Question about Kodak ESP 7250 All-in-One InkJet Printer
3523 kodak NO PAPER JAM CAN'T CLEAR CODE WHAT DO I DO?
Terry Hair
  • Kodak Master
  • 4,134 Answers
There may be a dirty sensor in the paper path...but most likely there is a tiny piece of paper still jammed somewhere that is difficult to see or access.
Posted on Aug 02, 2014
4 Related Answers
ROD GANDY
  • 1602 Answers
SOURCE: kodak printer will not print on vellum paper
THIS IS TRUE OF ANY TYPE OF PAPER, MOST MANUFACTURE RECOMMAND THERE OWN BRAND OF PAPER FOR SPECAIL USES OF THERE MACHINE AND IF YOU USE A GENERIC TYPE OF PAPER YOU WILL HAVE THIS PROBLEM, PAPER WILL NOT PICKUP, PAPER MAY JAM ALOT, PAPER PRINT QUILITY MAYBE BE POOR, INK MAY MEER, TOMERS ARE SOME OF THE PROBLEM TO ALONG WITH PAPER ISSUES ALSO, YOU MAY HAVE TO USE A THICKER OR THINNER VELLLUM PAPER, CALL A REPOGRAPHIC STORE , ONE DO BLUE PRINT PRINTING, MAP COPIERS, ASK AND SEE IF THEY HAVE ANY OTHER IDEAS
ROD THE CANDYMANGANDY
Posted on Feb 02, 2009
Anonymous
  • 8 Answers
SOURCE: How do I clear a paper jam in the Kodak ESP-3
If you have tried the Kodak standard instructions for clearing the paper jam problem and it did not help try the procedure below. Works for esp 7.
1. Open the printing area of the printer (containing the ink cartridges).
2. The Ink cartridge holder should be to right side of track.
3. Look on left side, below the track for the cartridge that is used to
clean the print heads.It can be identified by a square black pad
approx. 1" sqaure that appears to be made of "felt".
If it is visible this is most likely your problem.
4. To correct problem locate the flat latching lever approx. 3/4" wide that
sticks up about 1/2" above the cartridge. It is locacted just behind
the "felt" square. Gently push lever toward rear which should free the
cleaning cartridge and allow the entir cartridge to move slightly
backward.
5. Close the top of the printer and cycle the printer off and back on.
If this is the problem, the "paper jam" error will now be gone.
This is such a simple fix I do not know why kodak does not inform
customers of this problem and how to fix it.
Posted on Mar 05, 2010
Joed911
JDTec
  • 4338 Answers
SOURCE: How do you get the
Remove and inspect the paper tray.
CAUTION: Do not place the printer on its top or right side when you remove the paper tray. Ink could possibly leak into the printer and cause damage.
  1. Turn off the printer.
  2. From the back of the printer, disconnect:
    • power cord
    • USB cable (if used)
  3. Turn the printer on its left side.
  4. Open the paper tray.
  5. From the bottom of the printer, do the following depending on your printer model:
  1. Check the paper tray for the following:
    • surface scratches
    • bends
    • ink contamination
    • broken parts
  2. If the paper tray is broken, contact Kodak to order a replacement, otherwise do the following:
  3. Install the parts that were removed in Step 5.
  4. Place the printer upright.
  5. Connect:
    • power cord
  6. Turn on the printer.
  7. Make a print to check the functionality of the paper tray.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Posted on Mar 18, 2011
Rick Saulnier
SOURCE: cannot clear error code 3523
Had the same problem error 3523 that would not clear. Tried Kodak support with no results so took matters into my own hands.
Noticed the top tray seemed jammed into the printer. Tried pulling it out but it seemed locked. Flipped the printer over, removed 8 screws, 4 metal plates.
Removed bottom tray, set aside. Remove 3 screws for plastic bracket that holds top tray. Move bracket over, be careful not to damage wires. Remove top tray and reinstall so that it is in extended position. There is two notched in the side of the top tray. Extend so that catch is in back notch.
Reassemble everything in reverse order. Take care that the top tray does not slide into the printer when you turn the printer over. It did for me the first time that the tray jammed again.
Replug everything and startup the printer with top tray extended past bottom tray. The printer will tell you that top tray is jammed, push top tray flush with bottom tray.
Printer now works. Don't know why tray jams in the first place but this solution can keep you from scrapping printer or paying for service.
Very disappointed with Kodak printer. Obviously printers were not their core business and they paid a sub-contractor to build these products for them. My next printer will be an HP.
Posted on Jul 21, 2012
81 01 error
Paper-Axis shutdown - usually a paper-jam caused by a blockage of the
Paper-axis System.
