Question about Sony CDPCE500 cdp-ce500 5-disc cd changer
MESSAGE READS "NO DEVICE"...Yesterday musice stopped playing for all 5 discs
Machine is 14 months old. Received for father's day 2013. played perfectly till yesterday...How to fix...cost??? 78 year old veteran, Vic Zirkel [email protected] COMCAST.NET
ELECTREPAIR USA
    Habit-Forming:
  • 195 Answers
Have you tried disconecting it from the power completely leaving it for five minutes and plugging it in again?
Posted on Jan 06, 2017
5 Related Answers
Anonymous
  • 24 Answers
SOURCE: `Sony CD player won't play burned discs
Many of the older Car CD Players will not play CD-R's or they may with static sounds behind the music. What you need to do is try using a different brand of cd-r disc. If this doesn't work then it means that you may need to replace the CD player because the model that you have may not be decoded in order to play CD-R, CD-RW, play MP3's or anything of that such.
Get back to me if this doesn't work I'll help you square it away.
Posted on Nov 20, 2007
4L60B4R1UM
  • 133 Answers
SOURCE: My sony MHC-GX99 stereo will not play my cds.
Some possible causes:
a) dusty laser lens - cleaning it is the solution, you may use the lens cleaner disc (the one that uses liquid), this can be purchased in many shops. I prefer to clean the lens manually, using a cotton stick and some ethyl or isopropyl alcohol (DO NOT use acetone, benzene or similar strong solvents, these will ruin the lens).
b) dirty brush contacts inside the spindle motor (i repaired quite some CD players that had this kind of trouble). They cause the motor to spin with less power so the driver tries to compensate putting more power into the motor, which causes a feedback effect on focus (it may not work properly). The best solution for this is to replace the spindle motor (if you can find one), the second best solution is to clean the brushes and the commutator (that's what i usually do), but this is a pretty delicate and somewhat complicated procedure since you have to open up the motor, clean it and then put it back together in a correct way. I wouldn't recommend doing this unless there is absolutely no way to obtain a new motor (if you are truly interested in learning how to do it, post me a message, i'll explain it).
c) the main power switch has oxydized contacts, which means that the voltage on the primary of the power transformer is a bit lower, and, consequentially, all of the secondary voltages are lower, too. I know it may sound weird, but i had some players in which i cleaned the lens (on BOTH sides plus the mirror inside the laser), opened and cleaned all of the motors, but they would still not work correctly. Only after i've cleaned the contacts on the main power switch did they return to normal functioning. Obviously it's much easier to change the switch to solve this (if you have a spare one). You can check if the switch is the cause if you bypass it (you need to bring the mains voltage directly to the primary of the power transformer, but do it with caution as mains voltage can be LETHAL to you and your CD player - i don't recommend this either if you're not trained in electric safety).
These are just some of the possible causes. It may as well be that the real cause is something else, so don't take any of these for granted, they are just suggestions.
Anyway, i hope you can fix it (or at least have someone do it for you).
Good luck and best regards
3rq8 (triarcuate)
Posted on Jul 18, 2009
Gerard
  • 211 Answers
SOURCE: Put in clean commercial disc and get error msg "no disc" period!
Dr. OM,
Lets give it a try. The purchasedate will be 1991 (HI).
I'll suppose you allready cleaned the laserunit.
You can try to clean the laserslides, sometimes they are sticky and dry. Then the laser is not fast and precise enough to read the index of your CD.
Clean them with some alcohol on cottontips.
When they are really clean, use just a little teflonoil to make sure the laserunit slides very smoothly.
Regards,
73's Gerard
Posted on May 14, 2010
Testimonial: "Dear OM (Gerard). RIGHT ON !!! Your help was appreciated very very much. Your suggestion worked immediatelly. When you get to be nearly 90, things you did without hesitation become cautious prospects. Thanks and 73's - W2LRP (Harry)"
Anonymous
  • 11 Answers
SOURCE: Hi. I recently bought a
This happens when your laser is not able to read the data of the disc. Either u are using disc which the player cannot read or the disc is not readable. If your CD player is not reading the discs which it used to read earlier then CD player laser head has to be replaced.
Posted on Aug 15, 2010
elix0411
Jose Cada
  • 3530 Answers
SOURCE: Sony SCD-CE595 5-Disc CD Player. Shows TOC disc
Welcome to Fixya
Sounds like the lens stopped reading the disc. Try to clean the lens by using CD cleaner.
Get back to me for any update.
Thank you for using Fixya!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Posted on Dec 18, 2010
My downloaded music is starting to play on its own. What is going on?
Why does Google Play Music start automatically? - Android Forums ...
forums.androidcentral.com > ... > Samsung Galaxy S4
Jun 21, 2013 - 15 posts - ‎12 authors
Why does Google Play music sometimes (often) start automatically in the ... the "automatically download" album art option or else it'll start doing ...
The Best Music Player On Android: Google Play Music ...
www.makeuseof.com/.../the-best-music-player-on-android-google-play-...
Nov 20, 2013 - Play Music has been around for a while now, and it's been my musicplayer of ... When you first open the app, you start at your Listen Now section. ... The orange pin indicates that the album has been downloaded to my device for offline use.... You can create your own Instant Mixes from any song, album, ...
