I have a Toshiba photo copier machine that is wrinkling the pages randomly. we use this in a apartment complex to make applications and have every fifth or tenth page come out wrinkled is very annoying. so far we have had two people come out and look at it and no one and tell us for sure what it is.
SOURCE: Toshiba eStudio 163. Work out total pages Printed?
Press 0-8 button at once and then 257 then enter, 100% working I thing so
SOURCE: toshiba 2060 marks on papaer
There is no such paper for copiers that I know of in 18 years. What you can do is try to run some blank pages throw the copier. This can tell 2 things if the line gets lighter in may be in the fixing ***'y and the upper fusing roller is shoot, needs to be replaced and or if it dose not clear up you may need a cleaning blade for the drum(OPC) and or the drum and blade as a set. It depends on how old the parts are? You may need to replace all 3 items and a general cleaning. Here is a idea for you are you running LTR or LTR-R you may be able to switch the paper arould to avoid the line all togather. Good Luck.... You may need a service call on the copier. With the age of the copier I might just go with the cheap fix first.
SOURCE: Toshiba 850 e-Studio CD20 error
That code means the used toner motor is not running. That is pretty easy to emove and check. You have to take off the right 1/4 cover, normally held in with 2 screws, then remove the toner assembly, on screw on a bracket on top of the assembly and a spring loaded pin on bottom. Unplug the plug and set aside. You then remove 2 screws holding in the used toner assembly and unplug one more plug.
The moror on the top normally is the one that binds, you can try cleaning it and lubricating it lightly.
The recycled toner motor may be going bad. Possibly the auger is bound, and causing it not to run.
I have no clue about the toner you are using, But it is always best to use the toner designed for any printer. But that sounds like it is out of your control. Most of the times its like adding water to the gas tank of your can and then wondering why it doesnt run.
SOURCE: I have Toshiba photocopier, Studio
If you are printig labels you MUST use the bypass tray on the right side of the copier. You mst specify heavy or card stock/label paper so it will fuse properly. I can't tell you why the tray does not work? But labels must be run thru the bypass.
Good Luck and Thank You for using Fixya.
