Tascam 2488 Portastudio Multitrack Recorder System Logo
Question about Tascam 2488 Portastudio Multitrack Recorder System
Tascam tutorial why does the unit freeze up intermittently, usually after attempting to "premaster"? no buttons work, unit is on. shutdown, restart, no help. wait a few minutes, unfreezes and go again. Then freezes up again. help?
1 Related Answer
Anonymous
  • 4 Answers
SOURCE: Computer freezing while using Tascam 122l
I also have been having the same problem no matter what the sofware. Also I bought a gitar rig setup and got the same problm. So I have come to the conclusion that the asio drivers and usb guitar interface running with the music software ie Cubase Live ect are memory hogs and you must upgrade to 2 gigs if possible at least 1.5 gig. I have not done this yet to prove it out but intend to anyway. Probably the slower the cpu ( older) the more ram needed. If you do this and it works for you let me know please.
Posted on Jul 06, 2008
Reiniciar el equipo
Normal restart: select restart from the apple menu, or press the power key (the sleep/restart/shutdown dialog appears), then click the restart button or press the "r" key.
Forced restart (use only if the computer crashes or freezes): Press simultaneously the Apple, Control and power keys.
Forced shutdown (use only if the computer won't respond to anything, not even a forced restart): Press and hold the power button on the computer until the computer shuts off.
1helpful
I was using my recorder and it locked up. Nothing worked, I couldn't get any of the track arming buttons, transport buttons, the shutdown button, or the mute/solo buttons to work. the only thing that...
It sounds like the hard drive has failed... cheap test, get another and reformat the new one. They are so inexpensive now. To avoid losing data, they lock things up if anything goes wrong. The unit probably can't get the ready signal from the drive and freezes...
2answers
I want to erase all of my data on the tascam 2488
Register and download the manual for free at audio.manualsonline.com
Search for "Tascam Portastudio 2488"
http://music.manualsonline.com/manuals/mfg/tascam/2488neo.html
Chapter 7, page 45 talks about erasing partitions permanently.
4helpful
Media error 0 shut down displays when unit is
while the machine is off mode, hold down track edit and shutdown buttons. then power on while holding these buttons. an option to to reset will come up, let go of the buttons and select "yes".
This will reformat your entire hard drive, and you will lose any music you were working on, but it becomes operational again. Or you can send it in to Tascam and let them try to bring it back, if you don't want to lose any material.
Hope this helps :)
-Chenoa Desiree
2answers
I have a Tascam CD-01u CD player that has a CD that will not eject. It will play the CD, but only clicks a lot and displays "Error 2" wihen I attempt to eject it with the remote and/or the machine's face...
I have a Tascam CD-1u Professional that load's the CD and say nodisc once it is done loading. this unit dosen't seem to be reading the CD what is the problem
2helpful
2answers
How to chouse an out point when u press the pre master?
You have to choose your out point before entering premaster mode.
Use the transport keys to get to the point you want to end your mix and press 'shift' and 'set out' (mkI). For the mkII the end point is set by pressing the 'locate' key and the 'out' key.
2helpful
3answers
Tascam DP01 wont get past please wait screen
Usually an indication of bad sectors on the hard drive. This can be caused by bumping the unit when it is running, excessive vibration, a power failure while it is on, improper shutdown, or expoure to a strong magnetic field like having a subwoofer too close or an intermittent faulty power supply.
Your options are to return the unit (if it is still under warranty), or if not to open up the DP-01, remove the hard drive, connect it to a PC and perform a low level format (or take the drive to your nearest PC repair shop and have them reformat it).
Unfortunately you'll lose any data that wasn't backed up, but this should bring back your DP-01.
1helpful
5answers
Don't know how to Pre-Master or Burn to CD, please help me!
Don Q -
This answer assumes you have the 2488 mkI and not the newer mkII because the process may differ slightly on the mkII.
To premaster you first have to set an out point for the end of your pre-master (the start point is always zero). Go to the 'Audio CD' menu item and choose 'pre-master' under that. You'll see the word 'mastering' appear in the top left of the screen to let you know you've entered mastering mode. Make sure you have the tracks unmuted that you want to mix into the pre-master and have all of your eq, panning, etc set the way you want. Then hit record and play. The pre-master records to a stereo pair of dedicated internal tracks. You can redo the premaster as many times as you like which will overwrite those internal premaster tracks. You can clone the premastered tracks to a stereo pair of tracks, export them as waves or burn them to a CDR.
fnawesomewes - You have to press record and play to record your premaster.
Top Tascam Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
