HP Officejet Pro 8600 Logo
A
Anonymous Posted on Aug 02, 2014
Printer has operated troublefree in the past. Now the wireless con nection is off and will not reset.
Wireless wizard is locked. Wireless connection is locked. How do we unlock and reset wireless connection
Rod Eslinger
Level 2:
Legend:
An expert who has written 200 answers of more than 400 characters.
  • HP Expert 307 Answers
  • Posted on Sep 30, 2014
Rod Eslinger
HP Expert
Level 2:
Legend:
Answers
307
Questions
Helped
420158
Points
456
To gain access to the service menus and advance printer reset procedures (and service tests) for the HP Officejet Pro 8600, 8610, 8620 or 8630 series printers please refer to our HP Diagnostics document at the following link:
Advanced HP Printer Diagnostics (i.e. printer self tests, etc.): http://inkjet411.com/?page_id=1813
Please note that we provide professional HP 950/951 ink cartridge refilling services in multiple countries and at multiple retail outlets:
INK REFILL SERVICES:
Costco USA (462 stores): http://www.costcoinkjetrefill.com
Costco Canada (57 stores, more coming soon): http://www.ca.costcoinkjetrefill.com
Costco Mexico (35 stores): http://es.costcoinkjetrefill.com/
Fry's Electronics (34 stores): http://www.frys.com/ads/page51
Best Buy Canada (13 stores): www.geeksquad.ca/inkrefill/
Micro Center (8 stores): http://www.microcenter.com/site/content/refill-service.aspx
9 Major Universities in USA & Canada
Ink Cartridge Refill Store Map Locator: http://www.go2ris.com/
Our network of retailers stand behind the product and performance - guaranteed. Customers who have questions regarding the use of refilled ink cartridges can visit http://www.inkjet411.com or contact us directly at [email protected]
Alternatively, if you need to purchase a new ink cartridge(s) and are trying to cut costs, we suggest you try a remanufactured ink cartridge from http://www.inkplicity.com/ as their ink cartridges typically have the lowest cost in the USA, have a high reliability rating, come with a 1-year warranty and provide free shipping for all orders above $20.
-Thank you
Jon Erik Haavie
Level 2:
  • Expert 60 Answers
  • Posted on Aug 03, 2014
Jon Erik Haavie
Expert
Level 2:
Answers
60
Questions
0
Helped
15464
Points
190
Have you tried this?:
Touch Settings - Tools - Restore Factory Defaults
How do I Connect my HP Deskjet 3755 to Wi-Fi?
  1. To setup Wireless network to your printer, the HP Deskjet 3755 Wireless Setup Wizard is an easy method.
  2. Tap on the printer power button to turn on your printer. On your printer's control panel, click the Wireless icon.
  3. The Wireless Summary screen gets displayed. Click Settings->Wireless Setup Wizard.
HP Deskjet 3755 Wireless ' 123 HP Setup 3755 Wifi ...
2answers
I want to add my Lexmark X6570 to my wireless network. The modem is of the 'N' type. I have copied the wireless installation data to a memory stick but apart from putting it in the USB slot on the front of...
here is manual see page 50 -70 its useless to use standard wi-fi configuration because this printer dont use any operational system in this guide brief instruction is given HOW TO. If usefull rate
tip
How to Configure a Wireless Printer Wireless printers typically come with a...
Wireless printers typically come with a transmitter that a laptop, with a wireless adapter, can connect to and print from any location in a home. In order to configure a wireless printer you will need to install the drivers and software from the installation CD that came with the printer. You will be able to run the configuration for the printer driver, for the laptop, at the end of the software installation.
  1. Insert the installation disc for your wireless printer into the drive on your laptop computer.
  2. Wait for the Installation Wizard to appear.
  3. Click the "Next" button to continue and go through each screen to install the software for the printer.
  4. Select the option to "Configure printer driver now" on the last screen of the Installation Wizard.
  5. Click the "OK" button when the Information dialog box appears.
  6. Select the printer port for your printer when the Printer Port Setup dialog box appears.
  7. Click the "OK" button when the "addport" dialog box appears.
  8. Click the "Next" button to continue.
  9. Select your wireless printer from the list of installed printers when the Add Printer Wizard window appears.
  10. Click the "Next" button to continue.
  11. Click the "Connect" button when the Configure Printer Port dialog box appears.
  12. Wait for a connection to be made with the wireless printer and then click the "Finish" button to exit the Add Printer Wizard dialog box.
