15 System
Bose AM-500 Acoustimass Bass module hookup to new Sony STR-DG910 Receiver
it need it own sub out speaicl done so bye bose steyem crossovers wont work right in your set up nee dto upgrade the sub try mtx
Feb 04, 2008 | Audio Players & Recorders
Bose lifestyle no sound
Hi, best practice when troubleshooting a no-sound Bose Lifesytle system is to first begin with the internal sources (i.e. the AM/FM). Bose Lifestyle system when connected properly (media center and bass box via the data cable) should show a steady green light underneath the bass module. Begin by simply playing AM/FM tuner and try to increase the volume till 45 (normally the sound becomes audible at this level). If the system still has no sound, then try to check if the bass module is steady green. When you see a blinking green LED (slow green) then do kindly check the DIP siwtch (red latch switch with white mini switches) just beside the Light and data connection. All of the switches should be in "ON" position (basically toggled upwards with the arrow marking indication). Before changing DIP switch settings do ensure that the bass module is not connected to the electrical power. after ensuring that all DIP switch are in the "ON" position, connect the data cable firs and then power up the bass module. Then you should see the bass module blink green twice and once you turn on the nedia center, the green blinking should turn steady green. That should sort out your problem.
Also do note tha this procedure applies only to Series II Lifesytle System and does not include the Series IV (with the smaller bass module).
If all still fails, there is an internal problem with the bass module which would require servicing.
Hope this helps!
Jan 27, 2008 | Bose Lifestyle 18 System
81 people viewed this question
Top Bose Audio Players & Recorders Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
