Mitsubishi Electric Mr Slim E12C26426 Replacement Remote KM07K Logo
A
Anonymous Posted on Aug 01, 2014
Why is my mr slim a/c tripping the main C.B. on start-up, but not every time.
Cris Sparks
Level 2:
Sergeant:
  • Expert 338 Answers
  • Posted on Aug 02, 2014
Cris Sparks
Expert
Level 2:
Sergeant:
Answers
338
Questions
0
Helped
87146
Points
819
Try washing the outside coil with a water hose to see if its kicking out on high pressure and tripping the breaker. Clean the coil well with a spray nozzle.
2 Related Answers
Anonymous
  • 828 Answers
  • Posted on May 22, 2008
SOURCE: Mitsubishi Mr. Slim M/N MSH15EN
Try calling G A Larson's for technical advice. I think that they handle this product. 499-0866
Anonymous
  • 43501 Answers
  • Posted on Aug 20, 2010
SOURCE: MMy Mitsubishi Mr. Slim Air conditioner is
Here is where you can find all the info you will ever need about Mitsubishi Air Conditioning units...
Check out this tip that I wrote about that...
Mitsubishi Air Conditioner Troubleshooting and Repair
http://www.fixya.com/support/r5643983-mitsubishi_air_conditioner
heatman101
Power outage happened now power is on and no power to mr, slim .. main unit and wall mount no power ,, fuse box has no tripped fuses
Check the disconnect at the outside unit, little box on the wall. If not, turn power off and remove top to outdoor unit.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
heatman101
4helpful
2answers
Mr. Slim MXZ30TN Air Conditioner: Indoor unit blinks on and off what is the problem?...
continuous flash is frost prevention ...clean the filter & switch fan to high
flashes once every 2 sec could be room air sensor contact loose/short...call dealer
flashes 2x every 2 sec is indoor coil sensor contact loose/short...call dealer
flashes 3x / 2sec sensor contact problem, or compressor overload protection trip or gas leak...call dealer
CIRCUIT BREKER KEEPS TRIPPING
Your house wiring in not capable of powering the unit. Try a different location to plug in. Check the unit to make sure it is not faulty and will trip breakers because it is damaged.
Mr Slim unit "spits" water/dust mixture
some of those units are equipped with a condensat pump you could have a loose connection or a small crack in the line
Mitsubishi Mr. Slim breaker continuously trips
Sounds like you're on the right track. Might as well replace the , inexpensive, gfi while doing so. With power off make sure all connections are tight. Electrical tape is a wonderful thing. Good luck!!
2answers
Mr slim
41 amps is most likely a locked rotor in the compresser check on the tag of the compresser lok for LRA = Locked rotor amps) see what that reading says that is the first place to look also is it tripping the breaker or fused disconnect?
Top Mitsubishi Heating & Cooling Experts
 Mikey
Mikey
vince
Are you a Mitsubishi Heating and Cooling Expert? Answer questions, earn points and help others
