Question about Chevrolet 1996 Chevrolet Blazer S10/jimmy S15 Radio
Location of inertia switch - Chevrolet 1996 Chevrolet Blazer S10/jimmy S15 Radio
Posted by David Joseph on
2014 Ford Flex location of inertia switch
The 2014 Flex doesnt have a fuel cutoff/inertia switch like older Fords do.
Nov 03, 2016 | Ford Cars & Trucks
1995 ford festiva inertia switch location
Karl, Ford installs inertia switches in most fuel-injected vehicles.
In passenger cars, the switch is typically located in the trunk and is identifiable by the red button on its top. Switch could be behind a trim panel/ piece/door. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
OEM Ford Lincoln Mercury fuel cut off inertia control module switch XS7T...
1993 Ford Festiva No power at fuel pump relay
Aug 12, 2016 | Ford Cars & Trucks
If it has an inertia switch, it will be on the passenger side under the kick panel under the glove box.
Apr 20, 2014 | 2000 Mazda 626
i dont think GM usesinertia switch thats ford. but you could check the gas pump relay, or a fuse for example, the inertia switch on fords is in the trunk or close to drivers front door
Apr 04, 2014 | 2001 Oldsmobile Silhouette
Inertia switch located
The ony manufacture that uses a inertia switch for the fuel pump is ford.
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_d728a59f986299fa
Sep 08, 2013 | Hyundai Accent Cars & Trucks
92 Diamante inertia switch location
my 1996 nissan quest, i do not know Left kick panel near the hood release handle look for a hole left side just ahead the left door push down to reset the inertia switch. Good luck
carprog
Jul 16, 2013 | Cars & Trucks
Where is the fuel pump relay button located
If you're talking about the Inertia switch, the following may help: Inertia Switch GENERAL INFORMATION This switch shuts off the fuel pump in the event of a collision. Once the switch has been tripped, it must be reset manually in order to start the engine. The inertia switch is located on the toe-board, to the right of the transmission hump, in the passenger-side footwell.
Sep 18, 2010 | 1996 Ford Explorer
Inertia switch
hallo
i belive it does not have one. you have only engine control reley(K46) engaged by ECU and fuse(F28)
Marko
Sep 21, 2009 | Audi Cars & Trucks
Chevrolet 1996 Chevrolet Blazer S10/jimmy S15 Radio Logo
44 people viewed this question
Top Chevrolet Audio Players & Recorders Experts
Marvin
Marvin
Lawrence Oravetz
Glenn Smart
Glenn Smart
Are you a Chevrolet Audio Player and Recorder Expert? Answer questions, earn points and help others
