Lexmark Pro715 Wireless All-in-One Inkjet Printer, Copy/Fax/Print/Scan Logo
A
Anonymous Posted on Aug 01, 2014
Printer says Printhead Error 1 why can't I go pass setup?
Tried cleaning printhead and I can't get it to go pass error 1 message
pujahthemad
Level 1:
New Friend:
  • Contributor 32 Answers
  • Posted on Aug 01, 2014
pujahthemad
Contributor
Level 1:
New Friend:
Answers
32
Questions
0
Helped
7534
Points
88
It could be a cartridge problem, or perhaps something that can be resolved by a firmware update. I found this on Lexmark's site regarding the Pro series:
support lexmark com
1 Related Answer
Anonymous
  • 3344 Answers
  • Posted on Sep 24, 2012
Creating Customers For Life
    Verified Fixya Pro
    SOURCE: lexmark s450 printhead not moving
    Try to check for any obstructions inside the printer. Something could be blocking the paper path and the printhead from moving.
    Why will my printer not print. shows error 3802. just prints blank page. do have ink.
    Error: "Printhead Failure" (105-3802) - Kodak
    support.en.kodak.com/.../error%3A-printhead-failure-(105-3802)
    KodakAug 25, 2010 - How do I resolve the error message "Printhead Failure" (error code ...If you are not prompted to calibrate the printhead, turn off the printer, wait ...
    Error: "Printhead is missing, not installed correctly, or has ...
    support.en.kodak.com/.../error%3A-printhead-is-missing,-not-inst...
    KodakAug 25, 2010 - How do I resolve the error message "Printhead is missing, not installed correctly, or has come loose" (error code 105-3513) on my ESP or HERO All-in-OnePrinter? ... If the printhead and ink cartridges are not installed in the printer, install them: ... If the error continues, restart the printer and try to print.
    2answers
    Printhead error 2
    Oh boy,
    the last time this happened to me, I lost a rather good HP printer.
    I was not able to save it due to the ink drying on important componets.
    Sorry I have no constructive info for you, but I do wish you luck.
    HP Photosmart B210a error message
    Simple. Remove the ink and printhead. You can remove printhead by pulling gray latch up and sliding printhead up and out. Clean printhead gunk off using warm running water. Remove any ink gunk on the right side of printer if you see any. Turn printer off and on. See if problem went away. If it did, try putting the cleaned printhead inside printer again. If problem comes back, seems like the issue is with a bad printhead. Below are video instructions on cleaning head manually. The printheads are not same. B210 printhead is not the same with HP 6500, but instructions are same.
    If you need further help, I’m available over the phone at https://www.6ya.com/expert/alex_22751bbefa74c3d0
    Error 0x 19a0027
    Hi Norman,
    The Error message usually relates to Printer Failure. However you can try few steps to fix it. ( Hopefully )
    Turn off the Printer.
    1. Open the Carriage access door.
    2. Remove the Cartridges and Printhead ( Printhead is the part on which you install the cartridges )
    3. Lift the latch to remove the Printhead.
    4. Move the carriage from left to right 6 times and it should move freely
    5. Clean the contacts on the printhead with lint free cloth. ( Golden dots at back of Printhead )
    6. Turn on the printer and it should say " Printhead missing or not installed/Damaged "
    7. Install the Printhead and Cartridges and close the latch and close the Carriage door
    8. the printer should go through alignment process
    If this step does not fix, You may try calling HP customer support to check for better options/solutions
    HP Customer Care : 1-800-474-6836
    Regards,
    Sean
    1helpful
    HP 6500 ALL IN ONE DISPLAYS ERROR ON SWITCH ON Ox61011BED
    Hi Norman,
    Regards,
    Sean
    Printer head
    The error can be the result of firmware code, printer contacts or the printhead itself failing. There is a firmware update that addresses the "Printhead Error" on your printer. Please follow the steps below on how to successfully update your printer and provide information to the following questions:
    1. Open the cover to remove the printhead and tanks (if installed). You may go to http://bit.ly/klw9sJ to have a visual on how to remove the printhead. Note: Carrier will come to the center automatically with this error message as the cover is opened.
    - Remove the tanks and place on a table.
    - Open printhead latch and remove the printhead.
    - Close the printhead latch, close the printer cover, and confirm the error message goes away from op panel.
    2. Proceed with the firmware update. Please visit the Lexmark website to download and install the update. Click here to download an important firmware update for your printer. If more than one download is listed for your model, choose the first download in the list. If it is the wrong firmware level, an error message will tell you which firmware level is correct. Please indicate if the update failed or successful.
