Question about Zanussi ZWF1450W Front Load Washer
Also cancels at start of some wash cycles. Drum never starts rotating
SOURCE: Zanussi ZWD1680W Front Load All-in-One... Problem:
With the symptoms you describe i would suspect a intermittent heater element fault as you are getting earth leakage current which is tripping the whole supply rather than a current overload which would just trip the socket circuit breaker. Get the heating element checked over first as this is the most likely cause.
Posted on Nov 04, 2008
SOURCE: wash cycle and spin
you need to check a simple button called " no spin" may you will see it marked "aspiral shap" and has "x" over
good work !
Posted on Jul 05, 2009
SOURCE: Zanussi zwf12070wi machine indicates cycle is
flashing red start/pause button, wont spin or drain
Posted on Nov 20, 2010
SOURCE: The washing mashine goes through
Hi If the spinning cycle works then the issue is with the Timer/control
going bad and should be replaced. Hope this helps...please post back with the manufacturers name and model no for
further assistance. Daniel
Posted on Jan 18, 2011
SOURCE: I have a Zanussi Aquacycle
Hi.
If the machine is filling up, then cycling and draining, the
problem is usually the belt. The belt is reached disassembling the appliance . If the belt is OK the problem is usually the motor or the motor control unit, which is a sealed electronic module connected to motor and to control board and located inside the washer. If the motor
has volts and does not turn, then the motor must be replaced. In some
less common case the control module itself may be responsible. Motor assembly and belt are located at the back of the drum and get accessed disassembling top and back of the washing machine.
If the machine does not go through the cycle, but it starts draining from start, then the problem is overfill detected. In that case check the drain system, the drain hose, the inlet valve and the pressure switch.
Regards.
Ginko
Posted on Aug 29, 2011
Sep 05, 2016 | Zanussi Washing Machines
Aug 15, 2015 | AEG Washing Machines
May 21, 2014 | Hotpoint Washing Machines
Nov 01, 2013 | Whirlpool Cabrio Washing Machines
Nov 01, 2013 | Whirlpool WFC7500VW Washer
Nov 01, 2013 | Zanussi Washing Machines
Jul 13, 2010 | Zanussi ZWF12070 Front Load Washer
Sep 03, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Sep 29, 2017 | Whirlpool AWM6120 Front Load Washer
Nov 23, 2008 | Whirlpool Duet GHW9150P Front Load Washer
47 people viewed this question
