Question about Xerox Phaser Office Equipment & Supplies
Reset xerox phaser 5550
Phaser 5550 maintenance counter
ironman844
    New Friend:
  • 44 Answers
To reset the maintenance counter (assuming it is the maintenance kit you need to reset)
1. From the Main menu, select Information, then press the OK button.
2. Select Supplies Info, then press the OK button.
3. Select Reset Fuser Life, then press the OK button.
4. Select Reset Fuser Life NOW, then press the OK button to reset the fuser life.
Posted on Aug 05, 2014
5 Related Answers
Coss
  • 1056 Answers
SOURCE: how to reset drum counter for fuji xerox 203A
if the Drum LED is still lit after replacing the drum unit, the Drum counter may not be reset.
Reset the Drum counter as follows:
  1. Open the front cover.
  2. Locate the control panel button under the LED lights on the left side.
  3. Press the control panel button until all lights are lit, then release it.
    The Drum counter is now reset.
Posted on Aug 28, 2008
Anonymous
  • 117 Answers
SOURCE: XEROX Phaser 8560 - Maintenance Kit
They sell a lot of maintenance kits that way.I worked for a major Tampa are copier company for 10 years and they used every part until it just quit.However, you should line up a maintenance kit at the ready.Sometimes a counter will shut down the copier when it gets to the point where they want it to stop.
Posted on Apr 07, 2009
Anonymous
SOURCE: how to reset maintenance counter on a Dell 5310
1. Turn off the printer.
2. Press and hold (check) and .(right arrow).
3. Turn on the printer.
4. Release the buttons when Performing Self Test displays.
The message CONFIG MENU displays on the top line of the operator panel.
5. Select Reset Maintenance Count from the Configuration menu.
6. The message Reset Maint Cnt=Reset displays momentarily. Press (check) to reset.
When the reset operation is complete, the menu returns to the Printer Setup Reset
Maintenance Count Screen. Scroll down to the Exit Configuration Menu and Press
Select to Return to Ready status.
Posted on Jul 22, 2009
wrinaldo
Whit
  • 185 Answers
SOURCE: RESET INSTRUCTONS FOR XEROX 8560 MAINTENANCE KIT
There is no reset. Xerox never designed a supply reset for this machine.
If you installed a new one, either 1) you've got a bad one (get it replaced under warranty) 2)
the chip is not being read (due to drum maintenance camshaft cracked and out of position
Posted on Jul 31, 2009
Anonymous
SOURCE: Lexmark x642e MPF Reset maintenance counter
Hi~
You can reset the maintenance count by going to the Configuration Menu.
Step 1: Turn off your X64x printer
Step 2: Hold the 2 and 6 buttons while the printer is off
Step 3: Turn on the printer but don't release the buttons yet. Keep holding those buttons for about 10 secs
Step 4: On your Operator Panel, you should see "Configuration Menu"
Step 5: Scroll down and look for "Reset Maint Count" and select it.
Step 6: Exit Config Menu and powercycle your printer (turn it off then back on)
Hope this is helpful... =)
<<ichtuscheeky>>
Posted on Sep 11, 2009
How do I Reset the Maintenance Kit Life count on a Xerox Phaser 6360
Your just not meant to.
Fit genuine Xerox parts and have no further problems.
Good Luck.
Jul 17, 2014 | Xerox Phaser 6360DN Printer
Xerox 8860mfp how do I reset the Maintenance kit counter until a new one arrives
It cannot be reset at all.
Xerox makes you buy a new one, either 108R00675 or 108R00676
Whit
Item, Inc.
Dec 14, 2009 | Xerox Phaser 8560MFP Laser Printer
Phaser 8560 warns to replace the maintenance kit
Call Xerox. If they can't reset it, They will sent you a new Mtc kit. Thay will want that count sheet. Plus, They will not warrenty any kits over 6 months.
Sep 26, 2009 | Xerox Phaser 8560MFP Laser Printer
Apr 07, 2009 | Xerox Phaser 8560MFP Laser Printer
The maint kit resets the counter when it is installed. You may have gotten a bad maint kit or the black plasstic part that the roller slides into is bad. That is where the connection is to reset the counter.
Harry
Mar 18, 2009 | Xerox Phaser 8560MFP Laser Printer
Reset page count
Hi bseema:
Hope that this helps you.
Resetting Fuser Life
This procedure restarts the counter that tracks Fuser life. Perform this procedure after
you install a new Maintenance Kit.
To reset the fuser:
1. From the Main Menu, select Information, then press the OK button.
Oct 13, 2008 | Xerox Phaser 4500 Printer
Reset counter on Xerox Phaser 8200
I think the maintanance kit runs out based on time and usage, which ever comes first, roll back your printers clock a few months or more and see if that fix's the problem.
Oct 05, 2008 | Xerox Phaser 8200DP Thermal Printer
Xerox printer error
The answer can be found here: http://office.support.xerox.com/SRVS/cgi-bin/webcgi.cgi
You must manually reset the Belt Cleaner life after replacing the belt cleaner.
Resetting Belt Cleaner Life
  • Resetting the belt cleaner life is to be performed only if the Belt Cleaner Assembly was defective and or the assembly is replaced before an end of life or near end of life message. Not to extend the life of the assembly. Doing so may cause premature failure of other internal printer components.
  • The printer will prompt the user to reset the life counts if the assembly is replaced after receiving a Replace Belt Cleaner Assembly or Replace Belt Cleaner Assembly Soon message.
note_image33x30.gif    Note: If the main Menu does not appear on the front panel screen and only Replace Belt Cleaner Assembly is displayed, there may be a print job that is either processing or currently printing. Try the following steps to clear the print jobs and reset the Belt Cleaner life:
  1. Press the cancel button several times to flush processing jobs from the printer.
  2. If you do not receive access to the front panel menu by doing this, then power off the printer and disconnect Ethernet, parallel or USB cable from the printer.
  3. Turn the printer back on, and while it is powering up, immediately start pushing the cancel key repeatedly until you receive access to the front panel menu.
  4. If the printer menu appears on the front panel screen, follow the instructions below to reset the Belt Cleaner life if the printer didn't prompt you to reset it:
  1. With Menus highlighted press OK.
  2. Press the Down Arrow and scroll to Supplies Info Menu.
  3. Press OK.
  4. Press the Down Arrow and scroll to Exit at the bottom of the menu tree.
  5. Now scroll up to Reset Belt Cleaner Life
  6. .
  7. Press OK.
  8. Reset Belt Cleaner Life NOW is displayed.
  9. Press OK to reset the belt cleaner life.
Mar 08, 2008 | Xerox Phaser 7700 Laser Printer
Open Questions:
2,444 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
