Is it possible to upgrade a hisense flat screen tv to read more formats! i have a 32 inch led hisense tv and i downloaded seoson 10 of ncis of the internet and my tv does not want to read the format
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Firmware update procedure to many popular brand TVs are given with screen-shot details.
SOURCE: i need a new remote control for hisense tv flat panel, where can i buy one?
I've had very good with the Radio Shack Universal Remote. It recognized everything I had. Try that, because if it doesn't work, you can take it back for a refund.
SOURCE: need IR code for Hisense 32" LCD tv to program
Are you referring to the iPhone/iPad app? if yes then this is not a remote app, it's a management app made for Comcast boxes and nothing else it doesn't controls tv's.
If you are referring to the actual remote for one of the Comcast boxes then it all depends on what model of remote you have and the exact model of your tv - some will support it thru the use of a Daewoo or Samsung code, others don't.
So you have 2 options:
1 - you try every Daewoo and Samsung code you have in the manual and if that fails you do a code scan on the remote as explained in the manual:
Turn on your TV
Press the TV button on the top of the remote, then press and hold Setup until the TV light blinks twice
Enter 9-9-1 and the TV button will blink twice
Press and release 1 and the TV button will blink twice
Point the remote at the TV, press and release the Power button, then press the CH+ button multiple times until the TV turns off
Press Setup once to lock in the code and the TV button will blink twice
If even that fails - the tv doesn't shuts down - then the remote is incompatible to the tv so
2 - you get a remote that is compatible with both. The only one i could find is
http://www.logitech.com/en-us/remotes/universal-remotes/devices/6812
SOURCE: I have a 27 inch flat panel hisence tv.When you
Please help me find a DD3852 IC for my 27 inch Hisense Television I am in Kingston, Jamaica
SOURCE: New Hisense 55 inch LED TV does not have volume
Check its speaker. If it found OK, check and replace the audio output circuit board.
