Kohler 150REOZJF 150 kW Diesel Genset Logo
A
Anonymous Posted on Aug 02, 2014
How to Troubleshoot over frequency problem - Kohler 150REOZJF 150 kW Diesel Genset
J.D. Browning
Level 3:
  • Master 2,760 Answers
  • Posted on Jan 30, 2015
J.D. Browning
Master
Level 3:
Answers
2760
Questions
0
Helped
1014854
Points
6696
First question is does engine run at constant speed , if it doent then your frequency is never gonna match , most engine speed (surges) are caused by fuel problems clean this path very well , if motor runs contant speed but frequency is still not maintained then frequency control is bad replace it
What is a relative frequency table
It is a frequency table where the entries are the relative frequencies
relative frequency= (frequency/sum of all frequencies). The frequency can be expressed as a decimal number or a percentage. In that last case, the total of all frequencies will be approximately 100% (due to rounding errors).
Assigning number to a frequency on kenwood TK-1118
You are talking about a HF (High Frequency) tranceiver, if your example is correct.
Assigning channel numbers to frequencies on a HF set, isn't possible on certain tranceivers in these bands, as there is no facility built in by default.
If you have the facility to store frequencies, I would do so in frequency order, that lowest frequencies first and gradually going up:
example:
4064
4960
5768
6770
7356
8560
9460
10210
14500
etc.,
I think you get my drift.
That's the best practice, that way you know where each frequency is located and the band it's associated with.
I hope this is useful to you.
Cheers,
Peter
What are the applications of a band pass and low pass filters?
A "band pass" filter attenuates all frequencies except those in its specified range. A "low pass" filter attenuates frequencies above a specified frequency (permitting only lower frequencies to "pass"). A "high pass" filter attenuates frequencies below a specified frequency (permitting only higher frequencies to "pass").
For example, a "band pass" filter rated for 500MHz-4GHz will effectively eliminate all frequencies below 500MHz and all frequencies above 4GHz. A "low pass" filter rated at 10KHz will effectively eliminate all frequencies that are above 10KHz. A "high pass" filter rated at 70Hz will effectively eliminate all frequencies that are below 70Hz.
2answers
Moved to another county.need to know how to program my scanner to here
hELLO THERE:
Here is a extensive list of links to scanner codes acrost the UNITED STATES
i REALLY HOPE THAT YOU FIND THIS VERY HELPFULL
BEST REGARDS MICHAEL
Scanner Frequencies Database of old scanner frequencies for thousands of cities across the country. http://www.cityfreq.com/ - 6k - Similar pages RadioReference.com - Scanner Frequencies and Radio Frequency Reference The world's largest scanner frequency and radio communications reference source,
featuring a complete frequency database, trunked radio system information, ... http://www.radioreference.com/ - 17k - Similar pages RadioReference.com - Scanner Frequencies and Radio Frequency ... Scanner Frequency and Radio Communications Reference Database. http://www.radioreference.com/apps/db/ - 62k - Similar pages SCANNER FREQUENCIES - Online Database - Find Scanner Frequencies ... Scanner Frequencies Database, Police, Fire, Rescue, Racing Frequencies, Airport,
Railroad, Taxi, Amateur Radio, Ham Radio Call Signs. http://www.nationalradiodata.com/ - 18k - Similar pages Scanner Frequencies & Codes Similar pages
Need Scanner Frequencies & Codes
Hello there:
here is a whole list of links that will get you what you need ok
I hope that this is very helpfull for you
Best regards michael
  1. Police Scanner Frequencies & Scanner Frequency Resources Police scanner frequency page where you can find scanner frequency resources from across the net U.S. including free and commercial databases and lsitings.www.police-scanner.info/police-scanner-frequencies.htm - Cached
  2. Police Scanners, Scanner Frequencies, & More Police Scanner Stuff! ... police scanners; general police scanner info, police scanner frequencies, live ... 10/03/09 - Police Scanner Frequency Resources (3 New Resources Added! ...www.police-scanner.info/index.htm
  3. General Radio Scanner Frequencies General Scanner Frequencies in subjects including police, fire, aviation, ... Until the day internet becomes free to all, that is something that just cannot be ...www.angelfire.com/wi/scanner/frequency.html - Cached
  4. The Nation's Oldest and Largest Scanner-Only Dealer Frequencies ... name and password for free (although donations are welcome) and ... Copyright © Scanner Master Police Scanners Corporation. All Rights Reserved. ...www.scannermaster.com/Frequencies_s/121.htm - Cached
  5. Scanner Frequencies * Scanner Resources Free Spies Online E-mail. Greetings by Spies Online. Library Articles. Link To Us ... will find police frequencies, general frequencies, scanner radio information and ...www.spiesonline.net/scanner-resources.shtml - Cached
  6. Scanner frequencies, police, fire, NASCAR, airport, Ham radio. Scanner frequency Spectrum database, including police, fire, rescue, racing ... Free US Amateur Radio Call Sign: Home. Scanner. Frequencies. Amateur. Radio. Mass Media ...www.nationalradiodata.com/help-frequencies-frameset.html - Cached
  7. free police scanner frequencies ? washington idaho montanawashington idaho montanaanswers.yahoo.com/question/index?qid=20081023025353AAVGPXU
1helpful
2answers
Where can i get police frequencies for arkansas?