How to stop the Music app from auto-playing in your car ...
www.imore.com/how-stop-music-app-auto-playing-your-car
Jan 16, 2016 | Cell Phones
Why won't it stream or play disk?
Call Kurtis: Why Your Samsung Blu-ray Player May Not Play ...
sacramento.cbslocal.com/.../call-kurtis-why-your-samsung-blu-ray...
KOVRSep 26, 2013 - Blu-ray players aren't the same as DVD players. ... disc compatibility issues arise and firmware updates for our Blu-ray players are ... My BD-C6500 is apparently one of those old blu rays that won't play blu rays. ... If you are viewing netflix streaming thru your samsung bluray then YES it definitely can. Its not ...
play mp4 files on a blu-ray player - MP4 - Streaming Video ...
www.tomsguide.com/answers/id.../play-mp4-files-blu-ray-player.html
Jan 9, 2014 - I see a lot of Bluray players will play mp4 files. ... If it won't do it via the USB port, will it do it if the mp4 files are on a DVD? ... player has a menu, items likeDisc Tray, Netflix (I use this menu choice to watch streaming Netflix), ...
Sony BDP-S590 3D Blu-ray Disc Player with Wi-Fi (Black)
www.amazon.com/...Blu-ray-Player.../B006U1YUZE
Amazon.com, Inc.Sony BDPS790 4K Upscaling 3D Wi-Fi Blu-ray Disc Player. 4.0 out of 5 stars 334 · Panasonic DMP-BDT220 Integrated Wi-Fi 3D Blu-ray DVD Player .... With the Sony BDP-S590, you can wirelessly stream music throughout the home to .... at internet.sony.tv as in the past some Sony products won't connect to certain services ...
Amazon.com: Sony BDP-S5100 3D Blu-ray Disc Player with ...
Jan 07, 2016 | Televison & Video
2011 ram 3500, ipod frozen, will not play yet selection of songs etc does. Ipod works in other cars, new USB cord no help. How to fix? Reset uconnect?
uconnect (dodge, chrysler) issue ' Android Forums
androidforums.com > Android Phones > HTC Droid Eris
Jul 5, 2012 - According to htc/ford and chrysler, the evo is not yet compatible with ford sync or ... plug it into the USB connector using the iPod cable, does it work properly?... I can play songs, but the player will not pause, stop, or even force close. .... 2500Pickup2011 (D2) 3500 Pickup2011 (DD) 3500 Cab Chassis2011 ...
2013 Ram 1500 Radio Not Working Properly: 14 Complaints
www.carcomplaints.com/Ram/1500/.../radio_not_working_properly.sht...
The 2013 Ram 1500 has 14 complaints for radio not working properly. ... The screen would not update when a new station button was selected. ... you push, all you see is the Ram Logo.... can't change radio station or play a cd either! ... Also when my ipodwas plugged in i could hear my phone music through the speakers ...
Dec 21, 2015 | Audio Players & Recorders
Hi, don't know if I am sending this to the right bit or not. My son has an older version of the xbox and I bought him a second hand Lego Indiana Jones game which he loves, used to play ok then started...
this is in the wrong section... but... is there any visible scratches on the disc? if there is a visible scratch you can take it into a music store etc.. and they can polish out the scratch for less then $20 :) hope this is helpful
Feb 26, 2011 | Computers & Internet
My Panasonic DMP-BD655 won't read any discs. I was fine a month ago but hen it wouldn't read Blu-Ray discs, but would still play DVD's. It stopped playing DVD's about 3 days ago. I have upgraded the...
Ive only had mine for 2 months and it just stopped playing dvds all together. I had a brand new dvd playing, went to switch it to another new dvd movie and it wouldnt read it or any other dvd Ive tried. I havent tried a blu ray disc yet.
Jan 02, 2011 | Panasonic DMP-BD30K Blu-Ray Player
When I put a dvd in it try's to load and then it reads on the screen "no disc" and It won't play my player is only 5 months old.
Well, first I have to ask if it does load? If it does, and is not reading the disc, it will say, "no disc". DVD's in general are very touchy and the Memorex is not a high quality brand. If only 5 months old, it should still be under warranty.
Oct 23, 2009 | Memorex Televison & Video
DVD Player stopped working... will not LOAD/PLAY dvds
DVDs will not load / play... problem just started... TV approx 14 months old. Recently DVD was working and the TV just "SHUTOFF"?
Mar 03, 2009 | Polaroid TDA-03211C 32 in. LCD HDTV
Lyra H106a Error Message When Attempting To Play Songs
When I plug in my H106a mp3 player, the computer reads it, but fails to install it , any suggestions?
Dec 25, 2007 | RCA H100 MP3 Player
Disc Not reading
mine is doing somthing like that too. but i don't get beeps or the A4 symbol. [email protected] if anyone can help.
Sep 17, 2007 | Panasonic DMRES15 DVD Recorder
Sony CDPCE500 cdp-ce500 5-disc cd changer Logo
82 people viewed this question
Top Sony Audio Players & Recorders Experts
ThaMp3Doctor
ThaMp3Doctor
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
