Dyson AM07 Tower Fan Logo
Question about Dyson AM07 Tower Fan
Dyson instructions how to put together dyson am07 blue tower fan
AskDyson
  • Official Brand Answer
  • 2,572 Answers
Hi there, it's Jack at Dyson.
The AM07 Tower fan is quick and easy to assemble - our Getting started video guide shows you how:
I hope this helps, but if you have any additional questions you're welcome to give us a call on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Posted on Aug 11, 2014
tip
How to clean your Dyson Cool fan
How to clean your Dyson Cool AM01 or AM06 desk fan, AM02, AM02 Living, AM02 Mini, AM07, AM07 Living or AM07 Mini tower fan, or AM03 or AM08 pedestal fan.
Your machine may differ to the one shown in the video, but the process for cleaning it will remain the same.
IMPORTANT: Please turn off and unplug your Dyson Cool fan before cleaning it. We recommend using a soft, dry cloth or soft dusting brush to clean the intake holes and loop amplifier. Do not use liquids, polishes or detergents to clean your Dyson Cool fan as this could cause damage not covered under guarantee.
on Nov 27, 2014 • Dyson Dryers
tip
Dyson Cool AM07 Air Multiplier tower fan - Getting started
How to assemble and use your new Dyson Cool AM07 Air Multiplier tower fan: adjust the power and oscillation, set the sleep timer and store the remote. The sleep timer can be set between 15 minutes and nine hours.
on Mar 07, 2014 • Dyson Dryers
Keep getting an error code F3 on my fan, what does it mean?
The machine is too cold. Increase room temperature to 5°C or above before restarting machine.
http://www.dyson.co.uk/support/am10/am10-white-silver/my-machine-is-not-working/my-machine-displays-an-f1-f2-f3-f4-or-code-
2answers
Hi just brought Dyson am07 tower fan home from the shop. At first it worked fine but after a few minutes it started to show F3 and does not work
i dont know personally but try this link http://www.dyson.co.uk/support/am07/am07-tower-fan-white-silver best to get help from the experts :)
1helpful
My dyson fan was serviced last winter by you as it was recalled now it does not work , the lights come on and the motor runs 2 seconds and dies
Hi Kathy, it's Jack at Dyson.
I'm sorry to hear you're concerned about your Dyson fan heater. However, this could be normal behavior from your machine, as the heater would usually display an error code if was an actual fault.
If the target temperature you've selected (shown on the LED display on the front of the machine) is equal to less than the ambient room temperature, the machine may run momentarily until the intelligent thermostat shuts it off.
The solution is to raise the target temperature, using either the remote or the controls on the base of the machine, until the heater runs. It's important to keep in mind that what you're selecting is the temperature you want the heater to heat the room to - so the machine won't run if the room is already at or above the target temperature.
I hope this helps, but if you'd like to discuss this with one of our experts you're welcome to call us directly on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
1helpful
How do I disassemble a Dyson Cool AM07?
Hi Glennis, it's Jack at Dyson.
I've included our Getting Started guide for AM07 below. To disassemble it, you would just need to reverse these steps. To remove the loop amplifier, hold the main body firmly and twist
the loop amplifier anti-clockwise to unlock.This may be a bit stiff if the fan is brand new and hasn't been disassembled before.
I hope this helps, but if you need further guidance from our experts, just give us a call on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Replacement fuse
There is not only 1 fuse but there is inside the coil of the electric field a little temperature fuse its most times inside a insulation tape
Need a manual Dyson am07
You should find our video guide helps in getting started with your new AM07:
However, if you would like a .pdf file of the AM07 User guide, please email me directly at [email protected] so I can send this to you.
22helpful
5answers
Instructions
Here are the two pages of the Aloha Breeze Mdl 84001's Operation Manual (including the construction instructions, basic circuit diagram, and operation instructions).
Top Dyson Dryers Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
NOEL
NOEL
Are you a Dyson Dryer Expert? Answer questions, earn points and help others
