Hello, I have an odd problem with my Pioneer DEH-P9800BT Headunit. When the unit is closed, the display screen does not work. But when I press the eject button, the screen works perfectly and the cd pops out. Any ideas what the issue could be? I recently pulled the stereo out because the tuner was not working great, I found that was a loose connection. Then this started...
Check the contacts on the faceplate are clean. Sometimes they get dirty and worn. Turn radio on and lightly push in in different areas on the faceplate to see if the screen comes on. There is a connection point on the faceplate and head unit.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/mark_b53a7494531bf96d
Clean all contacts chemically and check all wiring for good, tight connections.
SOURCE: Screen behind faceplate stopped illuminating/working
The ribbon cable has gone bad. A new one can be ordered direct from pioneer at parts.pioneerelectronics.com Good luck!
SOURCE: pioneer deh-p840mp
THERE IS A RIBBON CABLE THAT CONNECTS THE FACE PLATES TO THE RADIO THAT NEEDS TO BE REPLACED
SOURCE: OEL Display not Working on my Pioneer DEH-P7800MP
Sorry can't help, but if you can't fix it and would like to sell it, let me know. I need the parts for an audio project I'm working on. Email: [email protected]. Good luck anyways :).
SOURCE: Pioneer DEH-1100MP stereo no working
Is it older then a year? warranty or call18004211404. If your fuse is good check these. check you harness for a GOOD ground, check for power with a meter reader. For some reason on these units if your constant 12v and ignition 12v are both not hooked up it wont even do a thing. make sure both are connected. no loose connects?