Hello there:
depending on what part of the state you live in this should help out a lot
  1. Central Arkansas Police Frequencies Central Arkansas Police. Benton Police. 154.580. Bryant Police. 155.565. 155.580. 154.680 new ... Shannon Hills. 37.220. Sheridan Police Dept. 155.640 ...www.skylord.com/kevin/central_police.html - Cached
  2. Northwest Arkansas Police Frequencies Northwest Arkansas Police. Bentonville Citywide Trunked System. 856.2625. 857.2625. 858.2625 ... Fayetteville Police Department 10-codes ...www.skylord.com/kevin/nw_police.html - Cached
  3. Arkansas State Police Scanner Frequencies and Radio Frequency ... Scanner Frequencies and Radio Frequency Reference for Arkansas State Police ... Arkansas State Police operations are conducted on this system. Frequency Display ...www.radioreference.com/apps/db/?aid=603 - Cached
  4. Arkansas Scanner Frequencies and Radio Frequency Reference Scanner Frequencies and Radio Frequency Reference for Arkansas ... Arkansas State Agencies. Frequencies for Arkansas public safety agencies. Choose Agency
  5. OK?
  6. best regards michael
Want frequencies for ''lower Burrell police'' pennsylvania
Hello there here is the link for you ok?
  1. Scanner Frequencies Scanner frequencies for thousands of cities. ... Scanner Frequencies. Alaska. Alabama. Arkansas. Arizona. California. Colorado. Connecticut ...www.cityfreq.com - Cached
  2. General Radio Scanner Frequencies General Scanner Frequencies in subjects including police, fire, aviation, ... If you are looking for scanner frequencies, then you have come to the right place. ...www.angelfire.com/wi/scanner/frequency.html - Cached
  3. Police Scanner Frequencies & Scanner Frequency Resources Police scanner frequency page where you can find scanner frequency resources from across the net U.S. including free and commercial databases and lsitings.www.police-scanner.info/police-scanner-frequencies.htm - Cached
  4. Scanner Frequencies & Codes Get a scanner frequency database program by email for your state (Works with Scancat) ... Mr. Scanner Trunking Database You Can Export both frequencies and ...www.bearcat1.com/free.htm - Cached
1helpful
Working principle of super heterodying receiver
you can find it easy with google, but here is how it works...the incomeing rf signal is mixed with a signal of another frequency from the local oscillator and then passes through a non linear device (semiconductor). after passing through the nonlinear device the output will contain the original frequency,the local oscillator frequency, and frequencies equal to those added together and subtracted from each other,these signals are then passed through filters to obtain only one which will be either the rf frequency plus the local oscillator frequency or the rf frequency minus the local oscillator frequency. This new frequency is then coupled to the intermediate frequency amplifier stages where most of the amplification takes place before the audio is removed and passed to the audio stages.
3helpful
2answers
Scanner frequencies
almost all frequencies are going digital encryted which will make finding frequencies hard to find
but there is a way to find frequencies
goto internet type in police scanner frequencies ( your city state or town) this will find the frequencies you need
Top Kohler Electrical Supplies Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Kohler Electrical Supply Expert? Answer questions, earn points and help others
