this is a diferent radio the problem is inside the radio if this is the am/fm/cd/tape radio
take radio out open the radio next to the cd left side there is a small board on screw in back of the radio to remove put it on a table and resolder the resistors there is 4 or take them out and clean them no need for new ones this is the power suply board and it runs very hot
I have the same problem and not just with the FM tuner. I have spoken to Aluratek about the sluggishness of this radio. Their reply was to not push the buttons ore than once. The radio will eventually work.
Press and hold the Time/Frequency Selector button approximately 2 seconds until the time display begins flashing on the display panel.
Within 5 seconds after the time display begins flashing press the Manual Down Turning button (<<) to adjust the hours and the Manual Up Turning button (>>) to adjust the minutes to the correct time.
Five seconds after the last hour or minute adjustment is made, the time will be set in the unit and normal operation can resume.
Contact Audiovox.com or 1-800-688-3135 and they will email (PDA) or fax a copy of the manual.
other than just double checking your switches settings there really isn't much you can do ,as there really isn't any easy to replace parts inside and that would be cost prohibitive anyhow , but do remember it is a clock radio , if its set t o use the alarm the radio will not work and not the cd either , ck all your switches for proper setting , one may have got bumped by you or cleaning staff
this is the reason I use a sound bar/phone dock as I use it to charge my phone and play music all day at my desk , they only cost about fifteen bucks to buy , and best thing is there's nothing for anyone to mess with when im not there as it wont work without my phone docked in it !!
turn radio off, and press the "audio" botton until clock is displayed. then click it again shortly till you see "FM 100" on the display, press > (side arrow, now it should switch to "FM 50". long press on the "audio" to save and exit.
afterwards it should work fine.