    3. If the firmware update software notifies that you have the latest firmware version, please inspect the printhead for the manufacturing stamp (http://bit.ly/vLvfCx ).
    a. Is the stamp on the nozzle plate side?
    b. Is the stamp on the contact side?
    4. Open cover, open latch, and insert printhead only.
    - Firmly push down on printhead then close latch and cover.
    - If error message goes away, continue with normal installation steps for cartridges.
    - If error message remains, open cover, remove cartridges, open latch, remove printhead, re-install printhead, close latch and install tanks cartridges firmly.
    5. Try to print a document again to verify that the problem is fixed.
    Please feel free to contact us at [email protected]
    2answers
    Lexmark c782 ps printer has printerhead error..108.10
    hi
    If this is the firsttime the error has occurred, try turning the printer off. Let it sit turned off for atleast 20 seconds before powering it back on. If powering the printer offand back on clears the error, continue using the printer but watchit to see if any printhead errors return. If your printer continues todisplay a Printhead Error message, make sure it is plugged straight tothe wall and not through a surge device or power strip. Power strips anduninterrupted power supplies can cause a low amperage problem in your printer.This can trigger a printhead error even if the printer has worked on this surgedevice for months.
    If theprinter continues to post a 930 Printhead Error, it thinks thewrong printhead unit is installed. If the printer was recentlyserviced, make sure the correct parts were used. This is especially true if theparts replaced were either the printhead unit or the printer's engine/systemboard. It is in one of these two parts that the printer is detecting theproblem. Note: If you are the personrepairing such a printer, please be aware that parts from different,though similar, printer models may not be compatible with this printer.Also make sure to check the laser cable going from the printer's engine boardto the printhead unit, as it reads that signal. If the printer was notrecently serviced before this error occurred and powering the printer off andon does not help, the printhead unit and possibly the laser cable or theengine/system board to this printer may need to be replaced.
    If the printer continues topost a 931 Printhead Error, it thinks there is an error in the signalgoing to the laser or the Hsync part of the printhead assembly. If the printer continues topost a 932 Printhead Error, it thinks there is an Hsync error occurringin the printhead assembly. If the printer continues topost a 933 Printhead Error, it thinks there is a failure in either theHsync signal or with the mirror motor unit of the printhead. If the printer continues topost a 934 Printhead Error, it thinks there is a "lock"failure with the mirror motor assembly within the printhead assembly. If the printer continues topost a 935 Printhead Error, it thinks the mirror motor unit within theprinthead unit cannot reach its operating speed.
    If powering the printer offand on does not clear any of these errors and it is alreadyconnected directly to the wall, your printer may require service. Itcould have a defective printhead unit or there might be a problem with theengine board or one of the printhead cables. Note:If you are the person repairing such a printer, check all of the cablesgoing from the printer's engine board to the printhead unit for any damage.Also check the continuity across these cables.
    It say it has a ink system failure error: 0xc19a0022
    An 'Ink System Failure' or '0x... ' error message displays on the printer control panel. The exact text of these error messages varies by printer, but they are usually preceded by the word 'Error .'
    Solution One: Reset the printer The error message might disappear after you turn off the printer and then turn it on again. After you make any adjustments to the cartridges or the printhead, reset the printer in order for the error message to clear completely. Follow these steps to reset the printer. 1.Press the Power button (c01602202.gif ) to turn on the product. 2. With the product turned on , disconnect the power cord from the rear of the product. 3. Unplug the power cord from the wall outlet. 4. Wait at least 15 seconds. 5. Plug the power cord back into the wall outlet. 6. Reconnect the power cord to the rear of the product. 7.If the product does not turn on by itself, press the Power button (c01602202.gif ) to turn it on. Solution two: Remove, clean, and reinstall the printhead If the previous solutions did not resolve the problem, the printhead might be installed incorrectly, or there might be ink or debris on the printhead electrical contacts. Follow these steps to check and clean the printhead. Step one: Remove the printhead
    1. Press the Power button (c01602202.gif ) to turn on the product.
    2. Open the cartridge access door.
    3. To remove each cartridge, press the tab on the front of the cartridge to release it and remove it from the slot.
    4helpful
    2answers
    Canon i860 error code 5200?
    5200 is a printhead temperature error, defective printhead You need a new printhead,
    QY6-0049-000 around $40.00
    1helpful
    Print Qued--No Print--Cartridge Error Problem--?Prinerheads?
    It sounds like you need a new printhead, with that error the printhead is defective. The printhead is BC21E around $40.00
    Top Lexmark Office Equipment & Supplies Experts
    Grand Canyon Tech
    Grand Canyon Tech
    k24674
    Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
