Check to see if your water supply hoses are set to allow water to flow to washer. The code refers to a water supply problem. Is there a clog in the hoses? Also, read this tech sheet from Whirlpool:
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/a9c27c267a3fa32785256a45005190c7/4048ac9ad5177883852574500049997b/$FILE/duet_f20_code.pdf
SOURCE: Error Code F20 blinking
Hello
I had to take the bottom panel off. There you will find a black squishy like filter. I unscrewed the the screw that holds it tight.
Be prepared for lots of water and suds, the water drains out quickly. I pulled out a wire from my daughrter's bra, that was plugging the filter. Re-attached everything, now it is working just fine. Happy in Maple Ridge.
