Sewing Machines Logo
A
Anonymous Posted on Aug 01, 2014
Why does the thread break on my sewing machine?
Toyota basic
Debbi's Sewing Machine Repair
Level 3:
  • Sewing Machines Master 7,365 Answers
  • Posted on Aug 01, 2014
Level 3:
Answers
7365
Questions
Helped
1744380
Points
19451
The top thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
8. Try a different spool or cone of thread
Bobbin thread breaks
1. There is a right way & wrong way to insert the bobbin in the case --when you insert the bobbin in if it doesn't stitch correctly turn the bobbin over see if that helps or bobbin case is not inserted correctly
2. Lint has collected in the bobbin holder
3. The bobbin is damaged & doesn't turn smoothly
4. Lower thread tension is two tight
5 Related Answers
snakehead
Henry Thomas
  • 1074 Answers
  • Posted on May 06, 2007
SOURCE: MACHINE COMES UNTHREADED
your bobin case needs to be tighten there is a screw on the case turn the screw to tighten .good luck.
Anonymous
  • 8 Answers
  • Posted on May 20, 2008
SOURCE: Bobbin thread breaks
Make sure your bobbin thread is turning clockwise as it sits in the bobbin case. There is a screw on the outside of the bobbin case you can turn with your thumb slightly to adjust tension. If you dangle the case from the thread and give it a light ****, it should move down slightly when doing so-an indicator of good bobbin tension.
seamer
  • Posted on Jun 07, 2008
SOURCE: my thread keeps om breaking i have juki lu1508n please help
try extending the looper just a hair. loosen the screw and pull past the stop just a fraction.
Anonymous
  • Posted on Jan 14, 2009
SOURCE: Upper Thread Breaks!!!
Hi, here are some reasons why the thread is breaking :-)
  • Threading is not correct.
  • Thread has a knot in it.
  • Thread tension is too tight.
  • Needle is bent or blunt or has a sharp eye.
  • Needle is wrong size.
  • Needle has been inserted wrong.
  • Needle and thread does not match.
  • Starting to stitch too fast.
  • Thread take-up lever has not been threaded.
  • Hope this helps.
    Anonymous
    • Posted on Sep 23, 2009
    SOURCE: thread keeps breaking on sewing machine
    Probably just the needle. Try turning it 180 degrees
    Toyota Overlocker SL3400D, 4 Thread Differential sewing machine. The blade not cutting thus needles keep breaking.
    Question edited for full 'make model (what it is).
    Question moved from Toyota Cars category to a Toyota Overlocker.
    There is some help in the link.
    https://www.google.com/search?q=toyota+sl+3400d+blade+not+cutting+properly
    2answers
    Breaking thread on Bernette sewing machine model 200B
    Is there too much drag on the thread?
    Please click the Comment link to respond.
    Why does the thread on my sewing machine keep breaking?
    Several possibilities. It could be the needle, the tension too tight, mis-threading, the thread weight, brand, poor quality, or fabric incompatibility with needle & thread.
    Sewing Machine Problem 1 Thread Breakage
    Sewing Machine Thread Keeps Breaking
    Why Does My Thread Keep Breaking While Sew
    All About Needles
    Why the thread cracked with when i sticked with the machine
    Thread breakage could occur for several reasons.
    First, try a brand new needle.
    Second, use only good quality thread--NOT old thread or bargain bin varieties.
    Third, when threading the upper thread, be sure to ALWAYS RAISE the presser foot throughout the threading process.
    Verify that the thread path is correct (consult the owner's manual). Incorrect threading will usually break the thread.
    Check that the upper thread tension is set at the midway point between the high & low numbers.
    Why Does My Top Thread Keep Breaking Sewing Machine
    NMSU Checklist of Common Machine Troubles
    I have a Toyota RS2000 sewing machine. The thread has suddenly started breaking, and I am getting big bundles of thread under the fabric. What is wrong please?
    try a top thread tension of 4
    change to a new needle
    clean under the needle plate & in bobbin area for lint or loose threads
    also rethread machine top thread & bobbin just incase thread is catching somewhere
    make sure the thread doesn't come off the thread take up lever
    check to see if there are any burrs on the needle plate or the bobbin
    2answers
    Thread Breaks
    Dear Sir / Madam, please get your book out and follow the threading instructions very carefully. I am certain that is your only problem.
    Kindest Regards,
    Cookey.
    Thread is going on cutting.
    you do need to provide more details.  start here - get a fresh spool of high quality all purpose thread such as Coats and Clarks or Metrosene thread, fill a fresh bobbin, install a new size 11 needle.  Follow the threading instructions even if you've threaded the machine a million times, read the instructions again.  try sewing on some basic cotton fabric.  You'll be able to determine if it's the machine.  Breaking thread can be the thread (it does get too old and fragile), the needle, the incorrect needle for the fabric, the wrong thread for the fabric, and a host of other things.  So try that and tell us more if that doesn't work.
    Top Sewing Machines Experts
    SmartAviator
    SmartAviator
    Are you a Sewing Machine Expert? Answer questions, earn points and help others
