PTO does not engage mower. Replaced the switch, no change
The electric clutch draws current while engaged. It is quite hungry on power which means that if the battery is low, the generator may not be making enough to charge the battery and hold the clutch in too. This is why the batteries on these machines are so large relative to say an ATV battery. I have several times experienced units with low batteries which started the engine OK but would not hold the clutch in. The battery may be getting old and not holding the charge. Try charging with a mains operated charger. Make sure to check water level in battery cells. Running them dry can ruin the battery.
SOURCE: problem with John Deere L120 tractor
Park brake switch is the most likely culprit,any other would cause the tractor to not turn over in the crank position.
