Question about Jacuzzi Home
What is the Bluetooth code for the stereo on a Jacuzzi J495?
Posted by Mark Mester on
I have just purchased a Jacuzzi j495 , and i am experiencing water around the entire perimeter of it, i am wondering if this is a normal experience on and outdoors tub in the winter , or if it is a leak
if level of water inside goes down then it's a leak or heavy use!!! but if not it's just condesation this is very normal in cold climates (they sweat) thats why cedar and redwood are used most for extetiors
Aug 19, 2013 | Jacuzzi Pool & Spa
Bluetooth Samsung Galaxy s3
Turn on bluetooth on phone.
- settings-bluetooth > on
Turn on bluetooth in car stereo
- Turn on radio, press Menu.- Scroll with knob to Phone. - Press knob to Select.- Turn knob to select Pair.
Back to Phone
- Hit the Scan button to search for BMW bluetooth- Find BMW Bluetooth name on phone and select Pair. - If should ask for a passcode, enter identical pass codes on stereo and phone.
Nov 05, 2012 | 2006 BMW 5 Series
I need to send a password from the phone to the car how do I imput it on the phone. the password is 1111
Power on the Bluetooth on your car stereo and MP3 player or cell phone. The Bluetooth may always be on in your car, but it may be disabled on other devices to conserve battery power.
Open up the menu of your cell phone or MP3 player and have it "discover new devices."
Select your car stereo from the options your device provides.
Enter in the "Pairing Code" for your car stereo into your device. In most cases you will find the pairing code in your car's manual. if you don't know the code try using all )'s.
Try playing a song once your device indicates it is paired with your stereo. If it doesn't work try
Steps 2 to 4 again.
Use 0000 instead.
Thank you.
Mar 12, 2011 | Cell Phones
I.Tech BlueBand Bluetooth Stereo Headphones whate is the pin code
Hi, In some states, hands free driving is the law. In order to avoid a ticket you need to talk on your cell phone with a bluetooth headset or speaker or with a headset that attaches directly into the phone. Bluetooth headsets are popular for this and other reasons but connecting it to your phone can be confusing. Here are some steps to help you connect your bluetooth device to your cell phone.
Instructions
Things You'll Need:
* Bluetooth headset
* Bluetooth capable cell phone
Read the owners manual for your bluetooth device. You will need to find the code to pair your headset to your phone. This code is usually 0000 (those are zeroes) but verify before you proceed.
Enter your bluetooth option on your cell phone. These can be found in your menu under "bluetooth," "connections," "settings," or something similar.
Turn on your bluetooth headset and put it in pairing mode. Pairing mode means the bluetooth is ready to be found by your cell phone. To pair your headset, follow the owners manual for your specific bluetooth model.
Select "add device" or "search for new device" from your cell phone. Your cell phone will then search for your bluetooth. Once it is found, or discovered, you will need to enter the pairing code (most likely 0000, check your manual to verify).
Select "connect" to finalize the connection if the bluetooth headset didn't connect automatically after the pairing code was entered. Make a test call with your bluetooth in your ear to ensure it is connected properly.
Hope it helped.
And please don't forget to rate me...
Thanks and have a nice day...
Feb 21, 2011 | Itech Blue Pro Bluetooth Stereo Headphones...
Hello I have just bought a Nokia Bluetooth stereo headset BH 505 and I can't find the pin code number. Where is it written please ?
Hi,when you want to connect a Nokia Bluetooth stereo headset BH 505 to a phone all you need is a default code which "0000" and your done Try it it works like magic...Or you can choose to useany other code, but the code must be 4 digits.....
Thanks for using fixya...............
Jan 06, 2011 | Nokia BH500 Bluetooth Headset For N95 8GB...
What is it for and how does it work
HI ....
Motorola Bluetooth Stereo Gateway DC800 is used as
Motorola Bluetooth Home Stereo Transceiver
By streaming music to your the Bluetooth Stereo Headphones, the Bluetooth Home Stereo Adapter turns audio devices such as home
stereos and MP3 players into wireless music systems. Just plug the
DC800 into your home stereo or MP3 player with an included RCA
cable or 3.5mm cable and you are ready to go. You can even hook
up to your RCA capable TV!
Thanks .....
With regards
Priya
Sep 26, 2010 | Motorola Mobility Bluetooth Stereo Gateway...
How do I connect my palm pre bluetooth to my Jenses UV10 stereo? I need a pairing code but neither the palm pre or the Jensen booklet have a code.
The code for the Jensen is 1234, but before it will work, you need to buy a btm15. Its a module that clips to your visor and the cord is ran to the back if your stereo "labeled bluetooth" you can buy these at Amazon for around $60
Sep 05, 2010 | GPS
Can't pair TDK BT-100 headphones to my Iphone
I managed to pair the device after plugging the bluetooth headset into the USB power slot. Then I press the main button for 5 secs until the red light started flashing very rapidly and I typed in 0000 and the headset paired off with my Iphone. Good luck
Aug 19, 2009 | TDK Audio Players & Recorders
Blue tooth compatible Car stereo ..and LG Voyager wont pair
The pass key is the password the bluetooth accessory has. So your car stereo manufacturer has a code that you enter on your phone, so that someone nearby with a bluetooth cell phone won't be able to hook to your stereo - it's usually in your owners manual for your stereo or bluetooth speaker system.
Most bluetooth headsets have a passcode of 0000, and it's the same for Motorola headsets, plantronics headsets etc. You may be able to lookup the passcode for your bluetooth speaker system in a manual online, if you no longer have it.
Mar 25, 2009 | LG VOYAGER VX10000 Cellular Phone
Home Logo
80 people viewed this question
Top Jacuzzi Home Experts
Mike
john h
Bill Johnson
Are you a Jacuzzi Home Expert? Answer questions, earn points and help others
