Question about PIAA 2000 Chrysler Town and Country - All Town and Country models - Xtreme White Bulbs
My 2000 chrysler town and country left rear brake light out
David
    Sergeant:
  • 470 Answers
Go to the part store and get a bulb a lightbulb
Posted on Dec 18, 2014
Left turn signal not working 2005 town and country
There is a plug type relay under your steering wheel that i believe is yellow ajust it then your blinker may work mine does it every once in a while
Apr 14, 2013 | 2005 Chrysler Town & Country
2000 Chrysler Town & Country Tail lights and dash lights won't work
If the brake lights and turn signal lights work, then there may be a bad fuse. Check the fuse box.
Mar 21, 2013 | Chrysler Town and Country Cars & Trucks
Rear brake lights not working 2005 chrysler town and country
check fuses but first refer to owners manual to see proper disconnection of battery neg. first -- obtain acess to brake lights and use dvom ''digital volt ohm meter '' to test continuity to brake lights
Dec 15, 2011 | 2005 Chrysler Town & Country
I have a 2008 chrysler town and country van. It has a warning light with a ! in the middle. In the upper left corner. What does that mean? Thanks, Brandi
that sholud be a brake light due to a parking brake engaged or not fully released it can also com on if there is a abs malfuntion or brake fluid is low. You need to get your brakes checked. If fluid is not low brakes are good and parking brake is not on you may need a brake switch.
Jan 24, 2011 | 2008 Chrysler Town & Country
Chrysler Town & Country Minivan Rear Drum Brakes
I replaced the brake pads on a '94 Chrysler town and country, I had the rotors turned also, I did not use any anti-vibration substance on the shoes. I hear a clicking noise from front brakes.
Apr 16, 2010 | 2005 Chrysler Town & Country
Front brakes wearing out on a 2000 town and country within 2 months. I have replaced both calipers but front brakes keep wearing out
Possibly your rear brakes not engaging? To my understanding that would put the entire load on the front brakes and cause them to wear out prematurely.
Apr 03, 2010 | 1996 Chrysler Town & Country
Brake lights not working
BRAKE LIGHT SWITCH LOCATED ABOVE THE BRAKE PEDAL
Jan 13, 2009 | 2000 Chrysler Town & Country
Fuse box chrysler town and country van
2002 town and country uses a relay and fuse...check fuse # 10 (a 40amp) in the box under the hood. the relay is also there
Dec 21, 2008 | 2002 Chrysler Town & Country
PIAA 2000 Chrysler Town and Country - All Town and Country models - Xtreme White Bulbs Logo
Top PIAA Optics Experts
 Mikey
Mikey
Lawrence Oravetz
Vernon Taylor
Are you a PIAA Optic Expert? Answer questions, earn points and help others
