Question about Panasonic VIERA TC-P60GT50 60-Inch 1080p Full HD 3D Plasma TV
My panasonic plasma tv model#TC-P65S1 will not power up the led light blinks 8 times and failed to boot up
Posted by Lauro on
    Top Expert:
  • Panasonic Master
  • 76,416 Answers
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. Viewing it in "Mosaic" or "Magazine" will make surf easy.
Blinking codes details to many popular brand TVs are given. Surf the site with patience
Posted on Aug 02, 2014
5 Related Answers
Anonymous
  • 39 Answers
SOURCE: Panasonic Plasma TH-42PV500H goes blank on power up
RKUMAR-ALL BLINKING LEDS ARE DIAGNOSTIC CODES WHICH NEED TO BE COUNTED PER SEQUENCE AND REFERRENCED TO A PANASONIC CODE CHART,COUNT THE BLINK SEQUENC AND LET US KNOW.JOE TV
Posted on Dec 17, 2007
Anonymous
SOURCE: my panasonic plasma tv has some error! the red led
Panasonic sent a repairman out with the correct part after telling them about the seven blinks. The unit was out of warranty. They rock. Call 800-211-7262 or 800-524-1448 1
Posted on Oct 06, 2009
gripfitter
gripfitter
  • 557 Answers
SOURCE: Panasonic Plasma TV - Model # TH42PX77U does not
This is a difficult question to answer completely. 7 blinks indicates that one of the C boads has failed. however, there are several an SC,SD, SS and SU.
The procedure is to disconnect each of there boards until the blinking is eliminated. The labor charge is usually around 200.00 and the cost of whichever board is bad. Hope this helps.
Posted on Oct 21, 2009
Paul
  • 381 Answers
SOURCE: panasonic model #TH-50PX75U wont turn on, it
Usually seven blinks indicates a Y sustain problem. Its either the Y sustain pcb and/or the buffer boards. I would highly recommend calling an authorized service center for this if you don't know what you are doing.
Posted on Mar 09, 2010
Brian Crowe
  • 78 Answers
SOURCE: my TV just turned off and the power light flashes
thought I would post this here for everyone.
1 blink STV 5v sense DG Board
2 blinks 15v SOS D Board
3 blinks 3.3v SOS D Board
4 blinks Power SOS P Board
5 blinks 5v SOS D Board
6 blinks Driver SOS 1 SU / SD / SC Boards
(SC energy recovery circuit)
7 blinks Driver SOS 2 SU / SD / SS Boards
(SC floating voltage area)
8 blinks Driver SOS 3 SS Board
(SS energy recovery circuit)
9 blinks Panel Config. SOS
10 blinks Sub 5v SOS / Main 3v SOS DG Board
DTV 9v SOS / Tuner Power SOS
11 blinks Fan SOS PB Board
12 blinks Sound SOS H Board
13 blinks Communication error DG Board
with IC8001 (Pesks Lite 2)
Posted on Feb 26, 2011
Panasonic TV, Model TC-P505U50
Not sure if it is Plasma or LCD/LED model.
Check out the codes below
Panasonic TV Blink Codes for All Panasonic Models Brainchamber Blog
You need to verify the Power board for defective capacitors. You can replace the defective Capacitors yourself if you are a DIY person or replace the entire board if you can obtain the part.
Aug 01, 2016 | Panasonic Television Mainboard, TV Model...
No picture. TV blinks 8 times
I have come across 6 blinks; 7 blink and even 10 blinks.
the video below may throw some light. Not sure if the blink codes are universal across models. Panasonic plasma tv 7 red blinks of *****
Apr 02, 2016 | Panasonic Viera TC-P65S1 65 in. HDTV...
Panasonic Plasma TC-P42C1 10 light blink code, then the light came on and then no light at all-nothing! Power Suppy board?
By blinking led its shows where is exactly the complaint. You have to count the blinking. How much time its blinks in one sequence. the only it will be possible to say is it power supply or any other boards.
www.electro-medical.blogspot.com
Sep 03, 2015 | Panasonic Televison & Video
Panasonic Viera TC-P65S1 No Picture, Red Light Stays on for 10 Seconds then Clicks Off
Need power board. Unplug then Have to remove all screws on back. The big board that the plug goes to is power board. Get serial number and find on Amazon or Internet. Usually around 150$ replace. It is easier than sounds. Any time power will not stay on or will not come on it is the power board. Tics are now just like computers. If u can change a hard drive u can do this
Sep 27, 2014 | Panasonic Viera TC-P65S1 65 in. HDTV...
Tc-p65s1
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Aug 01, 2014 | Panasonic VIERA TH-65PV500 65 in. Plasma...
The screen is black and red light is flashing
check the number of blinks from the LED. that will tell you which board is bad.
Feb 10, 2013 | Panasonic TC-P65S1 65 in. HDTV TV
Panasonic VIERA TC-P60GT50 60-Inch 1080p Full HD 3D Plasma TV Logo
1,188 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Muntejaya Ginting
Muntejaya Ginting
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
