Question about Lanier Compatible Copier Toner Black For 6112
How can I clear the Lanier 6112 "used toner" on the display?
dano0000
    New Friend:
Open the front door, lift the clam shell open and carefully replace or empty the white used toner container. Replace and turn the blue knob clockwise a few times.
Posted on Nov 03, 2014
1 Related Answer
Adorjani Laszlo
  • 1316 Answers
SOURCE: how do you reset a lanier 6112 copier so the
The maintenance time is flashing.To be use the service enter code C-0-0-C or C -Interrupt-0-Interrupt,then press 20(maintenance counter clear) and 72 maintenance preset counter setting for a new value.
Posted on Aug 07, 2009
Lanier ld 220 won't clear replace toner after i changed it
Very Common problem on that model Problem with the toner hopper assembly. Sometimes the green handle metal pin is out of position. The plastic green handles break a lot also.
Jul 11, 2014 | Office Equipment & Supplies
SC392 ERROR CODE
There's a video showing how to clear SC error codes: Resetting Ricoh Savin Lanier SC Error Code There's also a discussion here: Thread Ricoh Aficio 220 error SC392
Jun 30, 2014 | Ricoh 885288 Black Copier Toner Cartridge...
Lanier 335c toner won't load
If the toner hopper assembly is not broken the mylars inside of it have fallen off over time. The toner supply unit needs to be replaced.
Apr 25, 2014 | Lanier Ld328c Ld335c Type R1 Toner Black...
Lanier LP235c display says Add Yellow toner
Try removing the toner cartridge and gently cleaning the electrical contacts for the sensor. Sometimes they get toner residue on them and give false readings.
Aug 04, 2012 | Lanier 5235 Printer
Lanier 6720 U14 error on screen
U14 is a user code for waste toner full.
Open front cover and you will see a clear plastic bottle at the bottom of the machine; lift this out and dispose carefully of waste toner (do not reuse). When fitting back into machine, make sure that inside of bottle is clean as the detection sensor looks through the bottle to see if it is empty and if toner is covering inside of bottle, the message will remain.
Apr 20, 2010 | Lanier 5235 Printer
Canon 6112 indicates toner full
It might be waste toner that is full.Remove the drum unit by releasing the leaver and pull the drum unit out.There is a plastic plug on the side of the drum.Remove the plug and remove all the waste toner from the drum.Do not use that toner again in the machine.Reinstall the drum unit and lock in place.
Dec 08, 2009 | Canon Office Equipment & Supplies
Wrench (repair)light is on. It's a Lanier 7313.
Set the maintenance counter:perform test command 72.Press C - interrupt key - 0 - interrupt key - 7 - 2 - PSW.The currently set maintenance cycle code is displayed and the ready lamp lights up.After the ready lamp lights up anter the set code corresponding to the maintenance cycle mode.0 = 10000 sheets ; 1= 15000 sheets ;2=30000 sheets.See the toner full detection part and remove the wastw box,change it.Perfor the test command 14.This command used to cancel troubles other then U1 and U2.After cancellation of trouble the test command is also cancelled automatically,also used to cancel toner full detection the maintenance lamp blinking.
Sep 23, 2009 | Lanier Office Equipment & Supplies
My lanier 7345 was working fine & I put in a new toner & now it only says 'call for service'. Help! We are teachers w/a broken copier at school & at home & we can't get our work done!
Hello sir; To read the service code , just press "8" and "clear/stop"in differen time, normally you can reset by turn machine off and on.
Aug 29, 2009 | Lanier Office Equipment & Supplies
How do you reset a lanier 6112 copier so the wrench stops flashing. thanks
Aug 07, 2009 | Lanier Office Equipment & Supplies
EXPOSURE SETTINGS
what´s the model of the machine
Oct 21, 2008 | Office Equipment & Supplies
Lanier Compatible Copier Toner Black For 6112 Logo
60 people viewed this question
Top Lanier Office Equipment & Supplies Experts
Ekse
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Are you a Lanier Office Equipment and Supply Expert? Answer questions, earn points and help others
