Our washing machine was turned on, filling, and didn't stop, flooded our home, and didn't stop even when we pushed the control button to stop. We had to turn off water supply for it to stop. What is wrong?
SOURCE: Washing Machine stopped through cycle and now will not turn on
Unplug!!! NOW! I drained the water using a common garden hose, fill the hose with water and have some device turning it off like a trigger nozzle on the low end. Detach from the supply and put the supply end in the center of the tub under the softener dispenser. take the trigger nozzle off and watch the water drain without cups and buckets. Then wring out the clothes and put them aside, use the hose trick again for remaining water. Now get under the washer and detach and reattach the brown and white lead input to the rinse cycle motor. She is made in France so be gentle. Plug the machine in and set the machine down and turn it on. Push the >> button until you reach the spin cycle if it starts you have fixed it!! Put the clothes back in open a bottle of wine and try again.
SOURCE: Water Just Keeps Filling!
replace the water inlet valve, the valve that the black hat and cold lines connect to
SOURCE: washer won't stop filling
Remove the pressure switch hose and blow into it. Is it hard to blow through?
In the bottom right rear of the outer tub there is an air dome where the other end of the pressure switch hose is connected. The air dome can become clogged and prevent the pressure switch from working properly.
Also inspect the hose for any cracks splits or pin holes.
To access the air dome remove the cabinet shell as follows:
I will skip console removal as is seems you already know how...
With the console lifted;
1. You will find a lid switch connector (white in color). Unplug the switch from the connector.
2. There will be two brass colored clips. Place a flat blade screwdriver straight down into the opening on top of the washer and into the groove of the clip. Push the screwdriver down and away from you and the clip will release.
3. Open the lid of the washer and place your hand under the front rim of the opening (DO NOT grab the wash tub). Tilt and slide cabinet forward to remove.
In the bottom right rear of the outer tub you will find the air dome.
If I can assist you further, please let me know
reg501
The FixYa Team
SOURCE: GE washing machine water overflowing
sound like the same washing machine from hell that we have. three or four times it has overflowed from want we have been told the hose that runs from the drum to on/off pressure switch cloggeds with soap. we have tried different soap,hot water,cold,water you name it we've tried it. so now evey time we use it we have to clean it with a coat hanger by taking the front off the machine.
P.S. take the hose off top and bottom to clean it, all it takes two/three very small soap bubbles to clogged it
