Originally my VinoTemp (VT60GNV) stopped cooling completely and was making a clicking noise. I replaced the Relay and the Overload, plugged it back in and yay, it started cooling. It got to down about 65 then stopped cooling again. The fans running, the compressor is very hot but sounds like it's clicking on. Any ideas?
I sounds to me like the compressor is overheating. There is an overload on the compressor itself. Follow the wires where they go into the compressor. There will be a black wire going from the power cord to the overload. These can be purchased at appliance parts stores. Make sure there is no dirt build up on condenser coils or a kink in the tubing.
SOURCE: Vinotemp VT-60 Condenser won't shut off, unit running way too cold
It might be a sensor or control board problem. Any appliance repair place should be able to help you out with this. Or you can try contacting the manufacturer directly for help or if you need to purchase replacement parts. Otherwise, my cheapest suggestion would be to hook the cooler up to a timer, so you can turn the unit on and off maybe every 20 minutes or so. That should help keep it from causing more harm and then you can monitor the temperature with a thermometer. Hope that helps!
SOURCE: Vinotemp VT-16TEDS has light on but doesn't cool
You may need to change the cooling system on the unit if the unit is free of dust and still does not cool.
SOURCE: Vinotemp VT60 Freezing
For LL error code,click the link below :----http://technoanswers.blogspot.com/2012/01/ll-error-on-vinotemp-wine-cooler.html
-----------Thanks.
SOURCE: VinoTemp VT60
Step 1:
It's most likely the PTC (Positive Temperature Compensated) start relay that turns the compressor on and off. The manufacturer has replaced part number P6R8MC with part number 6R8MG for this PTC start relay. Order part number 6R8MG, it cost less than $20 from AppliancePartsPro
First, unplug the wine cooler and take off the back panel. The back panel is held into place with several philips head screws.
Step 2:
Locate the compressor. You'll find the compressor in the bottom left corner of the VT-60 as viewed from the back. You will see copper tubes coming out of the compressor. These tubes carry the compressed refrigerant to the evaporator assembly. Be careful not to crimp or damage the copper tubing.
Step 3:
Find the black plastic cover to the left of the compressor. This cover is held into place with one philips head screw. Remove the screw and remove the cover to find the PTC start relay.
Step 4:
The relay is connected to the compressor by a single blade connector and two pins which protrude from the compressor. Remove the blade connector and pull the PTC relay to the left, sliding it off the pins attached to the compressor.
Step 5:
Slide the relay on the connector pins, reattach the blade connector, reattach the black pastic cover over the relay, reattach the back panel onto the VT-60 and you're done.