  13. Repeat this process on each computer that you want to connect to the wireless printer.
on Apr 02, 2010 • Computers & Internet
3helpful
3answers
Will windows 10 work with HP deskjet 3630 All- in-one printer series?
yes
you have to check and adjust compatibility and have the correct driver installed
Cant get a wireless connection to my printer
To be able to set up wireless printer configuration, there are three basic items that you need to have. They are a high-speed broadband Internet connection (with modem), a high speed wireless router and wireless network adaptors. These three items will be used in setting up the wireless printer. Assuming that there is already an existing network in the home or office space, then all that is needed to do to make the printer available in the network through the operating system's networking wizard. If not, then the network must first be established, only then the printer will be made available through that network.
How do i set up my printer to print wirless after setting up the wireless wizard with my router
Presumably, the wizard helped you choose an SSID and a password.
On the controls on the HP printer, enter the SSID and the password,
and then the HP will try to connect to the wireless interface on the router.
Reset Hp C4385 All in one printer to new ATT 2Wire router?????
Turn on your Wireless printer. You can use the touchscreen in the wireless printerto connect your wireless network. On the touchscreen, press the right arrow key and press setup. Select Wireless Setup Wizard from Network menu, it will search for the wireless routers in the range.
4helpful
2answers
How to connect wireless HP Photosmart C4780
here is a general steps to connect a printer to a wireless network
http://www.castleink.com/_a-wireless-printer-setup.html
Hope this helps
Thank you
NetGear PS121 Print Server Problem
Here are some troubleshooting steps that I suggest you try:
1. Check physical connections.
a. Connect the modem to the Internet port of the router. The Internet “i” LED on the front of the router should light up.
b. Connect the computer to one of the four LAN ports (i.e port 1, 2, 3 or 4) on the back of the router. The corresponding port light where you connected the computer should be lit up.
2. Access the router's web-based utility.
a. Please open any web browser like Internet Explorer or Netscape Navigator.
b. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
c. A window will prompt for a user name and password. By default, the user name is "admin" and the password is "password".
Note: If you were unable to access the router's web-based utility, you may reset the router to restore the settings to factory default.
To reset the router:
a. Please push the reset button at the back of the router and release after 30 seconds.
b. Unplug the power adapter for 10 seconds and then plug it back in.
3. Configure the router.
If your Internet Service Provider is using a cable connection, please follow the steps below:
a. Click on Basic Settings under Setup tab.
b. Select No for Does Your Internet Connection Require A Login?.
c. Scroll down on the center page and look for the Router MAC Address section. Set it to Use computer MAC address and click on the Apply button.
If your Internet Service Provider is using a DSL connection, please follow the steps below:
a. Click on Basic Settings.
b. Select Yes for Does Your Internet Connection Require A Login?.
c. Select Other on the Internet Service Provider drop down box.
d. Enter your ISP's username (username@ISPdomain) and password. Then, click on Apply.
4. Configure the wireless settings.
a. Click on the Wireless Settings under Setup.
b. Change the SSID to any unique name.
c. Scroll down, look for the Security Options settings and select WEP (Wired Equivalent Privacy).
d. Set the Authentication type to "Automatic" and the Encryption Strength to "64bit".
e. Leave the Passphrase field blank, select Key 1 and enter a 10-digit number.
Note: The 10-digit number you typed in the key 1 will be the password or network key for the wireless connection.
f. Click Apply button to save the changes.
g. Go to Router Status under Maintenance tab and check if there is an IP address under Internet port. If it's 0.0.0.0, do a power cycle.
5. Power cycle.
a. Power off the modem, router and computers.
b. Turn on the power of the modem first and wait for it to initialize, the lights to stop blinking.
c. Power back the router and the computers. Check if it will be able to get online.
If you have wireless computers, you can connect them wireless to the router. Kindly follow the instructions below:
6. Connect wireless computer to the router.
If you are using Windows XP with Service Pack 1, please follow the steps below:
a. Please right click on the Wireless icon on the right lower end portion of your computer.
b. Then click on View Available Wireless Networks.
c. Click on the Advanced tab.
d. Please delete all the preferred networks then click on OK.
e. Right click on the Wireless icon again and click on View Available Wireless Network. Please select your network and click on Connect. It will ask you for the network key.
f. Please type in the network key and then confirm it. Network key is the password you type on the key 1 of the wireless settings of the router.
g. Make sure not to enable IEEE and then click on Connect.
