If one of the pads on your Yamaha DD65 electronic drum set is not working and not producing sound when hit with sticks or your hand, there could be a problem with the pad itself or with the drum module. Here are a few things you can try to fix the problem:
- Make sure that the pad is securely connected to the drum module. The pad should be firmly plugged into the corresponding port on the drum module.
- Check the pad for any visible damage or debris. If the pad is damaged or clogged with debris, it may not be functioning properly.
- Check the drum module for any visible damage or debris. If the module is damaged or clogged with debris, it may not be functioning properly.
- If the problem persists after trying these steps, it is possible that there is a problem with the pad or the drum module. In this case, you may need to have the drum set inspected by a technician to determine the cause of the issue.
If you are not comfortable troubleshooting the problem yourself, it is recommended that you contact Yamaha customer service for assistance. They may be able to provide further guidance or offer repair options.
Hi Anonymous, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? Please describe the problem.
