Question about 3Com NBX 3102 IP Phone
How do i reset voicemail password on 3com 3120 phone?
Posted by melissa sealie on
NBX_Tech
    New Friend:
  • 58 Answers
On 5.0 and older software, Log into the NBX Phone system as administrator and click on "tab to it". Then click on the "security" tab under System Configuration. Click on "Reset User Password". Highlight the user you want to reset and then click "reset. The system will reset the password to the same as the extension number.
On 6.0 and later software, Log into the Phone system and go to "System Maintenance, Password Administration". Select "User Password" in the drop down menu and click "Go". Select the box on the left for the extension you want to reset and click on the "Reset Password" button at the top of the list. The system will reset the password to the same as the extension
Hope that helps!
Posted on Nov 25, 2014
Reset the voicemail password
Contact your wireless carrier to learn how to reset or change your voicemail password on iPhone.
If you don't remember your voicemail password or need to change it, contact your wireless carrier for assistance.
If your wireless carrier offers Visual Voicemail, you can change your voicemail password directly from your iPhone: Tap Settings > Phone > Change Voicemail Password.
you have at&t following below steps:
To reset your voicemail password over the phone by calling AT&T's automated system:
  • Call 800.331.0500 from any phone or 611 from your AT&T wireless phone.
  • Press the option for Voicemail Help, and then follow the prompts to reset your password.
Oct 31, 2014 | Apple iPhone 4S
Forget password
If you forgot your phone security code then you can try 1234 or 0000 to reset your phone.It doesn't reset your phone then visit Unlocking4Free.com here they provider master reset code for your Nokia 3120 phone at free of cost.Using this code you can reset your phone and again set a new password.
Apr 14, 2014 | Nokia 3120 Classic Cell Phone
Voicemail password admin reset
The phone password has to be reset on the phone system (by the Administrator), not the phone. If you purchased phones and added them to the system, then those extensions wouldn't have passwords on them if they were newly added to it. If you purchased the entire system and phones then you can reset the phone passwords under "system maintenance", "password administration".
Jan 29, 2014 | 3Com NBX V3000 IP Phone
Password reset code
In order to reset the security phone codes of a Nokia 3120 Classic, you must do the following:1.Press the phone's 'menu' key.2.Select 'settings', and then 'security settings'.3.Select 'Access Codes', and then enter the requested security code for your Nokia 3120 Classic. The default code is '12345'.4.Select 'Change Security Code', then enter the desired code.5. Press the phone's 'exit' key. GOOD LUCK LET ME KNOW IF IT WORKS
Dec 29, 2013 | Nokia 3120 Classic Cell Phone
How to reset a 3com phone
You'd have to reboot the phone, and press the white dot 'Program' button within 30 seconds of reboot, then use the arrows to scroll down through the menus to Advanced settings, and find Eeprom reset to default, and choose that. *Note- This will reset all values of the phone. If it's Ethernet Only, it's fine. If the phone is using a Static IP, it will also clear the IP addressing on the phone*
If you are talking about resetting the phone from a user profile perspective it is different. You can reset the voicemail password under the system maintinence, password administration and select user password in the drop down box. After the password has been reset (to the extension number) they can log in and change the recordings and password. You will also need to then go to the users tab and change the name.
Jul 03, 2012 | 3Com NBX 3102 IP Phone
What my voicemail 4 digit passcodefor 2402620085
Your voicemail password is a 4 digit number that you enter when you want to listen to your voicemail messages from any other phone other than your mobile phone - this is called remote access. This voicemail password gives you the protection to know that only you can listen to your voicemails.
It is vital that your password is set to a random 4 digit password. To change your password, all you need to do is:
  1. Dial 173 from your mobile
  2. You will then be asked to pick a 4 digit number, and then press the # button
  3. If you are happy press press 2
Your password is all set up and you will be prompted to enter it whenever you want to listen to your voicemails through remote access.You will only need to use this password when accessing your voicemails from another phone. You will not need to use this password when accessing your voicemail from your own mobile phone - you simply dial 171 as normal
You can reset your voicemail pass code by dialing 611 or 1 800 331 0500
From the main menu, press3 (To get help with voicemail)
Press 2 to reset your voicemail pass word
Enter Billing Zip code
Customer will receive a text message to their wireless phone with their new voicemail password.
OR
You can log into your "My Account" from the www.cingular.com
From the My Phone page, click Reset Voice Mail Password.
Choose a wireless number from the dropdown menu and select Submit.
A text message is sent to the wireless phone with the new password.
Feb 24, 2012 | Cell Phones
It does not seem that my voicemail is working and i cannot remember my password for voicemail on iphone
Reset voicemail password from AT&T's automated system
Call 611 or 800-331-0500.
Enter the wireless number starting with area code .
Press 3 to "get help with voicemail."
Press 3 to reset your VM password.
Enter the Billing Zip code for the account.
After a few seconds, iPhone will display "Password Incorrect - Enter Voicemail Password."
Enter the last seven digits of the wireless phone number and tap OK.
Reset voicemail password from AT&T's website
NOTE: You must be registered and logged into myWireless Account to view this information.
From the myWireless Account home page, select Phone/Device then choose the Reset Voice Mail PIN link from the left column.
IMPORTANT: If there is more than one line on the account, make sure the correct wireless number is displayed in the Wireless Number list before selecting Reset Voice Mail PIN.
To reset the password for any of the lines on the account, choose a wireless number from the dropdown menu
Click Submit.
Aug 08, 2010 | Vtech 9009111 Cordless Phone
I made a voicemail password and i forgot it. how do i reset the password so i can use my voicemail?
Hi The voicemail feature is provided and administered by the wireless service provider. Please contact the wireless service provider to have your voicemail password reset. Then will help reset you the voicemail password. I hope this information will help you
thanks
Jul 04, 2010 | Samsung Alias 2 SCH-U750 Cell Phone
Why won't my voicemail password does not work
Enter the wireless number starting with area code.
Click Submit.
Jun 24, 2010 | Lands Phones
3com NBX phone number of rings setting problem.
Delete the MAc Address from the system and delete the user account. Re add the phone.
Feb 12, 2009 | 3Com NBX 2102 IP Phone
3Com NBX 3102 IP Phone Logo
1,161 people viewed this question
Top 3Com Computers & Internet Experts
Mike
Vincent G
Vincent G
Sheldon Dedek
Are you a 3Com Computer and Internet Expert? Answer questions, earn points and help others
