Question about Brand Remote Start/keyless/car Alarm Very Sleek
How I can get a service repair business for the diagnosis of a Clifford car alarm system?
I have installed in my 2008 Honda Pilot an alarm system that uses the remote starter SST 50.5X. After 4 years of good performance it just stopped working. I don't know if the problem is the remote (batteries replaced) or the alarm system. I live in Syracuse N.Y. and I have not been able to find a car alarm business that want to take a look at it. Can I send the remote to you for diagnosis so that way at least I can determine if the remote is working?
Helper
    New Friend:
    Problem Solver:
  • 5 Answers
First replaced the batteries, you may find a CR2032 in there easy to replace then try before blaming any other components
Posted on Aug 03, 2014
2 Related Answers
Anonymous
SOURCE: How to find the model # of car alarm system
go to a dealer
Posted on Dec 11, 2009
Wolfman304
Scott Bailey
  • 720 Answers
SOURCE: I bought a SPY TWO
Well done.....
Sounds to me like you've installed it correctly.
The only thing I could recommend at this point, is to scan your vehicle's PCM for OBDII fault codes - this will immediately identify which ignition circuit/component may have been disturbed during installation.
Cheers,
Posted on Jun 13, 2011
Clifford g5 alarm how do i reset it after i was checking fuses it wont let me start the car
The car won't start because the Clifford alarm has a starter interrupt wire where the start wire runs through the alarm system module/relay. The unit then must still be active for the car not to start. If pressing the disarm/unlock button on your Clifford key FOB does not turn the system off, you will after to do it manually. You will need to locate the manual override button installed somewhere in the car that is connected to the alarm system. Turn the ignition switch to "on" or "run" and within 10 seconds press the manual override switch. That will turn the alarm system off and allow the car to be driven normally. I would then take the vehicle to an authorized Clifford or other DEI (Viper) install shop and have them diagnose your apparent problem.
Jul 31, 2014 | G5 IntelliGuard 770 P/N 919621 Car Alarm
Replace discharge line on air conditioner 2008 Honda Pilot
tiger by tail.
read the FSM , see what it says.
not one tool you own , i bet.
go to alldata.com (pop that into google and bingo)
RTM , then ask questions.
IIRC:
  1. pull battery cable neg lug.
  2. connect collection system to our car and capture all freon.
  3. replace line., (unscrew fittings)
  4. new receiver dryer.
  5. pump down system to a vacuum. (gets killer water out)
  6. new compressor oil.
  7. new Freon. by weight added.
  8. test system.
its more then that. but you can google "car freon loop service" any time. or "car R134 loop service"
1million hits. google is your friend. LOL>
here ill type it for you....
https://www.google.com/#q=car+R134+loop+service
Jun 09, 2013 | 2008 Honda Pilot
I need a Clifford 50.7x installation manual
go to www. fitnessmanualsonline.com and download for freeGod bless youcreateLink
Dec 14, 2012 | Clifford Matrix 50.7X - Car Alarm with...
Battery went dead,clifford alarm locked the engine
Assuming that all is well with the vehicle's electrical system (fuses, etc...), the following should work, as Viper/Clifford uses the "fail safe" method of starter disable, and it only works to lock out the starter when the alarm is functioning properly and in the armed state.
That system has a "starter kill" system. When the alarm is actived, the starter kill is engages, and won't let the starter get voltage from the ignition switch. First thing I'd try is connecting the car's battery while the ignition key is turned to the "on/run" position. Cycle the alarm to arm, then disarm, so that the LED is not blinking. It also may require using the manual override button/switch (with the key on) to reset the alarm. Should start after that.
If all else fails, reconnecting the starter wires back together (they are spliced and running through the alarm via a SPDT relay.
Oct 23, 2009 | Viper Vehicle Parts & Accessories
Looking for clifford alarm manual,did not use the car for 8 months,the sound on the alarm went,does work ,lock unlock but no sound ,maybe easy repair????any ideea?thx
look in the phone book, (YES) the phone book and see if there's an alarm dealer around you that is an authorized dealer for clifford they should be able to assist you.
Sep 20, 2009 | Car Audio & Video
Maintenance required light was not reset at last servicing how do I reset it?
HI...........
If you can give me the axact YEAR, I can help you with that.
Thank you. for use fixya.
Jul 24, 2008 | 2008 Honda Pilot
Brand Remote Start/keyless/car Alarm Very Sleek Logo
192 people viewed this question
Top Spy Vehicle Parts & Accessories Experts
Colin Stickland
Colin Stickland
Kardoc
Mr.Mike
Are you a Spy Vehicle Part and Accessory Expert? Answer questions, earn points and help others
