Good afternoon friend, thanks for the post!
I see from your post that your Frigidaire dryer is getting extremely hot on the top and back. Have you checked to make sure that it is getting proper ventilation? I would verify nothing is blocking your dryer from ventilating which could be causing the appliance to heat up. If it continues to heat up I would reach out to a technician to come diagnose and repair your dryer. I hope this is helpful. -Matt
SOURCE: Problem with my dryer
Heating element coil has shorted to the metal housing. This is usually caused by items like nails or other metallic objects (left in pockets) falling into the heater assembly. There should not be any continuity between the heater leads and the housing. Unplug and do not use until issue with heater has been resolved
SOURCE: frigidaire dryer is overheating
Sound like the limit switch on the dryer is faulty and needs to be replaced. Hoped this helped
SOURCE: back of dryer gets extremly hot!!!
put hand at the outlet to see if the warm air is freely coming out. if not there could be a blockage in a pipe inside or the propler fan on the motor has failed.
SOURCE: My Frigidaire dryer model FEQ332ES gets very hot
my dryer gets very hot on the outside what should i do
