Hey friend, thank you for the post!
I understand you are looking for a reset button on your Electrolux washer. The best way to reset your appliance would be to disconnect power from it for ten minutes, you can do that by unplugging the appliance or flipping the household circuit breaker. I hope that information is helpful. -Matt
Thank you for your inquiry, Sarah!
I see that your Electrolux washer will not go past sensing mode. This sounds like a possible issue with your sensor or door latch and I would recommend performing a reset on your washer to help clear out any miscommunications. You can reset your washer by disconnecting the power cord for roughly ten minutes.
I would check your door latch and door strike for any physical damage that could halt the progress of your washer. If you continue to have issues with your washer I would suggest having a professional out to perform a proper diagnosis and repair. I hope this information is helpful. -Matt
Hi friend, thank you for your inquiry!
On an Electrolux washer the error code "E00" stands for No code stored. This could be a miscommunication I would recommend you perform a reset on your washer. You can do this by flipping the household breaker for roughly ten minutes. If resetting the power does not correct the issue, could you please inform me of the new error code or if your washer continues to display "E00". I look forward to assisting you. -Matt