Action- Try the following= If this error code was caused by a paper-jam, unplug the power cable from the printer and clear the blockage. Plug in the power cable again and check if the Error Code has disappeared
-If this error code appeared but was NOT caused by a paper jam,
replace the Paper-Axis Motor Drive Assembly
Jan 14, 2014 | HP DesignJet 500ps (42 in.) InkJet Printer
4TH LIGHT FROM THE TOP KEEPS COMING ON LEXMARK E232
What this light sequence means that the printer has a paper jam.
When a paper jam occurs, the printer stops and the operator panel's Paper Jam light and Continue button lights come on. Press and release Continue twice quickly to display the specific secondary error paper jam light sequence.
How to clear Paper Jam
Press Continue button twice quickly to see the secondary error code.
To get the secondary error codes
When the Error light (!) and Continue button lights are both on, a secondary error has occurred.
When the Paper Jam light (4th light) and Continue button lights are both on, a paper jam secondary error has occurred.
Press and release Continue button twice quickly to display the secondary error code light sequence.
Press Continue button to resume printing once all the jammed pages are cleared from the paper path.
We recommend that you clear the entire paper path when a paper jam occurs.
To clear a paper jam:
1 If you are feeding paper from a tray, remove the tray, and then remove any jams.
2 Open the front cover and remove the print cartridge assembly.
NOTE: Do not leave the print cartridge assembly exposed to direct light for an Extended period of time. Extended light exposure can cause print quality problems.
3 Remove any jams in the area behind the print cartridge assembly.
4 Lift the flap at the front of the printer and remove any jams beneath the flap.
5 Open the rear exit and remove any jams.
6 After you have cleared the jams, reinstall the print cartridge assembly, make sure all printer covers and trays are closed, and then press Continue button to resume printing.
NOTE: The printer reprints the pages that caused the paper jam.
Jun 30, 2011 | Lexmark E232 Laser Printer
I cannot print or copy . i see error 51
Error 51 is a paper jam code. Remove the paper tray in the front and the jam clear cover in the back (the light gray plastic piece in the center of the rear of the printer) and pull out any paper you can see.
Once you've removed the paper, the jam code should clear on the display, but if it doesn't, try resetting the machine. If the jam code is still there, that means there is still paper somewhere inside the machine. Check again to make sure you didn't miss any, and also lift the scanner bed to see if you can see any paper under there. (To lift the scanner, lift up with the tabs on either side until the scanner locks into place.)
Jun 03, 2010 | Brother Multi-Function Center MFC-240C...
I have an Intellifax 2820 and there is an error message of paper jam inside... I have cleaned all paper out of machine... please help me
A jam sensor may be stuck by a paper scrap. Try manually pushing a sheet of paper through the machine IN THE DIRECTION IT IS NORMALLY FED. This may force out any stuck scraps. The jam sensors are usually located where the paper feeds and where it exits the machine. Also, make sure ALL ACCESS PANELS YOU OPENED TO CLEAR JAMS ARE CLOSED PROPERLY. Otherwise, the jam code will not clear.
Nov 25, 2008 | Brother IntelliFax-2820 Laser Fax
Paper jam in xerox copier 5328
Specify the area of paper jam or the code on display that cud help isolate the problem quicker, it cud be a C or E code. Try to clear it with code 20 subcode 03, but state code on display
Oct 30, 2008 | Office Equipment & Supplies
Says paper jam but there is nothing in there
Can you tell me the jam code (if any), or where it is saying it is jammed?
Jan 10, 2008 | Brother MFC-8660DN 5-in-1 Laser...
I860 False Paper Jam Message
Check the back of the printer. There should be door at the bottom. Your paper jam could be there.
If this helps you, please rate me. Thanks, Patty
Nov 06, 2007 | Canon i860 InkJet Photo Printer
How do I clear misfeed.
In most cases where the machine says there is a jam, and there is no paper in the paper path, it's because the paper never got out of the paper drawer and didn't reach the 1st jam sensor. If you can open the machine and it resets, then chances are the paper feed roller is either slipping or in some cases not turning at all. If you can't clear the jam by turning off the machine, and back on, then you have a bad jam setect sensor or perhaps a small piece of paper lodged on the jam sensor. This will take some additional troubleshooting on your part. Need to know if the jam indicator goes away when you restart the machine. Let me know and I'll try to guide you from that point. Aloha, Bill Monroe
Sep 17, 2007 | Ricoh Aficio 1018D Copier
Kodak ESP 7250 All-in-One InkJet Printer Logo
867 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Muntejaya Ginting
Muntejaya Ginting
efs_perpends
efs_perpends
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
