Question about Samsung Galaxy Tab on 3 Mobile Tablet PC
Why wont my Samsung Galaxy Tab on 3 Mobile Tablet PC charge
It wont charge. shows the battery on screen but wont charge
daz bruce
    Problem Solver:
  • 16 Answers
Either your battery is shot as in dead or your charger is faulty
you could try to charge it using a usb lead in your computer or another usb port to see if that works , or try another charger to eliminate your lead /charger you are using
Posted on Aug 01, 2014
David Payne
    Top Expert:
  • Samsung Master
  • 14,162 Answers
just google it several videos on it. good luck.
Posted on Nov 10, 2014
5 Related Answers
reyjoshua07
Reynaldo Labaguis Jr.
  • 1157 Answers
SOURCE: SAMSUNG GALAXY TABLET NOT CHARGING OR TURNING ON
Hi buckpot2001,
To correct this issue, please follow the steps below.
1. Press and hold down the power button whilst at the same time touching the screen (you may have to wait up to 30 seconds as it clears the system).
2. You will then notice the battery indicator pops up.
3. The Tablet will then reboot. Everything goes back to normal.
4. If that fails to work, connect the power cable and repeat the above steps.
Hope it helps.
Thank you for using FixYa.
Posted on Aug 17, 2011
Meagan Quaid
SOURCE: my Samsung Galaxy Note 10.1 battery not charging can you please tell me why
mine still doesnt charge when it's turned off. it just vibrates sporatically. i had to get a totally seperate charger for my battery. it's stupid. so now i have to switch it out all the time
Posted on May 23, 2013
agc93
Alistair Chapman
  • 44 Answers
SOURCE: i cannot connect my samsung
If connecting the Tab to the computer with the cable and then correctly mounting the SD Card through Android (tap notification, follow steps) does not work, try a third-party app like On Air to connect over-the-air.
Hope this helps, Alistair
Posted on Mar 15, 2011
agc93
Alistair Chapman
  • 44 Answers
SOURCE: How do I know when my Samsung Galaxy Tablet is
The Tab takes quite a long time to charge (not sure why). Note that the Tab cannot charge from a computer USB port (only from the included AC adapter. When the Tab has finished charging, it should put out a notification (open the notification drawer by pulling down on the status bar) saying the battery is fully charged and to unplug the charger. Other than that, you would have to install a third-party app like Smart Battery Monitor (see here) and watch that to see when it is full.
peter4sons
Peter Uys
  • 5 Answers
SOURCE: why is there a red cross on the battery icon of galaxy tab though its fully charged?
I studied my galaxy note 10.1. when i use the original wall charger it charges well, fast an no red cross appears. when i hook it to the usb of my laptop then the red cross apears and the tab reports that it is not on battery ( look at the time on battery it does not change) the battery also remains at the same charge level that it was when i hooked it up. when i use the car charger it does the same as with the laptop. my conclusion is that when hooked to the car and/or laptop the battery does not charge, but the tablet is running of the power from the external source and not the battery. this seems to be a very clever move from samsung to preserve the battery when it cannot be charged by the device it is hooked up to.
Posted on Oct 23, 2012
Why wont my Samsung Galaxy tab 3 notcharge past 60%
The battery may be unable to charge to more than the 60% level.
Oct 07, 2016 | Samsung Galaxy Tab on 3 Mobile Tablet PC
How can I replace battery?
Not sure of your model and size..
however See; Learn and Decide using
Samsung Galaxy Tab 3 10 1 Battery Replacement
Choose the appropriate battery from ebay Galaxy Tab Battery eBay
Apr 16, 2016 | Samsung Galaxy Tab on 3 Mobile Tablet PC
I need help to fix my tablet that fell in the water this morning
Put it in a Tupperware container with rice in it for a week. Remove the battery if you can.
Oct 01, 2014 | Samsung Galaxy Tab on 3 Mobile Tablet PC
My Samsung Galaxy 3 Tablet wont charge
Have you tried a different charging cable?
Did you allow the battery to run down until it was completely drained?
- If so then try the following;
Watch this video (link below). You should only remove the back cover, disconnect and reconnect battery cable. Disregard the rest of the video as I could not find one doing ONLY what you would need to do. Follow the instructions to remove the back of the tablet then disconnect the battery cable(careful not to damage the circuit board), reconnect the battery cable, and replace the back cover. Connect the charger, within a minute the screen on the tablet will pulse/flicker which is good news, allow it to charge a while, turn on the device, turn off the wireless wifi, click the power button to turn the screen dark again, and allow to charge for another 6 hours or till fully charged (when not connected to wifi the background processes will affect the charge time, on a weak charger it may not even charge like from an usb port on a computer).
Again, you should only be concerned with the video up to about the 1 minute and 15 second mark. You only need to disconnect the cable then reattach it. ONLY DO SO if you are comfortable doing so. If you have never worked on electronics before or are uncomfortable find someone to do it for you.
Galaxy Tab 3 Battery Replacement and Screen Repair Disassemble and fix
Aug 01, 2014 | Samsung Galaxy Tab on 3 Mobile Tablet PC
Battery not charging
Are you using the charger that came with the tablet? If you are using a cell phone charger...it will not work. The tablet charger is rated for 2.1 A. Most cell phone chargers are rated for less than 1 A.
Mar 30, 2014 | Samsung Galaxy Tab on 3 Mobile Tablet PC
My tesoar tablet showed charging for 3 seconds then that was it now it wont turn on it wont do anything
I have a hacker inside my Samsung galaxy 8 notebook, he controls my ph and I pad, how do I break the tracking link.
Mar 21, 2014 | Samsung Galaxy Tab GT-P7510MAVXAB Tablet
Samsung Galaxy Tab on 3 Mobile Tablet PC Logo
409 people viewed this question
Top Samsung Tablets & eReaders Experts
Eric Rotmil
Eric Rotmil
CoppellTVRepair.com
Are you a Samsung Tablet and eReader Expert? Answer questions, earn points and help others
