Question about Motorola Mobility HS850 Consumer Headset
Moto bluetooth HS850 WON't turn ON!
I have the HS850 Bliuetooth . It has been sometime since I have used it. The problem is it will not turn on it seems. The blue LED won't flash. It seems like it's not even charging. I have plugged it in and wiggled the connection around. Tried to pair it again with my MOTO RAZR cell and nothing happens. It's like the headset is dead. It doesn't do anything. I think it's possible that I need a new battery or a new charger. The manuel has no troubleshooting guide so taht sux. I wonder whats going on with this piece of crap? If anyone can help ....
Posted by Double on
  • 1 more comment
  • drewlad Nov 30, 2007
    my headset now is not turining on what will i do???
  • x MiG Dec 15, 2007
    when i first connect it to the charger the light stays on firmly then it turns off.. when i disconnect it.. it will not power on
  • Anonymous Mar 07, 2009
    Help!!!!!!!!
Anonymous
    Sergeant:
  • 316 Answers
I think your guess is right a new battery may be required but try leaving it on charge for 12hrs or so sometimes if they havn't been used for a long time they go dormant and it takes a realy good charge to get them going
Posted on Nov 08, 2007
Motorola hs850 bluetooth headset won't pair with g five mobile
How to place a Motorola HS 850 bluetooth headset into paring mode:
  1. Close the boom to turn the unit off.
  2. Hold down the call button until the blue light comes on.
  3. While holding down the call button, swing the boom open.
  4. (Now you can let go of the call button.)
The headset is now in pairing mode, and you can search for it using your phone. When it asks for a PIN, use 0000.
May 14, 2012 | Motorola Mobility HS850 Consumer Headset
I have a motorola hs850 and it keeps flashing blue and it cannot go into discoverable mode need some help thanks
How to pair a Motorola HS850 bluetooth headset How to place a Motorola HS 850 bluetooth headset into paring mode:
May 17, 2009 | Motorola Mobility HS850 Consumer Headset
Motorola HS850 N136 bluetooth won't go into discoverable mode. I press and hold the call button. The light turns blue for a second but then turns off. I am trying to get my cell phone to discover it.
open the boom (mic) right when it turns to solid blue!
http://www.motorola.com/consumer/v/index.jsp?vgnextoid=4507f7c0c1a0b010VgnVCM1000008206b00aRCRD&ps=y&pg=PG_TYP_00003&show=globalSupport&productID=e4e6e7af976c9010VgnVCM1000008206b00aRCRD
May 06, 2009 | Motorola Mobility HS850 Consumer Headset
Won't pair with Motorola HS850 headset
Apr 20, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
My N136 / HS850 Bluetooth
push once to turn it on, push it once to turn it off if its in the on mode,
hold power till it flashes red,blue over and over then its in discovery mode and all zeros is most likely the code for it.
Jan 23, 2009 | Motorola Mobility HS850 Consumer Headset
My hs850
Press and hold your power button for about 10 seconds, unitl the blue light starts flashing. Most people just push the button and think it will turn on, but you must hold it for a while and it will turn on.
Aug 15, 2008 | Motorola Mobility HS850 Consumer Headset
Can't get the HS850 to pair with my blackberry
Device is not bad blackberry has a compatibilty issue with this headset try plantronics brand go to www.n1wireless.com
Jan 08, 2008 | Motorola Mobility HS850 Consumer Headset
Blue tooth adapter and hs850 headset on my computer
Yes, you need the blue tooth driver. The one that comes with your blue tooth "toggle". Although my laptop said "blue tooth compatible" I still needed a toggle. They are fairly cheap to buy and go into a USB port.
Sep 17, 2007 | Motorola Mobility HS850 Consumer Headset
Motorola Mobility HS850 Consumer Headset Logo
386 people viewed this question
Top Motorola Mobility Radio Communications Experts
Dennis
sandyp4ever
sandyp4ever
Level 1 Expert
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
