Anon, Not a lot to be found for this camera, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info." Polaroid iS426 Camera Intro Review Polaroid Digital Camera Manuals
check the small hole of the microphone at the camera body if it is filled with dirt, clean it with a toothpick like things, do not insert much in. and don't use needle. still problem open, change microphone.
At some stage all digital cameras need a memory card as the internal memory will not be sufficient. Refer the instruction manual for how to select and install a memory card in the camera. You also will need instructions to make sure the camera can always save images and videos onto the memory card. Polaroid cameras use the SD card.
There is no built in speaker in Polaroid iS426 camera. You can play your videos when imports on your PC. So don't worry about that. Thanks Fazal Zahoor Bangash from Pakistan
