I would recommend calling RCA support at (800) 252- 6123 so they can suggest some troubleshooting steps you can take. If it is still under warranty and you're unable to get it working then you can send it back and get a replacement
My son put a 9 point lock on his tablet and does not know the unlock pattern. I have done the reset button so many times and need to get back to the factory settings. Can some one help me figure this out? It has been locked for 4 weeks and im loosing my mind trying to unlock it.
I had the same problem before, it may need to charge but, your charger might be fried from having it plugged in too long... purchase or find a new charger for your product
it depends.. check the battery pack maybe this cause a over charge and check first if your galaxy tablet is still part of the warranty this will help you a lot.
Try letting it have a full charge. Occasionally this is the problem with a black screen. If that doesn't work, call kobo. They should replace your lookbook with little trouble. Just be patient if you go this route, it takes around a month to get the replacement, and the replacement is a refurbished unit as a heads up. Personally, I was more than happy with my replacement. No more problems! :)
It sounds like your in sleep mode. Hold the power button till the display says power off and tap the power off on the display, the charging light will come on and the charging light will change color when it is fully charged. Here is the link to the pdf quick start guide: http://www.pandigital.net/userfiles/file/Downloads/QSG_%20PRD07T-1_v2.2_09-08-10.pdf Hope this helps thanks for using FixYa
