Sony BRAVIA KDL-32S2010 32 in. LCD Television Logo
A
Anonymous Posted on Aug 02, 2014
Overlapping picture still picture see properly moving picture is overlaped
5 Related Answers
Anonymous
  • 104 Answers
  • Posted on Feb 12, 2009
SOURCE: KV36XBR400 fragmented picture horizontal overlapping lines
this will continue to degrade, almost any failure that can be affected or temporarily cleared up by hitting the set is caused by bad solder joints.
A good shop should be able to find and fix the bad solder connections for probably a little under $100
if you bring it to them and pick it up.
Anonymous
  • 10594 Answers
  • Posted on Apr 30, 2009
SOURCE: Overlaping colors
NO, does not lamp problem.
If its rear projection TV then its convergence our ICs failure problem and need to be replaced these ICs.
Let me know exact model and brand of TV for more info.
Anonymous
  • 7 Answers
  • Posted on Jun 10, 2009
SOURCE: KP53S70 Problem with picture. The colors don't
YOU NEED TWO CONVERGENCE AMPS STK392-570 CHECK THE LAST THREE NUMBERS ON THE ONES IN YOUR SET REPLACE THEM BOTH
Anonymous
  • 3459 Answers
  • Posted on Jun 19, 2009
SOURCE: picture is overlapping with a green and red color
Your TV most likely a convergence failure. ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
0667c5f.pngSOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Chi Chu
  • 8457 Answers
  • Posted on Oct 03, 2009
SOURCE: color overlapping and curved picture
Ur convergence is dead,need a convergence kit,use what in that kit.U know how to solder right?Buy a convergence kit, with these websites.Tv Repair World.com,Ebay.com.
Horizontally overlapping picture when connected to a CISCO Explorer 4642HD. Proper picture when connected to DVD, computer, and WD Live.
press the auto august button we occasionally have this and that fixes it OR you can adjust the screen positioning with the projector so move the picture across till its straight
Ghost / Overlapping Image
ok you have defective convergence crrection circuit! or maybe the RF Box is defective! can you describe the color of the ghost?
1helpful
The picture on my new 55" lcd hdtv overlaps the
Find a buttons on ur tv remote control that said like VIEWMODE,P.size or a Zoom.Push one of these buttons to find the wright picture mode to fit in ur tv picture screen frame.
HCL4715W 47 in. Rear Projection Television: My tv has an overlapping picture and the colors ar...
You have a bad convergence board. Replace two of the STK 392-040 ICs. And check all the resistors that are next to these ICs. Rplace the resistors as neccessary. This will repair your TV. Thanks for asking...sorry it took so long to find you!
1helpful
Out of focus. The picture overlaps itself.
if you mean the picture looks like a 3-d movie without the special glasses and you want to repair this yourself contact ,me at techman32katyahoodotcom
2answers
Colors arched and overlapping
if the option for convergence is still listed under the setting section of the on screen menu, then you need a convergence power supply board. If the convergence option is missing from the menu you need the ITC222 convergence missing repair kit. You can get either one at the following link they include instructions for the repair.
http://www.tvrepairworld.com/
Screen image overlaps edges of screen and entire image is not fitting the screen
if your tv has a format button on it just press it until your picture is to where you like it. plus if you have a hd reciever it also has a format setting on it to.
Picture is curved and wording is overlaping on my Sony 65'' hd pro
convergece ic's are bad also check low value resistors on convergence board. not an easy repair. you need expert soldering experience.
Have picture but color overlaps and is not sharp or crisp.
depending onwhat board you replace you may have to copy the light engine data to the chassis to sync the color wheel.
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
