Fisher Paykel ActiveSmart Fridge - 17 cu. ft. Counter Depth Bottom Freezer with I Logo
n
neil robertson Posted on Jul 31, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Fix-ya I have a F & P E415H fridge freezer, the fridge works fine then warms up as bottom vent in back of freezer compartment ices up i defrost and it is ok for a could of days the the cycle repeats, how can i fix this? thanks Neil
scj103
Level 2:
Scholar:
  • Expert 104 Answers
  • Posted on Jul 31, 2014
scj103
Expert
Level 2:
Scholar:
Answers
104
Questions
0
Helped
71991
Points
240
Find the water drain hole/pipe and clean it thoroughly with a pipe cleaner or other softish flexible rod. That should allow the water to drain away. Make sure back of the unit is clear and clean so water drains and evaporates off properly.
Daewoo frsu20iai freezer builds ice at bottom and starts to defrost some items?
Try clearing all vents - inside (make sure vents not covered - in fridge and freezer) and outside (gently vacuum - the coil areas in the back and bottom of fridge)
Hotpoint fridge freezer ff200 tx displays error code A1?
These tempratures are pretty cold should be around 0 deg. but it sounds like you might have a bad defrost timer or defrost thermostat the frost should not come back if defrost system is working
Frozen water on bottom of whirlpool model evl181nxtq01
I assume that the water is on the bottom of the fridge compartment? It could be that the drain trough has blocked and every time the fridge does an auto defrost, water runs out onto the floor of the fridge rather than down the drain. Once the defrost finishes, the water will stay on the floor of the fridge. Cold air falls to the bottom so its possible to get a sheet of ice in the bottom of the fridge. Locate the drain trough in the back wall of the fridge. See if you can visually locate any blockages or carefully dribble warm water down the drain to clear it.
4helpful
Not freezing
Either the defrost circuit has failed or the refrigerant is low - my money is on the defrost circuit.
Most defrost circuits have three main parts:
1) defrost electric heating coil
2) defrost terminator
3) defrost timer.
The heating coil and terminator are in the freezer compartment - behind a protective panel. The heater is usually piggy-backed on the freezer coil and the terminator is in contact with the freezer coil to detect its temperature. The defrost timer is a simple assembly of a clock motor with switch contacts that can be located anywhere the manufacturer desires. The timer turns on or enables the defrost circuit every 8 or so hours for up to 30 minutes give or take.
When the timer has enabled the defrost cycle, the cooling mode ceases; the compressor shuts off and power is sent through the terminator to the heater. The heater warms and melts any ice build up on the freezer coil. The water drips to a pan and flows down the tube to a pan under the fridge - where it is evaporated off. The heater warms the freezer coil until either a) the timer returns to cooling mode or b) the terminator senses a preset rising temperature on the freezer coil. Once either condition is present, power is interupted and heating stops. The compressor is energized through the adjustable thermostat in your fridge. Since it is warm, the compressor turns on and cooling begins.
If any of the components listed above (1,2 or 3) have failed, the defrost cycle never warms the freezer coil and the ice never melts to clear the freezer coil as intended. Air can not be circulated through the freezer coil since it is choked with ice, so even though the compressor runs, the fridge and freezer spaces never get colder. The adjustable thermostat never sees the temperature you've set so the compressor never shuts off.
Water dripping in the fridge is melting ice from the freezer space - as the freezer is not getting colder - only the protected space around the freezer coil is.
To fix this, you'll have to get the service manual or schematics for the fridge to determine where the parts are located and do some troubleshooting with a multimeter after disassembling the freezer compartment and wherever else to access the timer if needed. This is not a good first appliance repair job for a DIYer due to the danger of refrigerant and testing live electrical parts in closed in spaces.
I hope this helps.
1helpful
FREEZER MAKING ICE, BUT FOOD IS THAWING
If you have a Freezer on the top model Kenmore, with warm temps in the fridge, AND water dripping onto the top shelf of the lower fresh food compartment (FFC), this is usually caused by a clogged defrost drain. Since Kenmore is not an actual manufacturer of anything, they take other brands, i.e. Kitchenaid, GE, Frigidaire, etc., take their names off and put on a shiny Kenmore nametag. This is a common problem with Kitchenaid refrigerators. You can determine if your Kenmore is made by kitchenaid by looking at the model # tag. the first three digits will indicate the manufacturer, Kitchenaids begin with the sequence, 106.*.If this is indeed how your model # begins, keep reading. Since the water cant go down the drain tubing to the pan at the bottom of the unit, it builds up on the freezer floor, eventually blocking the air return vents from the fridge to the freezer, and the vent from the freezer to the fridge. YOu can check this very easily. Look at the ceiling of your FFC, near the back. toward the sides you will see two square holes, about 2" square, stick your finger and feel around the inside of those holes, do you feel any ice/frost, or do you just feel styrofoam, you might even see frost/ice below the level of your ceiling? This drain usually gets clogged with defrost water that does not completely drain, then of course it freezes, eventually plugging up the drian hole located at the level of your freezer floor, behind the back wall. The water keeps accumulating, and freezing, on the freezer floor, eventually filling in and clogging the air vents..no air flow , the fridge wont cool. The easiest way to resolve this, empty out all contents and store someplace cold for 24 hours...a 2nd fridge, outside in a cooler if its cold like here in chicago. After its empty, unplug, open both doors and blow a fan for 24 hours. Prepare for an abundance of water due to melting ice.
