Question about Samsung SYNC SGH-A707 Cellular Phone
Ford my sync problems
How do I delete a phone device on sync
How do I connect to Ford Sync?
To use any of the phone features for SYNC such as making a call, receiving a text message, or using SYNC Services, you must first connect, or "pair" your Bluetooth-enabled phone. Pairing is what allows Bluetooth devices to communicate securely with each other.
Please note that SYNC can make and receive calls using only one paired phone at a time.
Before you start
There are a few things you should do before starting step 1:
blobserver?blobkey=id&blobwhere=1309207543643&blobcol=urldata&blobtable=mungoblobs&b=91
Turn on your
  • Mobile phone
  • Vehicle
  • Radio/SYNC
blobserver?blobkey=id&blobwhere=1309207543650&blobcol=urldata&blobtable=mungoblobs&b=91
Enable your phone's Bluetooth feature and make your phone discoverable.
Press the Phone button to access the Phone Menu. Press OK. Add a Device displays. Press OK.
SYNC prompts, "Press OK to begin pairing device." Press OK.
SYNC prompts, "Search for SYNC on your device and enter the PIN provided by SYNC." Press OK.
A six-digit number displays on the screen for three minutes, during which time SYNC actively seeks for the same number from your phone.
Type the number displayed by SYNC on your phone key pad.
Upon successful pairing, a message displays confirming the phone is connected.
Exit the phone pairing process by pressing the Arrows to select the Exit message and press OK to leave the Phone menu.
Aug 25, 2014 | Cell Phones
How I delete the bluetooth devices or contacts?
Reset to factory settings. This will delete all the phones data.
Or do it one by one by going into contacts and deleting them.
Then go to bluetooth settings and delete the bluetooth devices that are synced.
Aug 06, 2014 | Pantech Breakout 4g Black Cell Phone...
Sync instructions
press the phone button, use the tune knob to get to bluetooth device, and delete devices, press OK. when you go back into the phone, it will ask to add a device. Search for bluetooth device with your phone, enter PIN. Done.
Jul 19, 2014 | 2009 Ford Escape
IPhone deletes my contact names when I sync it to computer! Leaves the numbers, delete only names.
If you've set up automatic syncing, iTunes syncs your device by default whenever you connect your iPod, iPhone, or iPad to your computer. If you don't want iTunes to sync your device without being prompted, you can change this setting.
You can prevent unprompted syncing for any specific iPod, iPhone, or iPad; or for all iPod, iPhone, or iPad devices you connect to your computer.
To prevent unprompted syncing for a specific iPod, iPhone, or iPad:
  1. Connect your iPod, iPhone, or iPad to your computer.
  2. In iTunes, select your device (below Devices).
  3. Click Summary, and then deselect "Open iTunes when this Device is connected."
To prevent unprompted syncing for all iPod, iPhone, and iPad devices:
  1. In iTunes, choose Edit > Preferences.
  2. Click Devices.
  3. Select "Prevent iPods, iPhones, and iPads from syncing automatically."
    If this checkbox is selected, any connected iPod, iPhone, or iPad won't sync without being prompted.
To sync your iPod, iPhone, or iPad when unprompted syncing is disabled, connect your iPod, iPhone, or iPad to your computer, and then choose File > Sync "Device Name" in iTunes, or click your device (below Devices) and then click Sync.
For more information, see the iPod, iPhone, or iPad User Guide or the Apple Support website.
Dec 18, 2012 | Cell Phones
I Phone Blutooth problem with Ford G6E Turbo it keeps disconecting
HI deepsurf. Look at the connections in the phone one you need to make sure it is in discovery mode and next you need to make sure it says always connect. Now if you are using ford sync yopu need to register on sync's site and this will elimate mot of your problems. Also side note you can delete the bluetooth out completely and reinstall the bluetooth . Use the fords manaual when your truing to get the bluetooth to connect. it should work. HOPE THIS HELPS
I’m happy to help further over the phone at https://www.6ya.com/expert/ronald_e152e07e272e4f27
Dec 06, 2010 | Cell Phones
How do I bluetooth pair my i9 phone with my Ford SYNC
On your Ford Sync board, press the phone button. It will start to search for already paired devices. If none is found, press the arrow buttons until you find 'Add Bluetooth Device'. Then, press OK. You'll see it will generante a PIN. Now, make your phone's bluetooth application look for new devices. After a while, the Ford Sync device will appear on the phone screen. Select it, and make the the bluetooth application proceed. When a PIN (or pairing code, or passkey) is requested, enter the PIN generated by the Ford Sync device.
Hope it works for you.
Regards, Carlos
May 20, 2010 | Cell Phones
My bb 8310 AT&T device won't pair with a headset or with my ford fusion
Make sure you have the correct password for your phone. Also look in your fusion manual as to the correct steps needed.
  • Press the Power Button. // This is on a 2010 Ford Fusion.
  • Then you hit the Phone Button.
  • It should say “No Phone Paired” that means that no phone has been paired with this.
You now have a choice of options:
  1. Add Bluetooth device
  2. Connect Bluetooth device
  3. Set Primary Phone
  4. Set Bluetooth On/Off
  5. Delete Device
  6. Delete all Devices
You want to choose Add Bluetooth Device, press OK
  • Then on your mobile, turn your Bluetooth On.
  • Setup Bluetooth – Search
  • Now it’s searching for it, when that gets full, Click Sync.
  • Then you’ll want to enter the PIN number that’s on the screen.
  • Say YES to connect to Sync.
  • Now screen on dash will say your mobile phone
Mar 26, 2010 | RIM BlackBerry Curve 8310 Smartphone
SGH-u700 - Ford Sync - Bluetooth - downloading phonebook
contact your samsung mobile store and have them upgrade the sync for you to pair with the car.
May 30, 2009 | Samsung SGH-U700 Cellular Phone
Unable to sync
Usually rebooting the phone will cure this, I presume you have switched the phone off, removed the battery and restarted?
make sure in
File--> connection settings
that usb and the port you have assigned to bluetooth is enabled
(all tick boxes checked)
try deleting the device from active sync
File--> Mobile device --> (select your device)
then go to
File --> Delete mobile device
make sure you have copies of any un-synced data as it may be lost but shouldn't.
If I remember rightly (dont have a touch to hand) also delete the link to the pc in the active sync window on the touch
Menu--> options (select the server name) Menu-->Delete
and re create the profile by plugging in the device.
May 26, 2008 | HTC Touch P3450 Smartphone
Recover deleted programs
doing a hard reset will reinstall all the factory software. Unfortunatly you will loose all your contacts and files and user installed programs unless you backed up your device and ative sync will see it as a new device you can drag the backed up files to the new device in from your old sync folder in windows
to do a hard reset
Press both the right and left softkeys on the front of the phone while you are pressing the 'soft' reset button on the bottom of the phone. Press Y and then the space bar let the phone reset and follow prompts, after 3 seconds, it will install the sprint software I recommend a soft reset after that. Sync, and you're ready to go again!
Dec 17, 2007 | Sprint Vision PPC-6700 Smartphone
Samsung SYNC SGH-A707 Cellular Phone Logo
Top Samsung Cell Phones Experts
Muntejaya Ginting
Muntejaya Ginting
Michael Thomas
Michael Thomas
Marvin
Marvin
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
