Question about American Standard Cadet 3 Right Height Elongated Toilet by - ADA Compliant
How do I remove a stain bottom of bowl? Appears to be a defect in the product.
Cannot remove stain in bottom of bowl. Toilet is 5 years old. Beige in color but brown stain developed in bottom of bowl. Tried to clean with Clorox, or CLR. Does not work. Could this be a defect in the product?
2mikecurtis
    New Friend:
  • 71 Answers
You would have to determine what the stain is before an accurate answer on how to deal with it. Can you add a picture?
Posted on Aug 07, 2014
  • 1 more comment
  • Anonymous Nov 14, 2020
    l had the same problem and tried everything other people suggested the pumice stone did not work the Clorox and baking soda did not work but if you turn the water off at the bottom of the tank and flush and sponge out the excess water with a glove use a hand held hair dryer on the area and it slowly starts to break up you can then wipe it out and clean the bowl with soft scrub or Ajax’s
    This work for me with two toilets
    I think this is hard water buildups
5 Related Answers
djchillsnyc
charlie rodriguez
  • 152 Answers
SOURCE: have to flush 2 or 3 times to empty toilet bowl
hello, this is a standard toilet you will need to inspect the flapper that is the rubber flap that holds the water up in the tank it works when you pull the lever it pulls the chain upward and lets the water flow if this flapper is old it may not stay up long enough for the water to flow. open the tank top and flush the toilet see if this flapper is staying up long enough and giving the tank enough time to empty if not change this rubber flapper its inexpensive part.
if this is not the reason then you need to adjust your water filler valve there should be a small screw on top of the pivoting float arm
if you have to adjust it for the water limit line inside the tank this will be the proper amount of water needed to flush once completely
also check that the chain lenth on the pull lever is not pulling the flapper down quicker than its supposed to,
try this let me know your results
hope it helps
Posted on Dec 15, 2008
Anonymous
  • 35 Answers
SOURCE: American Standard Elongated toilet bowl water level slowly drops
The tank holding the proper amount of water is a good sign. The inside of the stool is like the GOOSE NECK under you sink. It always holds water. This may sound like a bit of a hassle to do but if all 3 toilets are identical, here is what you can try if you are a bit handy. Go to the hardware store and purchase 4 toilet wax rings with a plastic flange and a few sets of toilet floor flange bolts(they are cheap and you can always return if not used, as It is better to have xtra parts on hand). Turn off the water supply to the "Mystery Toilet". Leave the tank and everything connected to the stool. Flush the toilet and remove all excess water from the tank and bowl. This can be done with a shop vac, sponge or towel. Disconnect the water supply to the tank. Remove the bolts holding the stool to the floor and carefully remove toilet. Scrap off all the old wax from the floor flange and bottom of stool. Now go and repeat this proceedure to one of the toilets that is working properly. In other words Switch the "Mystery Toilet" with a "Working Toilet" and see how they react. If the working toilet does it in the same bathroom and the "Mystery Toilet" does not do it in the other bathroom then you probably have a VENTING PROBLEM. If the "Mysery Toilet" Does it in the other bathroom then you most likely have a Defective Toilet. This Job is best done by 2 people, as it can sometimes be challenging to center the new wax ring on the toilet flange. Reconnect to the floor and reconnect water supply to the tanks. DO NOT OVERTIGHTEN BOLTS to the floor flange as you may crack the toilet. All drain lines must be vented properly for water to flow. If you are curious check out drain venting on the internet. Also, sometimes a vent can become obstructed with debris, ice, bird nest, etc.. I would 1st check the vent on the roof visually and then have someone flush and listen. If you believe the vent is clear....Then do the toilet switch and go from there.....Hope this helps and Happy Holidays....Joe
Posted on Dec 21, 2008
Steve Darnell
  • 117 Answers
SOURCE: water leaks from tank to bowl till water level in the tank is jus
Yes. You will have to remove your tank from the bowl to replace the defective fill stack(the tube thing your flapper is attached to) it is not as hard as it seems.First remove water supply tube.Then remove the through the tank bolts. should be two of them. Lift off and turn tank upside down. remove spud gasket. Unscrew old stack. You should be able to get a universal kit to work with your tank and should come with all new parts including new flapper and spud gasket. You will need new through the tank bolts and note the sequence of assembly to get water tight seal on tank. Hope this helps
Posted on Aug 03, 2009
Amado Petallana
  • 320 Answers
SOURCE: I had an American Standard Cadet3 Right Height
Adjust the water setting of the tank to higher level, meaning an additional water will be added to the tank. The purpose of this is to release extra water that will fill the missing water level in the bowl.
Posted on Nov 10, 2010
Anonymous
  • 102 Answers
SOURCE: My toilet doesn't flush every
I think the problem with your toilet bowl is in the tank fitting of it..you better check if the fittings are proprerly working..You also check the flapper and also the fillvalve.
If it is not good already you can replace it by buying the tank fittings at the hardware store..And you better also be check it to your plumber for the second thought..
Posted on Jun 17, 2011
1helpful
I would like to know how to put the finish back on the bottom of the toilet bowl
might be just stained
get a good stain remover or drain cleaner and leave it sit for a while then flush
talk with a plumber as to possible solutions
Jul 22, 2016 • Home
How to fix toilet bowl stains
Force the brush tip back and forth, especially along the toilet jets (holes under rim), around the water line and on visible stains. Scrub until stains are gone, reapplying cleaner as necessary, then flush twice. To make your toilet bowl clean again, start with a dry bowl so water won't dilute the cleaner.
Stain removal
What type of surface is stained?
What type of product stained the surface?
Bottom of bowl is stained very much. Appears to be a defect in the the finish?
Try using one of these A product called Kaboom Bowel Blaster and let it sit in the bowl for a while, then brush clean. This worked for me when others failed. You can try muriatic acid as a toilet bowl cleaner.Again let it sit for a while then brush and flush available from places like Home depot.Sometimes the toilets are not glazed as well as they should be you might call it a defect I call it poor quality control.
I have an American Standard (right height) beig in color. Bowl has a large brown stain near the bottom.
Probably a mineral buildup. Pour a bucket of water into the bowl so that the bowl flushes but does not refill with water. In other words you want as little water in the bowl as possible so it wont dilute the cleaner. Use an acid cleaner like lime away in the bowl. Let it set for several hours or over night,. then scrub with toilet brush. Lime away is fairly safe but try not to splash it on your clothes or yourself. Wash it away if you do.
You may have to repeat to finish the job.
2helpful
3answers
How to remove rust from a toilet bowl
Take some Ajax and lightly rub it on the stain just hard to remove the stain. The main thing is you don't want to etch the porcelain..
Feb 05, 2013 • Home
How do we keep the toilet clean. I understand that you are not able to use bleach based products in the toilet - what else can we use?
Most grocery stores sell "pumice stone" this is a solid bar about 1" x 1" x 6" long. It is literally lava rock cut to this dimension. You use this to scrub the stains off the porcelin. Have used one for years, never hurt the toilet.
American Standard Cadet 3 Right Height Elongated Toilet by  - ADA Compliant Logo
Top American Standard Home Experts
Mike
john h
Ekse
Are you an American Standard Home Expert? Answer questions, earn points and help others
