Question about Allen Brothers Seasoned Leg of Lamb Roast - No Color
Cooking time how long and at what temperature
treeeee
    Master:
  • 519 Answers
What temperature for cooking a pork tenderloin in the oven.
Hello, Lucille -
See the information here:
How to Pan-Roast Pork Tenderloin
https://www.bettycrocker.com/how-to/tipslibrary/meat-poultry-fish/how-cook-pork-tenderloin
The cooking time given at 425 degrees Fahrenheit is for 20-30 minutes for every 3/4 - 1 pound of pork tenderloin (based on the cooking chart information on the web page cited above.)
Note: If you do not reside in the USA and therefore use Celsius temperature measurement, then, the cooking temperature will be about 218 degrees Celsius and the internal temperature, taken with an internal meat thermometer, should be about 52 degrees C when done.
See temperature conversion program here:
http://www.onlineconversion.com/temperature.htm
Best wishes.
Aug 02, 2018 | Cooking
Cooking time for 3.91 lb. chuck cross rib boneless roast
Cooking times are dependent on much more than weight. The shape of the roast, the thickness, the uniformity, the outside temperature, the quirks of your grill or oven... the only way to cook a roast properly is with a probe-type thermometer. You decide what temperature you want the center of your roast and cook it until it reaches that temperature. The lower the cooking temperature, the more evenly the roast will cook. You can Google roasting temps to give you a general idea, but if you use a recipe time, you will overcook or undercook your roast, probably, 60% of the time. Probe thermometers are cheap and reliable.
Jan 05, 2018 | Grilling
I am cooking a pork crown roast for Christmas it says to cook it at 3:50 for 2 hours however I will not be back for 3 to 3 1/2 hours at what temperature should I cook it so that it will turn out well
Hello, Vicki -
I hope you have a meat thermometer.
I suggest you roast the pork at 250 degrees Fahrenheit, so the cooking time will take longer. When you return home, pull the roast out of the oven and insert your meat thermometer. The internal temperature of the meat needs to be between 140-145 degrees F. If it is not, put the pork roast back in the oven and turn the heat up to 350 degrees F. Check the internal meat temperature every 15 min.
You CAN set the cooking temperature even lower to allow for an even longer cooking time. But NEVER set it lower than 200 degrees F.
Note: Be sure to turn your oven off when no longer needed. Plus, allow the meat to rest 10-15 min. before carving.
Dec 24, 2017 | Cooking
Cooking a 6lb beef tenderloin to medium in oven
Cooking times are dependent on much more than weight. The shape of the roast, the thickness, the uniformity, the outside temperature, the quirks of your grill or oven... the only way to cook a roast properly is with a probe-type thermometer. You decide what temperature you want the center of your roast and cook it until it reaches that temperature. The lower the cooking temperature, the more evenly the roast will cook. 300 degrees will take awhile but the outcome will be excellent. You can Google roasting temps to give you a general idea, but if you use a recipe time, you will overcook or undercook your roast, probably, 60% of the time. Probe thermometers are cheap and reliable.
Dec 24, 2017 | Grilling
How long to cook 3lb chuck roast in 350degree oven??
What power level should i when cooking 16 pound turkey?
Turkey Farmers of Canada recommends cooking a whole turkey to an internal temperature of 170°F (77°C) in the middle and 180°F (82°C) in the thigh. When roasting, any stuffing placed in the cavity of the bird should reach an internal temperature of at least 165°F (74°C). Let the bird stand for 20 minutes before carving.
Cooking Times and Temperatures ' Canadian Turkey
https://www.canadianturkey.ca/wholebird/cooking-times-and-temperatures/ https://www.google.co.uk/webhp?sourceid=chrome-instant&ion=1&espv=2&ie=UTF-8#q=turkey+cooking+times+and+temperatures
Nov 25, 2016 | Kitchen Appliances - Others
I need an instruction manual for a cooks essentials air fryer
How to Use Your Fryer:
  • Remove all packaging materials, sticker, and labels.
  • Clean the basket and pan with hot water, soap and a non-abrasive sponge. These parts are dishwasher safe.
  • Wipe the inside and outside of the appliance with a clean cloth.
  • Place the air fryer on a flat and even surface.
  • Put the basket in the pan.
  • Plug unit in to an approved wall socket.
  • Place the ingredients in the basket and then put the basket and pan back into the appliance. The fryer LED will light up.
  • Set your cooking time and temperature by either choosing one of the 8 presets or manually set it with the "+" or "-" buttons. See "Cooking Guide" to determine the right time and temperature.
  • Once you have set your cooking time and temperature, press the "Start" Button.
  • The heating icon and fan icon will be blinking and this means that the fryer is starting and is circulating the hot air in the fryer. NOTE: During hot air frying, you will notice that the heating up icon will blink and stays from time to time. When the heating icon is on, it means that the temperature inside the fryer has reached the set temperature. When the heating icon is blinking, it means that the temperature inside the fryer dropped and is below the set temperature and is currently heating up to the reach the set temperature.
  • Some ingredients may need to be shaken halfway through the cooking cycle (see "Cooking Guide"), To do this, pull the pan out of the air fryer by the handle, the air fryer will automatically shut down. Then shake the contents in the basket, then slide the pan back into the air fryer and it will resume the cooking cycle. CAUTION: Do not press the button on the handle during shaking; this will detach the basket from the pan.
  • When the cooking time has been reacher, the air blower will stop in 20 seconds.
  • Pull the pan out of the fryer and place it on a pot holder. The cooking pan is VERY HOT do not put on surface that can burn. NOTE: Oil from the ingredients will gather in the bottom of the pan, so be careful when pulling the pan out of the fryer.
  • To remove the ingredients, press the button on the handle of the pan to detach the basket. DO NOT TURN THE PAN OVER. PLACE ON A POT HOLDER.
  • Upon placing the cooking basket back into the air fryer, the air fryer will automatically go to the previous cooking cycle and will repeat the previous cooking cycle, press the cancel button to stop and reset the air fryer if desired.
Mar 25, 2016 | Kitchen Appliances - Others
Brand new Blodgett Oven - Cookies over-cooked outside, raw inside.
bad thermostat,just because its new doesnt mean it cant have bad parts
May 15, 2015 | Blodgett DFG100 DOUBLE Convection Oven
I need to know the cooking times for my chicken
Use a thermometer and measure the chicken, keep track of how long it takes then you have the time it takes to cook that piece. It is always best to use a thermometer when cooking meat.
Generally I bake chicken at 350 degrees F. for 30 to 40 minutes. To be sure that the chicken bre asts are cooked thoroughly, use a instant digital Cooking or Meat Thermometer for the proper temperature of 165 degrees F.
These links will help.
Safe Minimum Cooking Temperatures
Meat and Poultry Temperature Guide Food Network
Internal Temperature of Chicken and Turkey How To Cook Perfect Chicken...
Mar 23, 2015 | Kitchen Appliances - Others
I have lost my manual for a Simpson Appolo Atlas Stove
call manufactuerer and ask if you can order one or try to do so online
Dec 22, 2009 | Stoves EC500DOA Electric Kitchen Range
Allen Brothers Seasoned Leg of Lamb Roast - No Color Logo
494 people viewed this question
Top Allen Brothers Clothing Accessories Experts
Jim Pattison
Tom Chichester
Andrew Taylor
Andrew Taylor
Are you an Allen Brothers Clothing Accessory Expert? Answer questions, earn points and help others