If you are using Windows XP with Service Pack 2, please follow the steps below:
c. Click on the Change Advanced Settings.
d. Click on the Wireless Networks tab remove all the preferred networks then click on OK.
e. Right click on the Wireless icon then click on View Available Wireless Networks.
f. Select your network and click on Connect.
g. It will ask you for the network key. Type in the network key and confirm it. Then click on Connect. Network key is the password you type on the key 1 of the wireless settings of the router.
If you are using Windows Vista, please follow the steps below:
a. Click Start then select Connect To.
b. Connect to a network window will show up.
c. Select your wireless network and click Connect.
d. It will ask you for a network key. Type in the network key and confirm it. Then click on Connect.
From the above configuration, please check if you can now access the Internet.
For the print server setup, please follow the steps below:
Note: Before setting up the print server, make sure that you can print when printer is connected directly to the computer.
1. Wire the print server to router. Check the lights on it. It should have the ACT light on and the Error light off.
2. One way to test if the printer would work with the print server is to reset the print server for 3 to 5 seconds while it is powered on and after you release the button, the printer should automatically print the IP address of the print server.
Note: If the printer did not print, there is a possibility that they are not compatible. However, you may still continue to try to set up the print server.
3. Install the PS121 software.
a. Power on your computer, let the operating system boot up completely, and log in as needed.
b. Insert the Resource CD for the PS121 into your CD-ROM drive. The CD main page shown at the right will load.
c. Click Install Software.
d. Click Next and follow the software installation utility prompts to complete the software installation.
e. When prompted, restart your computer to complete the installation.
f. When your computer restarts, click Finish to run the Print Server Setup Wizard.
4. Run the Print Server Setup Wizard to Set Up a Fixed IP Address for the PS121.
a. The Print Server Setup Wizard screen should be displayed.
b. Click Next to proceed. The Print Server Wizard will now search your network for the PS121. If the Print Server Setup Wizard cannot find your PS121, check the network connections and status lights on the PS121.
c. The “Server Name” and the “IP Address” your network assigned to the PS121 are displayed. Click Next to proceed to the device name screen.
d. You can enter a descriptive Device Name and Domain Name or accept the defaults. Click Next to proceed to the IP Address configuration screen. The Print Server Wizard displays a recommended static IP address setting for the PS121. This is usually fine.
e. Click Next to proceed.
f. Click Finish to exit the Print Server Setup Wizard. This completes the configuration of the PS121 for operation on your network.
g. Click Yes to run the Add Printer Port Wizard. Follow the instructions in the next section for using the this wizard to set up each computer to use the PS121.
To set up each computer to use the PS121, please follow the instructions below:
1. Use the NETGEAR Add Printer Wizard to set up each PC to use the PS121.
a. When the Print Server Setup Wizard finishes, you are prompted to run the Add Printer Port Wizard. Click Yes to proceed. Alternatively, from the Windows Start menu NETGEAR Print Server program group, you can run the NETGEAR Add Printer Wizard.
b. After a short delay while the software searches the network for your PS121, the Printer Select window opens and displays the PS121 you have set up.
c. Click Next to proceed to the Port/Printer name screen. Take note of the printer model number listed.
2. Set up the correct printer driver for the printer port.
a. Click Next to proceed to the Port/Printer name screen. Take note of the printer model number listed.
b. Click Next to proceed to the Select Printer screen. If you see the exact printer model number listed as the printer model number from in the previous screen, click it to select it from the list.
c. If prompted, print a test page to verify operation of the printer and the PS121. Then, close any remaining Add Printer Port Wizard or Windows Add Printer Wizard windows.
Use the NETGEAR PS121 Mini Print Server Resource CD to run the Add Printer Port Wizard to set up each PC on you network that you want to use with the PS121. Select the port you added
You may also use the links below as your guide to troubleshoot the print server:
http://kbserver.netgear.com/kb_web_files/n101269.asp
http://kbserver.netgear.com/kb_web_files/n100033.asp
However, if this does not resolve the issue we will need to get some additional details from you to be able to assist you further. I have summarized my questions below:
1. Model number of router
2. Model of printer
3. Operating system of computer/s
k24674
Grand Canyon Tech
Grand Canyon Tech
