Question about Motorola Waris GP338 Plus 2-way Radio power supply ac adapter charger
How do i hard reset motorola - Motorola Waris GP338 Plus 2-way Radio power supply ac adapter charger
Motorola Mobility
  • Official Brand Answer
  • 3,100 Answers
It's best to contact Motorola Solutions.
portal motorolasolutions com
Mark
Motorola Mobility Support
Posted on Aug 12, 2014
I have an Rca tablet and can't use it anymore because when I go to turn it on it tells me to enter my password to encrypt storage and I have never had a password on the device. How do I fix this?
If it has Windows, you can buy a password CD online that will get you inside the computer to reset the password. If it is Andriod, here are instructions for a Motorola unit that should be the same because it's an Andriod specific problem.
These are not _my_ instructions. Credit goes to person named at bottom of instructions.
Andoid cell phone reset
Here are the steps to perform a hard reset in your device:
1. Switch off the device.
2. Now press and hold Volume Down + Volume Up + Power button, and release them, when you see menu of Bootloader Mode.
3. Then select option "Recovery" from the menu, using Volume Down, then press Volume Up.
4. When you see Android with triangle, then press together Volume Up + Volume Down.
5. After that select option "wipe data / factory reset" using Volume buttons to browse option, and Power button to confirm operation.
6. Choose option "Yes -- delete all user data" and accept with Power button.
7. Press Power button to select option "reboot system now".
Best Regards,
Katy
Motorola Support
May 18, 2015 | Tablets & eReaders
How to reset a factory fasttouch 7inch tablet
Hard reset or factory wipe is a method of formatting any Android device ( tablet or mobile). By doing hard reset all the apps and files that are installed or created by the user will deleted. Even the memory card will get formatted. So before going for hard reset or factory swipe, it is suggested to remove the memory card if you do not want data to be erased
For simple factory reset the process is follows:
Sponsored
  • Goto settings -> Back & reset -> factory data reset
After factory reset, only pre installed apps and files that came with the device will remain on it.
Feb 19, 2015 | Android 7 inch Tablet
I need a manual for a Motorola Droid 3XT862 cell phone...how can I get one?
Hello Joanne White,
You can download a copy of the User's manual from this link: http://bit.ly/DROID3UG, if you need a hard copy of it, please contact our support team: Select Your Location Motorola Google Company.
Regards,
Lester S.
Motorola support
Oct 24, 2014 | Motorola Mobility Xt862 Droid 3 Verizon...
A password got put on and can't get on
IDA-
You'll have to reset the device. For security purposes you cannot bypass the code.
Use external key option: How do reset my Motorola XOOM to original settings
Mark
Motorola Support
Aug 11, 2014 | Motorola Mobility Xoom
MZ604 Motorola Xoom with no video
Sounds like you need the screen replaced: http://bit.ly/MotoLocation
Apr 12, 2014 | Motorola Xoom Tablets & eReaders
Can not log in, says my password is incorrect
If you can't remember the PIN/Password then you may have to do an external data reset. Ensure you are connected to WiFi to ensure it isn't just an issue because you aren't connected to the internet before resetting. Then go to Motorola Support Find Answers Motorola Mobility Inc to locate your device and find external reset instructions.
Mark
Motorola Support
Apr 03, 2014 | Motorola Tablets & eReaders
Motorola Waris GP338 Plus 2-way Radio power supply ac adapter charger Logo
89 people viewed this question
Top Motorola Tablets & eReaders Experts
buddyglee
buddyglee
Marvin
Marvin
ray gallant
Are you a Motorola Tablet and eReader Expert? Answer questions, earn points and help others