After you defrost, you can plug it back in and it will be fine, HOWEVER, I suggest you take the back freezer wall off, you might have to take a floor cover off first, likely 2-4 screws in both the floor and the back wall. When you have the evaporator exposed, you will see a black cal rod defrost heater underneath the evaporator, as well as your drain hole just to the right of center underneath both heater and evaporator. Take a piece of 12-14 gauge solid, not stranded wire, removing the insulation and exposing the entire 6-8" piece of copper wire. wrap the wire around the diameter of the cal rod heater, 3-4 turns should be sufficient, and stick the other end of the wire down that drain hole. This will melt any ice that will build up in the future, everytime your unit goes into defrost cycle, so this wont happen again.
If air vents are clear of frost/ice, next thing to check is the back wall of your freezer, does there appear to be frost/ice/snow on the back wall? If so, your unit is not defrosting. On most Kenmores, this is usually caused by your defrost timer, located in the canopy mounted at the top of the FFC on Top freezer models, or your defrost thermostat, which is clipped onto the evaporator coil inside your freezer. Again, if its a 106 model Kenmore, this thermostat will have a pink and a brown wire coming into/out of it. My suggestion, if it isnt defrosting, change both. tjhe defrost control will connect with a plug, but you will have to hard wire the thermostat, ( cut wires from old, strip wire, and connect using wire nuts and electrical tape.)
Since y ou mentioned the water accumulation, more water recently, my diagnosis would be the former versus the latter, as the lack of actual defrosting coincides with lack of defrost water, however I'll never say never.
If your unit is a side by side model, check for ice on freezer floor...clogged drain. Check again for frost/ice on back wall, not defrosting, check same two parts, (the heaters rarely go bad on Kitchenaids, but never say never) You should also check for air flow into fridge, even if no frost / ice visible on back wall. Open the FFC door, and locate the air vent near the top, back of the fridge, on the left wall. While depressing the door switch, AND WITH THE FREEZER door closed, put your finger/hand near that vent. Do you feel any cold air? If you dont, you could have a bad door damper, not uncommon, or a bad damper control--> the temperature control WITHOUT the off or "0" position.
If any of this seems a bit overwhelming, I suggest you have a reputable repair technician check your fridge.
Oh, and lastly, you WILL NOT have two compressors, one for each compartment, nor will you have two sets of defrost heating elements, one for each half.
ALL cooling for 99% of refrigerators made in last 25 years takes place in the freezer, with the fridge being an empty box, except for an air intake vent, and an air exhaust vent which leads directly back into the freezer. When a refrigerator unit seems to still be cold in the freezer, but not cold enough or not cold at all in the FFC, its ALWAYS going to be caused by lack of air flow. But as you can see, there are a few things that can cause that lack of air flow.
Fridge/freezer. Freezer works great but fridge is
Air from the freezer is blown into the fridge by a fan, some new type frigs have electronic controls that open and close a vent to frig. the older ones have two vents in the frig from the freezer and when covered with frost or ice the air will not reach the frig. check for ice or just defrost the freezer if there is ice or frost, also check for food or plastic over vents in freezer. Also check that the freezer fan is running as these sometimes become blocked or defective motor.
Intermittent freezing and fridge warm
The ice builds up in the freezer compartment because the defrost cycle is not working. Check the timer , the defrost elements the defrost thermodise.
God Bless.
Jul 07, 2009 • Freezers
2answers
Freezer very cold, no air going into fridge it warm ANY SUGESTION
hi there,
check the blower fan inside evaporator,there is fuse on the back side of your refrigerator for cooling fan,check on this using multi tester if busted replace fuse.
1helpful
Hello, we have a three year old LG GR-359SQ Fridge freezer. Firstly, everything works fine with the unit but at the bottom of the freezer compartment is a 30cm x 30cm by 10mm deep trough that in a space of...
Try adjusting the levelers on the bottom I like to see 1/4 bubble on a level if you don't have a level no problem just so it slopes to the back. good luck Tom
Jul 02, 2009 • Freezers
1helpful
Sears Coldspot 17 frostless freezer not defrosting
One reason for the fan running is that it is trying to distribute the air in the compartment. Look at the very rear of the freezer on the bottom and see if the little vents, which allow water to disperse, are not filled with frozen ice. If so, turn off the fridge (unplug it) and use a hair dryer to melt that ice until it is all gone. That will probably fill the condensation pan under the unit and you'll need to empty it.
Top Fisher Paykel Freezers Experts
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Fisher Paykel Freezer Expert? Answer questions, earn points and help others
