Question about Avanti WC1500DSS 30 Bottle Wine Chiller with Electronic Display
Has anyone replaced a compressor relay on this chiller? Looks like it is not designed for replacement, but if it can be done with a generic relay I would like to know. Thanks.
The compressor relay is not listed on the Avanti parts list for this chiller - apparently is sold as part of the compressor assembly. If the compressor has to be removed to replace the relay, then I expect the chiller is ready to junk.
Posted by Dwight Abbott on
Rick Parker
    Sergeant:
    Champion:
  • 234 Answers
The cost of one of those compressors is over $100. When you factor in tax and labor you're better off junking it. Its also possible you have a compressorless cooler called Peltier.
Posted on Aug 16, 2014
4 Related Answers
Anonymous
SOURCE: AVANTI WCR683DZD WINE CHILLER - E4 ERROR CODE
I have the same E4 problem. You can order the PCB from Avanti at Miami Florida or your regional Avanti service rep.
Posted on Dec 16, 2009
j_warenzek
  • 49 Answers
SOURCE: Avanti EWC-12 circuit board replacement (correction)
the green an yellow wire is a ground. Look for an area on the board with a ground symbol earth.gif. Can you not match the location from the old board???
Either way the black and red are your positive and negative power, while the third is the ground. The wire probably are located in close proximity to each other.
Let me know if this helps
Jer
Posted on Jan 16, 2010
Sea Breeze
John Tripp
  • 4656 Answers
SOURCE: Where can a I find
You don't really need the exact parts. Supco sells a RO81_1-12th HP to 1-5thHP that just slips on the compressor S,R and Common pins.
sea_breeze_218.jpgDistributor Locator
I would choose their parts over any OEM hard to find parts because they are simple and dependable, Thanks Sea Breeze
If helpful please Rate this solution.
Posted on Jul 15, 2011
galsga
  • 42 Answers
SOURCE: my avanti wine chiller mod ewc 16 b serial n.0800854 stop cooling what can i do ?
I've added a link for an Avanti ewcb,
http://www.retrevo.com/support/Avanti-EWC16B-Refrigerators-manual/id/867bh235/t/2/. There you can find a complete manual on the product which will help you to locate where the problem is coming from. hope I've helped!
Posted on Oct 31, 2012
Wine cooler does not stay cool
Do only if you are properly trained on live circuits.. Do at your own risk. Check the compressor's capacitor and the relay. Is the compressor getting juice?
Nov 23, 2013 | Avanti Refrigerators
HAVE A PARAGON A706 TIMER IN A OLD CARRIER CHILLER ,THE MOTOR IS BAD, NEED TO REPLACE TIMER OR MOTOR ,CARRIER DON'T OFFER A REPLACEMENT PART NOW,NEWER EQUIPMENT ARE USING CIR-BROADS, GOGGLE THE TIMER...
Here is a new control via e-bay:
http://cgi.ebay.com/Paragon-A-706-00-Hvac-Timer-Control-/170621558465 ($99.00)
This is the chinese generic version of the timer:
R 8004-TMDE706SC Problem is.... it is so generic that you must sort out defrost time required periods 115V 230V or 240V.
I have to be honest... you can probably walk into any reputable applicance parts source and find a generic timer much cheaper. (Match them up) What is the model number of the compressor? Per the timer specs.. you should have a 1/3 hp compressor. The LRA (locked rotor amperage) number on the side of the compressor is probably around 21.7 Amps. The failures on older equipment are run capacitors, and PTC relays / thermal overloads. There should be 3 posts on the compressor. C, R and S. You should read winding resistance C - R and C - S you should NOT read resistance C, R or S to chassis ground. (C maybe if it is internally grounded) If R or S read to ground the compressor has failed. Again if you insist on keeoing the unit you can get a generic 1/3 HP Embraco (or another brand) compressor.
Thanks for choosing FixYa,
Kelly
May 09, 2011 | Heating & Cooling
Compressor not coming on. Part looks like a relay burnt up, part #5SP04P437NFM 2220475 04 F03R. Question - would compressor work if part replaced? or is compressor gone?
Hello, Shake the relay. If you hear it rattle it's just a bad relay and you can replace it. If it does not rattle then the compressor is bad. If you have any other questions please feel free to comment again. Good Luck! Mike
Oct 19, 2009 | Whirlpool Refrigerators
AC compressor will not stay on during hot days
THE COMPRESSOR TRIPS DUE TO TWO REASONS, FIRST ONE IS THAT EXCESS GAS IS CHARGED IN COMPRESSOR CIRCIT AND DUE TO THIS COMPRESSOR OVERLOADS AND TRIPS. THE SECOND ONE MAY BE DUE TO THERMOSATIC VALVE LOCATED IN CHILLER (IN SIDE CAR SWITCH BOARD/DASH BOARD). FROM [email protected]
Apr 20, 2009 | 2002 Nissan Sentra
York screw chiller R-22
hi! there;
there are several causes we can consider in tripping of unit on auxillary sensor.the sensor device was designed to cut off source at specific limit of time or load.the over load sensor device was equipted to the main source specially on cmpressor of chiller to protect of burning the motor.
common causes of tripping off unit
1.high current on supply source.you can check this on one common line of compressor.using clamp ammeter.what ever reading you got when unit is running,compare this on rated current on manuals if high ampere was registered.ther is an overload supply the over load sensor will activate and cut off your unit.
a. source of overload is due to obstruction on refrigeration system,filter dryer are clogged,excessi9ve oil on high side.
b. themostat not cycles on,due to poor condensing fan, dirty condenser fin tube,or condeser insufficient cooling effect.
c. bearing,lubrication are not maintained usually on compressor on open type unit,
2. electrical wire and electronic control board short circuited.
a.sometime relay malfunction on cantactor w/c the supply souce intermittent either on one line supplying compressor,the compressor will suffer,it will just hum and trip off,
b.busted capacitor will trip off your unit,due to in the absence of starting motor.
this are common ways unit trip off, so regards and have a nice day,and one thing more don't forget to rate me, thank's
Apr 08, 2009 | Heating & Cooling
Replacing overload relay/capacitor on compressor of maytag fridge
replacing a start relay is very easy to do. usually its a swap the part wire for wire operation. in some cases you get a different looking relay but they normally have good instructions for the replacement part. if you'll post the model numebr fo your unit i can give you detailed instructions. thanks peyton
Mar 16, 2009 | Refrigerators
Avanti WC1500DSS 30 Bottle Wine Chiller with Electronic Display Logo
384 people viewed this question
Top Avanti Furniture Experts
ThaMp3Doctor
ThaMp3Doctor
ray gallant
Tom Chichester
Are you an Avanti Furniture Expert? Answer questions, earn points and help others
