Need to hook up to tv
SOURCE: Im going to be running a set of BOSE acoustimass
By set, do you mean just the satellite speakers? Without the sub? With the sub?
Your receiver front, center and rear channels are rated at 100watts per channel at 8 ohms. If the Bose speakers are 8 ohm speakers, you're good to go. And as long as they have speaker connectors on them, and are not specifically made to work with the sub, or with each other(in other words proprietary). If you are using the entire Bose system, it should work fine.
Hope this helps.
SOURCE: Is the STR-DE675 5.1 Surround Sound Receiver
Sure! Any P.C. with an audio output jack, like an 8mm phono jack to stereo for example, can be connected to any audio input on the receiver.
SOURCE: Sony's STR-DE675 5.1 Channel Receiver - Speaker OFF problem
There's a button that turns the speakers OFF right above the headphone jack.
Get the manual: retrevo.com
Testimonial: "@dunnbiker Very true on assumptions! I've tried everything the manual suggests. Right now, nothing is connected to the unit, but upon power up, I get the SP:OFF display (which is not seen in the DEMO mode). I will try the headphone jiggling idea and see what happens."
