Question about JVC KD-G421 CD Player
Jvc firmware think i need to update firmware on stereo as my iphone and ipod no longer work on stereo since installing numerous updates from apple. cant find anywhere that does a firmware download. plus update must be done through cd as i think there is no usb ports. many thenks
Errol Hodgson
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 135 Answers
If you are using adapter, KS-PD100, it is possible that new iPods wont work with this older adapter, I would recommend to connect your iPhone via AUX on the front of the unit
Posted on Aug 03, 2014
5 Related Answers
Anonymous
  • 265 Answers
SOURCE: Cannot play ipod touch on car stereo
hi there
You will need one of theses:
Click Here
This is a USB to Stero adaptor... will fix your problem for you.
hope this helps
alex
Posted on Apr 06, 2009
josetejas
josetejas
  • 300 Answers
SOURCE: Connecting iPod to JVC KD-LH810!?!
Hi, KD-LH810 has no option for external input. Refer to the picture attached. It is only front and rear line outputs. Don't get disappointed. Buy the accessory cable KS-U100 and you are set. This info is from the installation manual.
Posted on Jan 19, 2010
afairman1927
  • 41 Answers
SOURCE: had a new battery put in my car and now when I
push the volume knob button in and hold it down until the psm menu pops up. your display should read "DIMMER" press the track forward button repeatedly until you get to "EXT IN" and then use the volume knob to select it. then hold down that volume knob button again for 4 to 5 seconds and your done
Posted on Mar 17, 2010
Anonymous
SOURCE: I have a jvc kd-g720 stereo in my car and when I
hey dude the ipod connector from the back wont let me use my ipod touch but it will let me to use my ipod nano as long as i play a song and than connect it, could it just be a failed connection? thanks.
Posted on May 20, 2010
Anonymous
SOURCE: JVC AVX-800 and Apple iTouch compatability issue
setting radio stations
Posted on Mar 31, 2011
Apple a1362
the model A1362 seems to be an iPod Touch 4th gen.
- update can be done with connecting the device with the USB-cable to a computer with iTunes on it
Apple iPod touch 4G Firmware iOS Update 6 1 apple-a1362-qrl052hdp2kg0kvuqxssgusw-4-0.jpg apple-a1362-qrl052hdp2kg0kvuqxssgusw-4-2.jpg
http://www.imore.com/how-update-iphone-ipad-and-ipod-touch-ios-6-itunes
Jun 17, 2013 | Cell Phones
Tried to update now ipod doesn't work at all!
download lastest ipod lastest firmware from http://www.felixbruns.de/iPod/firmware/
restore your ipod using that firmware.
here is howto do it tutorial
http://iphoners.org/shift-restore.itunes/
Dec 27, 2011 | Apple Ipod Touch 4
I just installed a jvc kd g825 and i have a iphone 4 when i plug it in it says reading file and starts charging my iphone but wont play any thing any solutions?
I had a similar problem after I updated my iPhone 3g's software to 4.0.1. I read that if you turn off your iPhone, then with your car/stereo turned off, plug in your iPhone. Now turn on the car/stereo which will turn on your iPhone automatically and "re-initialize" the relationship with the iPhone. This worked for me. Hope this helps. If not, check the Apple forums.
Aug 11, 2010 | JVC KD-G820 CD Player
My iphone has just been updated ne s/w
please update the new software and try it . it will work
Jul 19, 2010 | Apple iPhone 3G
Firmware
It is the program that makes your iPod touch function the way it should. We update that using software updates from iTunes.
How do you get it? If you're talking about .IPSW files for updating your device, you can get it from this website:
For more iPod touch / iPhone tips, click here.
Feb 17, 2010 | Apple iPod touch
How can I use JVC AVX810 with Iphone? Currently IPOD works fine with the USB cable but IPHONE is not recognised. Maybe there is an adaptor that can solve it?
JVC KS-PD100 iPod Interface Adapter (257KSPD100, sold separately). This optional iPod Interface Adapter supports audio playback for the following iPod models - iPod click-wheel (3rd gen), iPod photo (4th gen), iPod mini (1st/2nd gen), iPod nano (1st/2nd/3rd/4th gen), iPod video (5th gen), and iPod classic (80/120/160GB). The KS-PD100 is not compatible with the iPod touch (1st/2nd/3rd gen), iPod nano (5th gen), or iPhone (2G/3G/3GS). This iPod interface will also not charge the iPod nano (4th generation). *Apple firmware updates may change functionality results.
There u go.....
Jan 29, 2010 | JVC KW-AVX810 Car DVD Player
What are the steps to update my iphone
Here is simple guide for those Users who will be first time upgrading their iPhone 2.2 or 2.2.1 to firmware 3.0. The guide is applicable for Upgrading iPhone 2G/3G 2.2 or 2.2.1 to OS 3.0 and also for iPod Touch. Please note in order to upgrade iPhone to firmware 3.0 you must have installed iTunes 8.2.
How to Upgrade iPhone 3G 2.2/2.1 to 3.0 firmware 1. Connect your iPhone 3G to computer
2. Open iTunes 8.2
3. Select your iPhone under Devices in the Source List on the left.
4. In the iPhone Summary pane, click Check for Update.
5. Click Download and Install. Do not disconnect your iPhone until the update has finished
That’s it, Once update is finished your will have iPhone 3G running latest firmware 3.0.
Please rate this solution
RNJ VINODKUMAR
Oct 02, 2009 | Apple iPhone Smartphone
Computer shuts down when connecting iphone
Try the latest itunes:
http://www.apple.com/ipod/download/
- Quit iTunes if it's currently open.
- Visit Apple Downloads to see if there are newer versions of iPod Updater (this contains software for all models of iPod) and iTunes than what's installed on your computer.
- If there are newer updates available, download the Windows versions of the updates, then run the installers on your computer to install the updates.
- When it's finished, iTunes will already be updated, but you'll need to run the iPod Updater to update your iPod, so connect your iPod to your computer.
- On the Start menu, point to All Programs, point to iPod, point to iPod Updater, then click the latest iPod Updater.
- Click the Update button to update the software on your iPod (if the Update button appears unavailable, your iPod is already up to date).
If it still fails, remove the automatic restart from windows:
Go to Start -> Control Panel -> System
Go to Advanced
Under the Startup and Recovery section, click Settings...
Under System Failure un-check "Automatically restart"
Feb 11, 2009 | Apple iPhone Smartphone
JVC KD-G421 CD Player Logo
Top JVC Car Audio & Video Experts
xxxxxx xxx
Steve Sweetleaf
Steve Sweetleaf
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
