Question about Kirby Vacuums
How to repair drive pedal kirby
Drive pedal
kirvac
    Problem Solver:
  • 13 Answers
You will need to remove upper cover ,then remove the three screws
holding the trans in. Slide out the old drive pedal reuse the cam arm
and install new pedal. Slide trans back in and reinstall belt,reinstall rear screw first then the other two . replace cover and test N/D pedal.
Posted on Aug 18, 2014
1 Related Answer
b0sslady2001
Marci Marple
  • 357 Answers
SOURCE: kirby neutral/drive pedal
HELLO, JUST USE THIS GUIDE! :0)
http://reviews.ebay.com/REPLACING-OR-REPAIRING-KIRBY-VACUUM-NEUTRAL-DRIVE-PEDAL?ugid=10000000011180003
HOPE IT HELPS! :0)
Posted on May 17, 2012
How do I replace a kirby g7 drive pedal?
Here is a step by step walk through with pictures on how to replace the neutral / drive pedal on any Kirby Generation vacuum (G3, G4, G5, G6, Ultimate G, Ultimate G Diamond Edition, Sentria and Sentria II)
Kirby Neutral Drive Pedal Replacement Guide
GoodVac.com Technician
www.goodvac.com
1-800-775-6586
May 04, 2014 | Kirby G6 Bagged Upright Vacuum
Kirby g5 techdrive n/d pedal came off will not stay on
The pedal will need to be replaced. A shift mechanism pressed on the end of the shaft has come off and cannot be re-installed. The drive unit must be removed from the machine, and the pedal assembly and shift cam can then be replaced. This may not be a do-it-yourself repair, as a good deal of disassembly is required.
Feb 04, 2011 | Kirby G5 Bagged Upright Vacuum
My Sentria always runs in the drive mode and it is so fast it seems out of control. If I push the neutral pedal it stays in drive. I can push it the regular way when it is turned off, whether the pedal is...
I sold vacuums for almost 20 yrs and the Kirby gets lots of complaints. The transmission that it has in it breaks as your has and they are costly.The best thing to do would be to take the maching to the local vacuum store(eg. sewing and vacuum are often in the same store).Bring it to a used vac store and they all repair kirby and thay can give you the best advice. I dont recommend going to kirby as thay will spend four hours at your house trying to sell you a newer model and they have not changed enough to get another one in hopes it will be betrter. Good luck
Oct 07, 2010 | Kirby Ultimate G Bagged Upright Vacuum
Kirby G5 - the Tech Drive does seem to have much power
you need either a new nutreal cam bracket assembly, that is what engages and disengages the tech drive.OR to adjust the handle pivot assy- diffucult . this is not for the faint of heart. it is possible to fix them as i used to repair kirbys, however, I remember how frustrating it was to figure out how to disassemble and reassemble them. it is very complicated to a novice. I would recomend having it repaired professionaly. it is possible for a professional to repair it in a very short period of time.
another thing to consider. look on the UNDERSIDE of your Kirby, between the two drive wheels. just in fronnt of the tech drive/nutreal switch. there should be a screw there, tighten that screw up. actually tighten all of them. on My generation 3 the center screw came loose and it would not go in to drive and it would make an aweful clatter. hope this was helpful
Jul 08, 2008 | Kirby G5 Bagged Upright Vacuum
Gear lever
here are a few links to repair proceedures for the kirby (pictures included)
Transmission:
http://www.greatvacs.com/Kirby%20Transmission%20Adj.shtml
On/Off switch
http://www.greatvacs.com/Kirby%20Powerswitch.shtml
Hope that helps!
Jan 02, 2008 | Kirby G6 Bagged Upright Vacuum
Vacuums Logo
Top Kirby Vacuums Experts
Gerry Harvey
Gerry Harvey
Paul Bade
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
