I setup the AVR X1000 and used it for about 3-4 hours. Next day, it started going into protect mode. I have unplugged all speaker/HDMI connections, reset the micro, but it still goes into protect mode. I don't have access to a Denon service rep, but a local technician inspected it and mentioned that the OUTPUT is correct, but the DSP area is failing. Unfortunately he doesn't have the service manual (that lists the output parameters, voltages of individual components), so he cant troubleshoot the culprit. Any help or pointer to resolve this will be greatly appreciated. Thanks!
If you used it for only 3-4 hours before the problem occurred then you should have a replacement warranty on the product.
I think you have already done the factory reset procedure shown on page 175 of the user manual.
Is it possible to take it to the place you purchased it from. Alternatively check the Denon website and find out who the closest agent is in your locality. Send it back with proof of purchase using a courier service that you can track for receipt. Hope it turns out well.
http://assets.denon.com/DocumentMaster/us/Owners%20Manual%20-%20English_AVR-X1000.pdf
Denon
SOURCE: Denon AVR-810 going into PROTECTION mode
It sounds like there is a problem with the differential circuit. The bias I am not sure about, as every unit is different. You should get the service manual to be sure or call Denon and see if they can give you an idea. Good Luck
SOURCE: Setting Up New Denon AVR-588 / Adding Sony DVD with Component Video cables
Make sure you have receiver switched to proper input as coax rather than digital
SOURCE: no HDMI video output from AVR-588 receiver to plasma TV ???
You can also use a digital coax cable (color orange) to go into coax 1 for DVD coax 2 for cable box. Just make sure to set the coax in input settings. The coax cables are a little cheaper than the optical cables and work just as well.
SOURCE: Cant Access System Setup on Denon AVR-588
Are you connected with video cables to a tv or "monitor" this is more than likely were the setup is visible for speaker configuration, input assignment etc, most denon receivers work this way so I would suspect you need to re-check the video connection until a set-up picture appears.
SOURCE: connection problem with HDMI cables on Denon AVR-589
Hi dmsgolfer22,
If your Time Warner Cable box is old enough that it has a DVI output it may have HDCP (copy protection issues) with the receiver. If you are having to use a DVI to HDMI adapter to connect to your receiver (output from Cable Box to input on Receiver) then it's very likely your cable box may have may not output the signal because it detects the HDMI repeater in the receiver.
The two best options to correct this are:
1. Connect the DVI to HDMI cable directly to the input on the TV, you lose the convenience of the video switching in the TV, but it will solve the problem. Then connect the digital audio output from your cable box to the receiver, although you've probably already done this.
2. Contact your cable provider and check into the possibility of them swapping out your cable box for a newer model that would have an HDMI output. This would be the best option since the HDMI output on the cable box would give you both the Digital Audio and Video through a single HDMI cable.
Let me know how it works out for your, or if you have any questions.
Matt @ OneCall
www.onecall.com
twitter.com/onecalldotcom
