Husqvarna Viking Emerald 116 Sewing Machine Logo
Marie Jokipii Posted on Aug 02, 2014
Why does the needle hit presser foot?
I have not used the machine for awhile. I went to use it and the needle is off centered to the left at 0 mm stitch width. At 5 mm stitch width, it was almost centered. I tried sewing with it at 5 mm, but it didn't work. It was a birds nest. The needle was replaced.
Natasha Subko
Level 1:
Habit-Forming:
New Friend:
  • Contributor 64 Answers
  • Posted on Jul 15, 2015
Natasha Subko
Contributor
Level 1:
Habit-Forming:
New Friend:
Answers
64
Questions
0
Helped
11620
Points
81
Did you change the stitch selection, or have it on a stitch that is too wide for the foot that is attached?
5 Related Answers
Anonymous
  • 84 Answers
  • Posted on Aug 02, 2007
SOURCE: Doesn't sew
Hi emnsam....please update your post with the complete Model Number in it's entirety and I will be able to advise you.
Anonymous
  • 188 Answers
  • Posted on Mar 26, 2009
SOURCE: needle stuck in right position, will only sew tiny,tiny stitches
oil it. down the shaft if you can get to it. and where ever there is a hole it always helps.
deborahcha
  • 371 Answers
  • Posted on Feb 14, 2010
SOURCE: the bobbin is bird nesting on my viking emerald
Check that it is threaded correctly (both top and bottom) making sure that the upper thread is in the takeup lever and the bobbin is guided through the tension spring in the bobbin case. Watch the needle as you slowly turn the handwheel counter clockwise (toward you) and the needle point touches the fabric (make sure presser foot is down). Is the thread still relatively taunt? If it is loose, the upper thread tension unit does not have enough tension. Check the areas where the thread goes and make sure you remove any loose threads or fluff which could be inhibiting the tension discs from closing over the thread. If the tension unit still is not tightening enough, the tension unit may need to be replaced or the circuit board replaced. If everything is ok in the upper thread area, now look at the bobbin area. With no fabric, watch as the needle enters the bobbin area. Does it go down and the upper thread catch the bobbin thread and pulls it to the surface? Check for anything preventing the bobbin thread from being pulled up to the surface through the needle plate. If you have still not been able to resolve the problem suggest you take it to an authorized husqvarna viking dealer for service. You can locate a dealer near you by visiting the husqvarna viking website and clicking on the Dealer link on the left-hand side of the page - http://www.husqvarnaviking.com
Good luck.
vunivasa
  • 5 Answers
  • Posted on Apr 23, 2010
SOURCE: Viking Husqvarna Model 6020 stitch selector will not turn.
look at the cam gear. This is the unit that the cam connects to. It could have a crack or be split completely. If there is a crack the cam stack will have to be replaced. The parts are hard to get and a good technician is needed.
RichSew
Douglas Plant
  • 222 Answers
  • Posted on May 27, 2010
SOURCE: presser foot control -- Viking Husqvarna #1 sewing machine
There is a presser foot pressure dial on the left end of the machine, make sure it is on 3 or higher.
Testimonial: "Thanks--Don't know how the wheel was moved, but that fixed the problem. Now if I could only find the owner's manual!! "
My needle keeps breaking because it's hitting the square part of the presser foot that it goes down into.
If your machine has multiple needle positions, make sure the needle is set in the center position. Also, make sure you are using a zig-zag presser foot where the opening is wide enough to accommodate an off-center needle or to make decorative stitching. If you are using a straight-stitch foot, then the foot will have only a small circular hole in the center and the machine must be set for straight-stitch only.
It the needle still hits, then the needle bar may be off-kilter. Take it for service.
Look at the Different Types of Sewing Machine Feet
Why do needles keep breaking?
Just guessing here. Is the needle hitting the presser foot? If so, it could be the wrong presser foot for your machine (especially if it is not attaching properly), could be the wrong needle for the machine or is installed incorrectly, could be the needle bar is not centered, or the needle position setting could be off to one side or the other rather than in the middle. Hard to diagnose without more information.
How can I attach a zipper foot to my unidentified machine?
Assuming you have the correct zipper foot attachment for your machine, you should be able to attach it like any other presser foot. On some machines, you may need to adjust the needle position to the right or left so the needle will not hit the presser foot when stitching.
1helpful
Model 930.Why is presser foot not lined up correctly?
Is your needle position centered? The round dial on the top right is a combination zig-zag stitch width selector and the center silver dial selects the needle position. If it is pointed at the #2, then the needle should be centered and something (probably the needle bar) has been knocked out of alignment on your machine (which would probably mean repair service).
Also, if the needle is hitting the presser foot, you probably have a straight stitch foot on your machine which requires the needle be centered. To do any decorative or zig-zag stitching, the presser foot needs to have a wide space for the needle to swing back and forth. The zig-zag foot is marked with a zero.
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=4&ved=0ahUKEwiP-OL76L7JAhWG9x4KHZ-6AgsQFghDMAM&url=http%3A%2F%2Fberninainstitches.com%2Fpdfs%2FBernina_Presser_Feet_Guide.pdf&usg=AFQjCNFihfp9MHOUl_6HmXxRrC8t3N32TQ&cad=rja
My left needle keeps breaking
Could be: Wrong needle size for fabric: The presser foot is not the correct one for the type of stitch you want to sew: The needle clamp screw is loose. Hope this helps.
2answers
Using my Bernina 440 qe in the embroidery mode needle is hitting the foot.Worked fine yesterday, today I have broke 3 needles.
could you possible have attached a foot that is not the correct one for your Bernina one that is a smaller mm
Needle not lined up with hole in presser foot
Is it also hitting the needle plate? if so then you need to move the arm the adjustment is internal and you\'ll have to disassemble the clam shell case of the machine. May be best to have a pro fix it for you.
Needle not aligned with hole in presser foot
Hi if the needle is hitting the needle plate you best get in touch with who you bought it from, The needle position is a critical adjustment and is done in conjunction with other adjustments.
Top Husqvarna Sewing Machines Experts
ZJ Limited
ZJ Limited
Sean Wright
Sean Wright
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
