Question about American Standard Cadet 3 Right Height Elongated Toilet by - ADA Compliant
Fix an american standard slow close toilet seat
Loose. Needs to be tightened
VBGSr
    New Friend:
  • 39 Answers
Check the chain the goes between the handle and the flapper.
It should not be taught. If it is it will not permit the flapper to seat
properly and water will leak out. Adjust the chain length so the flapper is seated and there is just a little slack in the chain.
Posted on Aug 02, 2015
5 Related Answers
Anonymous
SOURCE: american standard toilet
I have the American Standard Champion 4 toilet. Water is leaking from the tank to the bowl causing the toilet to refill. I've replaced the flapper and cleaned the surface the flapper contact. Nothing seems to work.
Posted on Nov 23, 2008
djchillsnyc
charlie rodriguez
  • 152 Answers
SOURCE: have to flush 2 or 3 times to empty toilet bowl
hello, this is a standard toilet you will need to inspect the flapper that is the rubber flap that holds the water up in the tank it works when you pull the lever it pulls the chain upward and lets the water flow if this flapper is old it may not stay up long enough for the water to flow. open the tank top and flush the toilet see if this flapper is staying up long enough and giving the tank enough time to empty if not change this rubber flapper its inexpensive part.
if this is not the reason then you need to adjust your water filler valve there should be a small screw on top of the pivoting float arm
if you have to adjust it for the water limit line inside the tank this will be the proper amount of water needed to flush once completely
also check that the chain lenth on the pull lever is not pulling the flapper down quicker than its supposed to,
try this let me know your results
hope it helps
Posted on Dec 15, 2008
Jeff Maul
  • 9 Answers
SOURCE: hole in back of toilet (stool) leaks water.
The hole your refering to is common in the manufacturing of toilets and is generally filled before it leaves the manufacturing. I have repaired several toilets, new toilets, all American Standard, using a good grade of epoxy - not silicone. I used West System epoxy as this is made for marine projects and surprisingly states "toilet repair" as one of the uses of their product. I'd suggest carefully chipping the smooth porcelan around the hole to give the epoxy something to grip. Use a knife or screwdriver to gently chip the edges and make sure the area is dry. Press the epoxy into the hole and give it enough time to cure before putting it back in service. Of course, if the toilet is less than a month old I suggest returning it and getting a new toilet.
Posted on Jun 22, 2009
dmftrucker
daniel hendrickson
  • 1922 Answers
SOURCE: running toilet
your float is stuck
Posted on Oct 13, 2009
Anonymous
Mine don't leak but the toilet suffered from the lazy flush until I found the hole and covered it with masking tape.
Posted on Aug 18, 2010
Hi Fixya Team, I have a loose toilet seat and it is difficult to tighten as there is no underside. The toilet seat and cover fall out from the hinges. Please may someone help me. Thank you.
If the bolts spin and don't tighten, you'll need to use pliers to grip the nut on theunderside of the toilet while turning the top of the bolt with a screwdriver. Tightenuntil the seat stops wiggling. Fortunately, there's something you can do to keep thetoilet seat from coming loose so often
Loosen the screws with a screwdriver just enough so you can adjust the hinges to reposition the seat. Temporarily reinstall the seat and lid by pressing them back down onto the hinge pins. Close the seat and lid, and align them with the front and sides of the bowl.
Dec 29, 2018 • Home
How to tighten a vitro nupva toilet seat.
Christina, how to tighten or install hidden fasteners on your toilet seat. check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Remove Vitra Shift toilet seat
Soft Close and Quick Release Toilet Seats Installation
How to fix loose toilet seat
http://vitraglobal.com/
Jun 27, 2016 • VitrA Home
How to tighten the seat on toilet
Put your hand around the back of the seat and you will feel the nuts. Tighten them by simply turning them.
How to tighten an american standard toilet seat
They all work pretty much the same. Feel around the top rim of the bowl near where the tank meets the bowl you should find one bolt underneath on either side of the toilet seat. Tighten the nut under there to tighten the seat.
The toilet set is loose and move around. How do you tighten it> Serial Number is 8321280870
lift flat tabes on back hinge reach under hold wing nut with hand and use a flat head screw driver to tighten down
Toilet seat does not wont to close only using about a month
seat hinges were tightened out of alignment. Loosen platic nuts and tighten snugly, rotate hinges to bein line and tighten
11helpful
Slow closing toilet seat not working
It needs a new air shock on it. You might be able to take the old one apart and fix it but replacement would be best.
How to tighten the hinges on a slow close toilet seat?
You don't want to overtighten since you could crack the porcelain. Are your rubber washers in good shape? This will help. You should be able to do this w/out doing any damage.
American Standard Cadet 3 Right Height Elongated Toilet by  - ADA Compliant Logo
Top American Standard Home Experts
Mike
john h
Ekse
Are you an American Standard Home Expert? Answer questions, earn points and help others
