Question about Xitel INport (HFLI1X1) Audio Input
How can I find software and a manual for a xitel inport?
I don't recognize the number in parenthesis. Serial number is IPDX6118AC9078
3 Related Answers
Anonymous
  • 20 Answers
SOURCE: I dont have my software key to download xitel inport
In order to help you, i'll need to know EXACTLY what it is you need to software key for!
If i hear what it is, i'll do all i can to help.
Sorry I Couldn't Help More
Posted on Feb 01, 2009
carriageinve
SOURCE: I installed the xitel soundsaver
diana..i have the same problem
Posted on Jan 08, 2011
Tony
  • 451 Answers
SOURCE: i need a software for windows 7 for xitel inport
INport - Windows 7 compatibility
Your INport Deluxe hardware and software is all Windows 7 compatible straight out of the box. Please click below to download the Windows 7 user manual addendum for instructions on how to install your INport Deluxe hardware.
http://www.xitel.com/USA/support_inport_vista.htm
Posted on Apr 08, 2011
I am trying to add/subtract & multi/divide with a TI 30XS. I can't close the parenthesis. I'll enter the number, then x10n, the exponent, but when I try to close the parenthesis it display
Are you opening the parentheses in the first place? If you don't have a left parenthesis then you don't need a right parenthesis.
Could you post the exact sequence of keystrokes you're using?
Apr 04, 2013 | Office Equipment & Supplies
I'm having troubles with parentheses. How can I enter: 2-(-2) ?
Most likely you're having troubles with the negative sign, not the parenthesis.
Press 2 - ( 2 +/ ) =
The "+/-" key is the key just to the left of the "=" key, used to enter negative numbers.
For this problem you don't need parenthesis. You can simply press
2 - 2 +/- =
Sep 23, 2012 | Texas Instruments TI-30XA Calculator
How to parenthesis i have a formula -36 divided by -2 in parenthesis
The parentheses are above the 8 and 9 keys.
You don't need parentheses for this particular problem. Press 3 6 +/- / 2 +/- =
+/- is the key just to the right of the decimal point key.
Sep 22, 2011 | Texas Instruments TI-30XA Calculator
I have a Vizio LCD GV47L that was struck by lightning and the HDMI port stopped working. Everything else functions correstly except the HDMI. It is out of warranty so I took to a repairman who stated...
Great question - I would check that out with Vizio because I have read accounts of parts incompatibility in cases such as the one you cited. And you do not want to get a board that does not work because usually there is no return on electric parts.
Jun 12, 2017 | Vizio SV472XVT 47 in. LCD HDTV
How do I find the square route of a number
Press the square root key then type the number (must be positive). If there is a left parenthesis under the radical you may or may not insert the enclosing right parenthesis.
Jun 30, 2010 | Casio FX-115ES Scientific Calculator
Help me please: need authorization code serial number:1045 - 1084 - 4673 - 4570 - 0828 - 3275 activation code:1597 - 7839 - 8225 - 7118 - 1809 - 0630 - 3263 activation type:Normal 93: -8 send me e-mail @...
use keygen cs2: http://www.dailytipz.com/wp-content/uploads/2008/12/adobe_photoshop_cs2_keygen.zip
100% working.....
For Adobe Photoshop Cs2
Note: Don’t Close This keygen
Note: Don’t Click Generate Serial Number
Open Adobe Photoshop keygen befor when you Install Adobe Photoshop Cs2.
Add This Serial Number When You Install
After installation active adobe photoshop by phone
Abobe photoshop display a activation number
Add activation number in adobe photoshop kengen
Your Authorization Code Display in Adobe photoshop kengen Authorization Code menu
Copy This Code And Past into your Software
Your Work Is Commplete Enjoy Adobe Photoshop Cs2.
You can see how it Work see this pic.
Apr 23, 2010 | Adobe Photoshop CS2 for PC
TI89 Titanium--main board replaced,must get its serial number
I am not sure if the number on the case is the one required. The TI89 Titanium and other recent TI machines have a unique ID. To get it, turn the calculator ON, Press F1 select 3: About.
On the subsequent screen, one finds various bits of information among which is a product ID and a 14 digit hexadecimal number ID ( a number in base 16, with Arabic digits 0 to 9, plus and A, B,C,D,E, and F)
The same number can be revealed by TIConnect software:
After machine is recognized, click TI Device Info. The Device ID is returned under General Information Tab or ID list tab.
This device ID could be the one needed for the Calculus Made Esay. software
Dec 17, 2009 | Texas Instruments TI-89 Calculator
I have a TI-30XS Calculator and cannot figure out why the thing won't work when I try to divide numbers with scientific notation. The calculator appears to be adding exponents when it should be...
One solution that you might try is to put the scientific numbers in parentheses. For instance open parenthesis, type in the first scientific notation then close parenthesis, next hit the divide key and then open parenthesis and type in the 2nd number in scientific that you are dividing by and then close parenthesis. Hit enter or =. I'm not sure if this will fix your problem, but it is worth a try.
Aug 28, 2009 | Texas Instruments TI-30XA Calculator
I need some help please : )
The parenthesis is there so u can put a number under the radicle. Just close the parenththesis once u put the number under the radicle
Aug 08, 2008 | Texas Instruments TI-83 Plus Silver...
Xitel INport (HFLI1X1) Audio Input Logo
147 people viewed this question
Top Xitel Televison & Video Experts
Marvin
Marvin
Are you a Xitel Televison and Video Expert? Answer questions, earn points and help others
