Jabra Stone BT350
Not sure if you have provided the correct model. You need to pair the headset with the corresponding mobile phone and then accept the calls.
Refer this table on the link and select the correct Jabra model and the mobile phone model and you will find the correct instructions.
Bluetooth Pairing Guide
SOURCE: Jabra BT350 Bluetooth Headset
This is what I did:
1. open the headset by following these steps:
http://www.instructables.com/id/Jabra-BT-350-Disassembly-and-Repair/
2. measure the voltage of the battery. If it is too low, the internal charger circuit may not like it. Mine was 2.6v.
3. Charge the battery "manually" by connecting to 3 serially connected rechargeable batteries (final voltage should be around 3.7v). Three NiMH AA batteries are fine.
4. Reassemble and hope your headset is back to business.
SOURCE: Jabra BT350 stopped connecting
BR, I had the same problem with my BT350 and my Razr V3c. I was finally able to resolve the problem by doing the following:
- delete BT350 from device list on Razr
- start Razr looking for device
- put BT350 in pairing mode while phone searching (hold answer button till solid blue light)
- phone will detect BT350 and retrieve name
- select Jabra BT350
- say 'yes' to bond with Jabra BT350
- enter passkey - 0000
- phone will connect with Jabra BT350
SOURCE: How to hook up a Jabra BT350 bluetooth
Make sure your cell phone's bluetooth is activated. Once you do that, you should be able to hold down the main button on the Jabra and once it turns on, it will connect with your phone.
Also, go to this site for Jabra. It links directly to the manual.
SOURCE: jabra BT350 bluetooth
While the headsetis off, press and hold the power button for 6 seconds. It will first blick the light in several patterns, all in blue. Finally, it will come on solid blue, no blinking. It is now ready to be paired. Once your phone/PDA has detected it, the passkey /should/ be 0000, as in zero zero zero zero. That should do it. Best of luck! :-D
